- Distrowahl
- Linux Mint
- System:
Kernel: 6.14.0-37-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASRock model: B365 Phantom Gaming 4
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: P4.30
date: 05/14/2020
Info: 6-core model: Intel Core i7-8700K bits: 64 type: MT MCP
arch: Coffee Lake rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 3278 high: 4599 min/max: 800/4700 cores: 1: 4505 2: 800
3: 800 4: 4466 5: 4599 6: 4459 7: 4500 8: 4552 9: 4597 10: 800 11: 4459
12: 800 bogomips: 88796
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] driver: nvidia v: 535.274.02
arch: Pascal bus-ID: 01:00.0
gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia platforms: active: gbm inactive: N/A
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.274.02 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
API: ALSA v: k6.14.0-37-generic status: kernel-api
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6
Local Storage: total: 1.82 TiB used: 1.62 TiB (88.8%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
size: 1.82 TiB temp: 37.9 C
ID-1: / size: 130.16 GiB used: 97.24 GiB (74.7%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot size: 9.85 GiB used: 2.99 GiB (30.4%) fs: ext4
dev: /dev/nvme0n1p1
ID-3: /home size: 1.61 TiB used: 1.52 TiB (94.5%) fs: ext4
dev: /dev/nvme0n1p4
ID-1: swap-1 type: partition size: 18.63 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p2
System Temperatures: cpu: 40.0 C mobo: N/A gpu: nvidia temp: 45 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 11%
Memory: total: 64 GiB available: 62.6 GiB used: 2.99 GiB (4.8%)
Processes: 340 Uptime: 35m Init: systemd target: graphical (5)
Packages: 3697 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
peter@peter-desktop:~$
Untere Fehlermeldungen erhalte ich seit Monaten. Jedes Mal, wenn ein neuer Kernel kommt, dann erhalte ich eine Kernel Panic Meldung. Die obigen Fehler-Meldungen erscheinen immer wenn ich Updates/ Upgrades mache. egal ob übers Terminal oder die AV. Ich muss dann über den Boot-Manager den zweiten Kernel auswählen...dann fährt er wieder hoch. Leider ist es in der AV nicht möglich den neuesten Kernel zu aktivieren. Denn dieser Button und der Installationsbutton fehlt gänzlich. Nicht aufzufinden. Also habe ich folgende funktionierende Möglichkeit gefunden: "sudo update-initramfs -c -k all && sudo update-grub". Damit aktiviert sich der neueste Kernel automatisch und der Rechner fährt ohne Panic-Meldung flüssig hoch. Eigenartig ist dass ansonsten der Rechner funktioniert, und das seit fast einem Jahr der Fehlermeldungen.
Hier die Fehlermeldungen:
Cleaning build area...
make -j12 KERNELRELEASE=6.14.0-32-generic KVER=6.14.0-32-generic....(bad exit st
atus: 2)
Error! Bad return status for module build on kernel: 6.14.0-32-generic (x86_64)
Consult /var/lib/dkms/rtl88x2bu/5.2.4.4/build/make.log for more information.
dkms autoinstall on 6.14.0-32-generic/x86_64 succeeded for nvidia virtualbox
dkms autoinstall on 6.14.0-32-generic/x86_64 failed for rtl88x2bu(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
* dkms: autoinstall for kernel 6.14.0-32-generic
...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: Fehler beim Bearbeiten des Paketes linux-image-6.14.0-32-generic (--config
ure):
»installiertes post-installation-Skript des Paketes linux-image-6.14.0-32-gener
ic«-Unterprozess gab den Fehlerwert 11 zurück
Fehler traten auf beim Bearbeiten von:
linux-headers-6.14.0-33-generic
linux-headers-6.14.0-27-generic
linux-headers-6.14.0-29-generic
linux-headers-6.14.0-32-generic
linux-headers-6.14.0-28-generic
linux-headers-6.14.0-36-generic
linux-headers-6.14.0-37-generic
linux-headers-6.14.0-24-generic
linux-headers-6.14.0-35-generic
linux-headers-6.14.0-34-generic
linux-headers-generic-hwe-24.04
linux-generic-hwe-24.04
linux-image-6.14.0-34-generic
linux-image-6.14.0-36-generic
linux-image-6.14.0-37-generic
linux-image-6.14.0-27-generic
linux-image-6.14.0-28-generic
linux-image-6.14.0-33-generic
linux-image-6.14.0-29-generic
linux-image-6.14.0-35-generic
linux-image-6.14.0-24-generic
E: Sub-process /usr/bin/dpkg returned an error code (1)
