Farbcodes des Programms Laufwerke
    Linux Mint
    Kernel: 6.8.0-88-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop System: Hewlett-Packard product: HP Z640 Workstation v: N/A
    serial: <superuser required>
    Mobo: Hewlett-Packard model: 212A v: 1.01 serial: <superuser required>
    UEFI: Hewlett-Packard v: M60 v02.34 date: 05/18/2017
    Info: 10-core model: Intel Xeon E5-2640 v4 bits: 64 type: MT MCP
    arch: Broadwell rev: 1 cache: L1: 640 KiB L2: 2.5 MiB L3: 25 MiB
    Speed (MHz): avg: 1389 high: 3400 min/max: 1200/3400 cores: 1: 1198
    2: 1197 3: 2800 4: 1205 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 3400
    11: 1200 12: 1197 13: 1200 14: 1200 15: 1200 16: 1200 17: 1200 18: 1200
    19: 1200 20: 1200 bogomips: 95785
    Device-1: NVIDIA GM206GL [Quadro M2000] vendor: Hewlett-Packard
    driver: nvidia v: 535.274.02 arch: Maxwell bus-ID: 02:00.0
    gpu: nvidia,nvidia-nvswitch resolution: 1920x1200~60Hz
    API: EGL v: 1.5 drivers: nvidia platforms: active: gbm inactive: N/A
    API: OpenGL v: 4.6.0 vendor: nvidia v: 535.274.02 glx-v: 1.4
    direct-render: yes renderer: Quadro M2000/PCIe/SSE2
    Device-1: Intel C610/X99 series HD Audio vendor: Hewlett-Packard
    Device-2: NVIDIA GM206 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 02:00.1
    API: ALSA v: k6.8.0-88-generic status: kernel-api
    Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: 3040 bus-ID: 00:19.0
    RAID:
    Hardware-1: Intel sSATA Controller [RAID Mode] driver: ahci v: 3.0
    bus-ID: 00:11.4
    Hardware-2: Intel SATA Controller [RAID Mode] driver: ahci v: 3.0
    bus-ID: 00:1f.2
    Local Storage: total: 5.92 TiB used: 4.89 TiB (82.5%)
    ID-1: /dev/sda vendor: SK Hynix model: SC313 HFS512G32TNF-N3A0A
    ID-2: /dev/sdb vendor: Western Digital model: WD20EZRZ-00Z5HB0
    ID-3: /dev/sdc vendor: Western Digital model: WD20EZRZ-00Z5HB0
    ID-4: /dev/sdd vendor: Western Digital model: WD2003FYYS-02W0B0
    ID-1: / size: 467.89 GiB used: 68.98 GiB (14.7%) fs: ext4 dev: /dev/sda2
    System Temperatures: cpu: 22.0 C mobo: N/A gpu: nvidia temp: 45 C
    Fan Speeds (rpm): N/A gpu: nvidia fan: 56%
    Memory: total: 16 GiB available: 15.53 GiB used: 2.94 GiB (18.9%)
    Processes: 404 Uptime: 25m Init: systemd target: graphical (5)
    Packages: 2597 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Mir fiel es schon länger auf, jetzt frage ich einfach mal, da ich keine Infos dbzgl. finden konnte.
    Diese Partition ist farblich mit einem helleren Blau versehen. Die anderen Partitionen sind durchgängig blau. Alle HDs haben eine NTFS-Partition und die gleiche Größe.
    Was bedeutet es? (es funktioniert alles)
  • Steffen December 7, 2025 at 2:06 PM
  • Antwort auf folgende Frage von perplexity. ^^
    Cinnamon v: 6.4.8 Farbunterschiede eingebundene Partitionen im Dateimanager
    und chatgpt.
    Hier habe ich leider nichts gefunden.
    Cinnamon — Linux Mint Developer Guide documentation
    So bekommt man regnerische Sonntage rum. ^^
  • Kannst du mal bitte die man dazu zeigen.
    Ich habe mir gerade einen abgesucht.
    Hab nur im Programm Hilfe gewählt und bei der Installation von Mint gelandet bzw. per Google gesucht. Wenn sich das "man" auf "Manual" bezieht und im Terminal ausgeführt werden muss, hilf mir bitte. Ich bin da total doof. :D
  • /su Die KI bezieht sich immer auf Nemo, ich meinte das Programm "Laufwerke".
    OK, trotzdem finde ich nirgends ein Manual/Page Link dazu.
    Das was ich gefunden habe behandelt das nicht.
    Bin ich den heute Blind ? ?(
    Steffen Ich wühle mich gerade wegen Langeweile dadurch und finde nichts.
    Wieviel Kaffe muss ich den noch einwerfen ?
  • OK, trotzdem finde ich nirgends ein Manual/Page Link dazu.
    :D Es funktioniert ja alles, wollte es nur informell wissen. Es beruhigt mich, wenn Du auch keine Antwort findest. :D
  • Unter Ubuntu bestimmt die Akzent Farbe die Farbe der Partitionen:
  • es geht ja nicht um die Farbe, sondern um den Farbverlauf.
    Bsp1: 14,2% belegt, schmaler hellblauer Streifen
    Bsp.2: 48,6% belegt. breiter hellblauer Streifen mit fast 50% Deckung
    ? Verstehe ich nicht. :D
    Es betrifft die Unterschiede der Partition im Blauton des Programms Laufwerke. Selbst wenn man diese Farbe ändert, bleiben Farbabstufungen. Ich wollte wissen, was es bedeutet.
  • Ok dann habe ich nicht richtig gelesen.
  • Steffen die Frage hat doch @Frostlike8343 schon beantwortet, es zeigt die Belegung der jeweiligen Partition an. Je voller dein Datenträger wird um so höher wird der untere Balken der Anzeige.
