Mounten einer HD unter bisherigem Namen nicht möglich
    Linux Mint
    Kernel: 6.8.0-88-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop System: Hewlett-Packard product: HP Z640 Workstation v: N/A
    serial: <superuser required>
    Mobo: Hewlett-Packard model: 212A v: 1.01 serial: <superuser required>
    UEFI: Hewlett-Packard v: M60 v02.34 date: 05/18/2017
    Info: 10-core model: Intel Xeon E5-2640 v4 bits: 64 type: MT MCP
    arch: Broadwell rev: 1 cache: L1: 640 KiB L2: 2.5 MiB L3: 25 MiB
    Speed (MHz): avg: 1482 high: 3400 min/max: 1200/3400 cores: 1: 1694
    2: 1200 3: 1200 4: 1200 5: 1200 6: 3092 7: 3400 8: 1200 9: 1200 10: 1756
    11: 1200 12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 17: 1200 18: 1620
    19: 1200 20: 1297 bogomips: 95777
    Device-1: NVIDIA GM206GL [Quadro M2000] vendor: Hewlett-Packard
    driver: nvidia v: 535.274.02 arch: Maxwell bus-ID: 02:00.0
    gpu: nvidia,nvidia-nvswitch resolution: 1920x1200~60Hz
    API: EGL v: 1.5 drivers: nvidia platforms: active: gbm inactive: N/A
    API: OpenGL v: 4.6.0 vendor: nvidia v: 535.274.02 glx-v: 1.4
    direct-render: yes renderer: Quadro M2000/PCIe/SSE2
    Device-1: Intel C610/X99 series HD Audio vendor: Hewlett-Packard
    Device-2: NVIDIA GM206 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 02:00.1
    API: ALSA v: k6.8.0-88-generic status: kernel-api
    Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
    v: kernel port: 3040 bus-ID: 00:19.0
    IP v6: <filter> type: deprecated dynamic mngtmpaddr noprefixroute
    scope: global
    RAID:
    Hardware-1: Intel sSATA Controller [RAID Mode] driver: ahci v: 3.0
    bus-ID: 00:11.4
    Hardware-2: Intel SATA Controller [RAID Mode] driver: ahci v: 3.0
    bus-ID: 00:1f.2
    Local Storage: total: 5.92 TiB used: 4.88 TiB (82.4%)
    ID-1: /dev/sda vendor: SK Hynix model: SC313 HFS512G32TNF-N3A0A
    ID-2: /dev/sdb vendor: Western Digital model: WD20EZRZ-00Z5HB0
    ID-3: /dev/sdc vendor: Western Digital model: WD20EZRZ-00Z5HB0
    ID-4: /dev/sdd vendor: Western Digital model: WD2003FYYS-02W0B0
    ID-1: / size: 467.89 GiB used: 69.19 GiB (14.8%) fs: ext4 dev: /dev/sda2
    System Temperatures: cpu: 21.0 C mobo: N/A gpu: nvidia temp: 48 C
    Fan Speeds (rpm): N/A gpu: nvidia fan: 58%
    Memory: total: 16 GiB available: 15.53 GiB used: 2.27 GiB (14.6%)
    Processes: 386 Uptime: 8m Init: systemd target: graphical (5)
    Packages: 2597 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Ich wollte jetzt meine HDs von NTFS auf ext4 umrubeln. 1. HD gekauft = defekt (reparierte HD - brauche sie ja nur zum umkopieren - an meine Backups gehe ich nicht heran - Probleme bei der Partitionserstellung + kopierte und brach dann ab, wieder von vorn, jedesmal an anderer Stelle - Dockingstation). 2. HD gekauft (repariert), jetzt gab die erste interne HD auf (brach Kopiervorgang ab, ließ sich nicht mounten etc.).
    Hatte diese 2. HD per USB3 (Dockingstation) dran. Habe dann die 2. gekaufte HD eingebaut. Sie ließ sich nicht mehr mounten unter dem bisherigen Namen (Partitions-Name wie bisher). Habe dann einen neuen Mount-Namen vergeben, das war problemlos.
    Ich hab jetzt nur geschaut, ob ich etwas im Forum finde, fand nichts. Gegoogelt hab ich noch nicht und stelle diese Frage einfach mal. Die Spezis kennen bestimmt die Antwort.
    Ich vermute die alte HD steht irgendwo drin.
  • Go to Best Answer
  • Steffen
    zuerst die Ausgabe von:
    lsblk -f -m | grep sd
    Inhalt des Codeblock kopieren, in die Bash einfügen und die komplette Ausgabe posten.
    Versuche mal die SMART Werte der externen Laufwerke zu ermitteln. Da gibt es ein grafisches Programm in Mint.
    Diese auch posten.
    Kann es sein das die Docking Station ein "Knacks" weg hat. Wenn möglich die mal mit einem anderen OS testen.
  • sda 476,9G root disk brw-rw----
    ├─sda1 vfat FAT32 911D-6118 504,8M 1% /boot/efi 512M root disk brw-rw----
    └─sda2 ext4 1.0 c97a21f4-38dc-4f43-8fae-e7063afbf491 375G 15% / 476,4G root disk brw-rw----
    sdb 1,8T root disk brw-rw----
    └─sdb1 ntfs Daten_ 1761E1C1066D4B2A 88G 95% /media/steffen/Daten_ 1,8T root disk brw-rw----
    sdc 1,8T root disk brw-rw----
    └─sdc1 ntfs TV1 0A9469DD9469CC2F 49,5G 97% /media/steffen/TV1 1,8T root disk brw-rw----
    sdd ntfs TV2 78404AE73A790D26 520,6G 72% /media/steffen/TV3 1,8T root disk brw-rw----
    Die sind alle intern, extern (Dockingstation) war es nur für den Kopiervorgang, der nicht mehr funktionierte.
    Die SMART-Werte der betreffenden HD:
  • Ich würde jetzt die Aktion Kopieren mal unter einer Live Umgebung probieren. Mit einer mint.iso zum Beispiel. Nur mal so zum Test.
    Da wird es gehen (mounten), aber ich probiere das mal. Es lief ja so schon ewig. TV2 heißt jetzt TV3 (Mountname) und funktioniert problemlos. Als LW wird der Partitionsname (TV2) angezeigt.
  • Du sprichst vom automatischem mount wenn du das Laufwerk einsteckst? Vermutung: Da scheint jetzt die ursprünglich gemountete TV2 mit ihrer UUID verknüpft zu sein und das Paar ist jetzt für den Automount auf /media/USER/PLATTE reserviert zu sein. Die Verknüpfung kann man sicher irgendwo wieder löschen wenn man dem automatischen Mountmechanismus nachgeht.
    Da liegst Du goldrichtig, denke ich. Aber auch wenn ich Automount deaktiviere ist es nicht mehr möglich diese HD mit dem Klick im Dateimanager zu mounten. Irgendwo wird dieser problematische Eintrag stehen, nur wo?
    Hab mir mal die ISO von Mint Cinnamon 22.2 heruntergeladen und mir einen USB-Stick erstellt. Mint gestartet = keine Probleme. Der Klick im Dateimanager mountet diese HD mit ihrem Partitions-Namen, auch TV2, was bei mir nicht mehr funktioniert.
  • Aber auch wenn ich Automount deaktiviere ist es nicht mehr möglich
    evl. liefert
    cat /etc/fstab
    ein paar nützliche Infos.
    Oder mal hier ansetzen:
    How to mount a hard drive automatically in Linux Mint on start up using the GUI - RealLinuxUser.com
    Are your hard drives not showing in Linux Mint after start up? Here the solution to automatically mount a hard drive in Linux Mint via the GUI.
    www.reallinuxuser.com
  • # /etc/fstab: static file system information.
    # Use 'blkid' to print the universally unique identifier for a
    # device; this may be used with UUID= as a more robust way to name devices
    # that works even if disks are added and removed. See fstab(5).
    # <file system> <mount point> <type> <options> <dump> <pass>
    # / was on /dev/sda2 during installation
    UUID=c97a21f4-38dc-4f43-8fae-e7063afbf491 / ext4 errors=remount-ro 0 1
    # /boot/efi was on /dev/sda1 during installation
    UUID=911D-6118 /boot/efi vfat umask=0077 0 1
    /swapfile none swap sw 0 0
    /dev/disk/by-uuid/CC44FAEF44FADAE2 /media/steffen/TV2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    /dev/disk/by-uuid/0A9469DD9469CC2F /media/steffen/TV1 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    /dev/disk/by-uuid/1761E1C1066D4B2A /media/steffen/Daten_ auto nosuid,nodev,nofail,x-gvfs-show 0 0
    /dev/disk/by-uuid/316D7D6C0A07911D /media/steffen/TV2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    /dev/disk/by-uuid/5B05F30C5753F84E /media/steffen/TV2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    UUID=3ABB4B074F30E9DB /media/steffen/TV2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    /dev/disk/by-uuid/1661F2314277FBAF /media/steffen/TV2 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    /dev/disk/by-uuid/78404AE73A790D26 /media/steffen/TV3 auto nosuid,nodev,nofail,x-gvfs-show 0 0
    Zu Deinem Link, der erklärt wie man HDs automatisch mountet: Hab sie doch schon ewig per Automount gemountet (hab vorher ein Video von Jean geschaut). Hab ich etwas überlesen?
  • Das sind mir zuviele Einträge für nur 2 Festplatten (unter /media) mit je einer Partition. Ich würde die /etc/fstab mal als Backup speichern und alles im Codeblock löschen. Danach dann wieder alles von Anfang: siehe:
    https://wiki.ubuntuusers.de/fstab/
    frohes Schaffen
    Mir auch. :D (4 Festplatten)
    1 Linux-SSD, 3 Daten-HDs (alles intern). 1 USB3-Dockingstation für die Backups (keine HD momentan).
    TV2 gibt es in media, ist aber leer. Sie heißt jetzt TV3 (auch in media) und beinhaltet alle Ordner, die es sein sollen.
    Ich google mal. Ich vermute es ist eine Datei, wo es drinsteht.
  • Ich vermute es ist eine Datei, wo es drinsteht.
    Du brauchst Dir nur den Inhalt von /media anzeigen lassen:
    ls -alh /media/
    Das sieht bei mir so aus:
    insgesamt 0
    drwxr-xr-x.  3 root root   60  5. Dez 07:30 .
    drwxr-xr-x. 57 root root 1,5K  5. Dez 08:53 ..
    drwxr-x---+  4 root root   80  5. Dez 08:54 tux
    und jetzt weiter beim Benutzer (bei mir "tux"):
    ls -alh /media/tux/
    in meinem Fall: zwei externe Festplatten und sonst nix
    insgesamt 8,0K
    drwxr-x---+  4 root root   80  5. Dez 08:54 .
    drwxr-xr-x.  3 root root   60  5. Dez 07:30 ..
    drwxrwxrwx   1 tux  tux  4,0K 19. Nov 16:49 Daten5
    drwx------  20 tux  tux  4,0K  7. Nov 17:45 Master1
  • Steffen
    Jetzt brauchst Du nur noch herausfinden was die Sicherung ist und welche das Ziel sein soll.
    Wenn keine weitere Frage dazu, dann bitte den Thread als "gelöst" markieren.
    P.S. Ausgaben der bash bitte im Codeblock posten.
  • Jetzt brauchst Du nur noch herausfinden was die Sicherung ist und welche das Ziel sein soll.
    Welche Sicherung? Die Backup-Festplatte hängt nicht dran. Beim Backup merkte ich, daß es 2 Fehler sind (1 HD defekt, 1 HD läßt sich nicht mehr mounten). Habe die Ablage-HD gegen die defekte Interne ausgetauscht.
    Habe mir mal die UUIDs der Festplatten anzeigen lassen und festgestellt, daß die fstab Murx ist. Einträge löschen? (mache regelmäßg Timeshift)
  • die UUIDs der Festplatten anzeigen lassen und festgestellt, daß die fstab Murx ist. Einträge löschen?
    Du hast im Beitrag #11 bereits festgestellt das die Murks ist und ich in Beitrag #10 geschrieben wie Du vorgehen musst. Fazit: DU musst aktiv werden.
  • 1 HD defekt, 1 HD läßt sich nicht mehr mounten
    Ich würde vor dem Mountversuch mal in einem Terminal dmesg -W eingeben und dann die Platten anstecken. Dann bekommst du Meldungen über Lesefehler, Bad Blocks oder was auch immer. Mal mit verschiedenen USB Ports versucht? Es loiefern nicht immer alle vollen Strom.
  • Ja, das war ein super Hinweis mit der fstab. Mache es nachher, hab gerade keine Zeit (bin nicht so schnell beim denken :D).
  • Ich würde vor dem Mountversuch mal in einem Terminal dmesg -W eingeben und dann die Platten anstecken. Dann bekommst du Meldungen über Lesefehler, Bad Blocks oder was auch immer. Mal mit verschiedenen USB Ports versucht? Es loiefern nicht immer alle vollen Strom.
    Für etwaige Bad Blocks etc. hab ich mir SMART anzeigen lassen. Am USB steckt nichts. Ich hab da nur gemerkt, daß etwas faul ist. Dann hab ich die neue externe HD gegen die Interne ausgetauscht. Bearbeite mal nachher die fstab. Ich berichte dann.
  • Schonmal blkid eingegeben, um einen Überblick zu bekommen und zusehen, wo was dazu gehört? So eine fstab sieht man selten und wundert ein, wenn das System trotzdem startet.
