- Distrowahl
- Linux Mint
- System:
Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop System: Acer product: Aspire XC-1780 v: 1.0
serial: <superuser required>
Mobo: Acer model: Aspire XC-1780 v: 2.0 serial: <superuser required>
UEFI: American Megatrends v: R01-B1 date: 10/21/2024
Info: 10-core (6-mt/4-st) model: 13th Gen Intel Core i5-13400 bits: 64
type: MST AMCP arch: Raptor Lake rev: 2 cache: L1: 864 KiB L2: 9.5 MiB
L3: 20 MiB
Speed (MHz): avg: 811 high: 900 min/max: 800/4600:3300 cores: 1: 800
2: 800 3: 900 4: 800 5: 833 6: 800 7: 800 8: 801 9: 821 10: 800 11: 800
12: 800 13: 800 14: 800 15: 831 16: 800 bogomips: 79872
Device-1: Intel Alder Lake-S GT1 [UHD Graphics 730]
vendor: Acer Incorporated ALI driver: i915 v: kernel arch: Gen-12.2
bus-ID: 0000:00:02.0
resolution: 1920x1080~60Hz
v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel UHD Graphics 730 (ADL-S GT1)
Device-1: Intel Alder Lake-S HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel bus-ID: 0000:00:1f.3
API: ALSA v: k6.14.0-37-generic status: kernel-api
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3
IF: wlp0s20f3 state: up mac: <filter>
vendor: Acer Incorporated ALI RTL8111/8168/8411 driver: r8169 v: kernel
port: 3000 bus-ID: 0000:01:00.0
IF: enp1s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IP v4: <filter> scope: global
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:7
Report: hciconfig ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: <filter>
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 0000:00:0e.0
Local Storage: total: 591.54 GiB used: 192.2 GiB (32.5%)
ID-1: /dev/nvme0n1 vendor: Micron model: 2450 MTFDKBA512TFK
size: 476.94 GiB temp: 32.9 C
ID-2: /dev/sda vendor: SanDisk model: USB 3.2Gen1 size: 114.6 GiB
type: USB
ID-1: / size: 225.48 GiB used: 90.52 GiB (40.1%) fs: ext4
dev: /dev/nvme0n1p7
ID-2: /boot/efi size: 244.2 MiB used: 18.9 MiB (7.7%) fs: vfat
dev: /dev/nvme0n1p5
ID-1: swap-1 type: partition size: 7.45 GiB used: 2.7 MiB (0.0%)
dev: /dev/nvme0n1p6
System Temperatures: cpu: 29.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.32 GiB used: 4.08 GiB (26.6%)
Processes: 434 Uptime: 6d 17h 34m Init: systemd target: graphical (5)
Packages: 4234 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Ich habe einen PC mit Linux Mint Cinnamon 22.2 und einen USB-Stick mit Linux Bodhi.
Als Installationsziel für den Bootloader (Grub) habe ich den USB-Stick ausgewählt.
Wenn der Stick eingesteckt ist und ich von diesen boote, dann habe ich im Grub-Menü die Wahl zwischen dem internen Linux und dem Linux vom Stick (beides läuft).
Wenn der Stick nicht eingesteckt ist, dann ist der Eintrag von meinem internen System noch im Bootmenü meines UEFI, läßt sich jedoch nicht starten.
Gruß
Thomas
