Wo kann man sinnvollerweise Programme unter Linux-Mint installieren?
    Kernel: 6.8.0-88-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Laptop System: Dell product: Precision M4800 v: 00
    serial: <superuser required>
    Mobo: Dell model: 0V5GVY v: A00 serial: <superuser required> UEFI: Dell
    v: A15 date: 09/29/2015
    Battery:
    ID-1: BAT0 charge: 20.0 Wh (30.6%) condition: 65.3/86.6 Wh (75.5%)
    volts: 11.1 min: 11.1 model: Samsung SDI DELL P8TC727 status: charging
    Info: quad core model: Intel Core i7-4810MQ bits: 64 type: MT MCP
    arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
    Speed (MHz): avg: 2544 high: 2794 min/max: 800/3800 cores: 1: 2794 2: 2793
    3: 2794 4: 800 5: 2794 6: 2794 7: 2793 8: 2794 bogomips: 44696
    Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
    driver: i915 v: kernel arch: Gen-7.5 bus-ID: 00:02.0
    Device-2: NVIDIA GK106GLM [Quadro K2100M] vendor: Dell driver: nouveau
    v: kernel arch: Kepler bus-ID: 01:00.0 temp: 34.0 C
    Device-3: Microdia Integrated Webcam driver: uvcvideo type: USB
    bus-ID: 1-1.5:3
    loaded: modesetting unloaded: fbdev,vesa dri: crocus gpu: i915
    resolution: 1920x1080~60Hz
    API: EGL v: 1.5 drivers: crocus,nouveau,swrast platforms:
    API: OpenGL v: 4.6 compat-v: 4.3 vendor: intel mesa
    v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel HD Graphics 4600 (HSW GT2)
    Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:03.0
    Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell 8
    Device-3: NVIDIA GK106 HDMI Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
    API: ALSA v: k6.8.0-88-generic status: kernel-api
    Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
    port: f080 bus-ID: 00:19.0
    Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
    vendor: Dell driver: wl v: kernel bus-ID: 03:00.0
    RAID:
    Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 bus-ID: 00:1f.2
    Local Storage: total: 1.6 TiB used: 1.54 TiB (96.6%)
    ID-1: /dev/sda vendor: Toshiba model: MQ01ACF050 size: 465.76 GiB
    ID-2: /dev/sdb vendor: Micron model: M600 MSATA 256GB size: 238.47 GiB
    ID-3: /dev/sdc vendor: A-Data model: SE880 size: 931.51 GiB type: USB
    ID-1: / size: 103.72 GiB used: 50.78 GiB (49.0%) fs: ext4 dev: /dev/sdc2
    ID-2: /boot/efi size: 507 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sdc1
    ID-3: /home size: 810.56 GiB used: 272.96 GiB (33.7%) fs: ext4
    dev: /dev/sdc3
    ID-1: swap-1 type: file size: 2 GiB used: 61.9 MiB (3.0%) file: /swapfile
    System Temperatures: cpu: 61.0 C mobo: 52.0 C sodimm: SODIMM C gpu: nouveau
    temp: 35.0 C
    Fan Speeds (rpm): cpu: 2084
    Memory: total: 16 GiB available: 15.52 GiB used: 8.85 GiB (57.0%)
    Processes: 357 Uptime: 1h 45m Init: systemd target: graphical (5)
    Packages: 4093 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Versuch Programme die ich installieren möchte unter Flatpack zu installieren. Leider sind nicht alle Programme darüber verfügbar.
    Wo installiert man die Programme, da es unter Linux scheinbar keine Regeln dafür gibt?
    Gruß Holger
    seit 02-2026 Linux-Mint 22.3
  • Über die Anwendungsverwaltung
    Images
    MfG Nico
    2: Intel Core i5-12450H | NVIDIA GeForce RTX 3050 | 16 GB RAM | 500 GB nvme | 256 GB SSD | 2 TB SSD --- CachyOS / Nobara 43 KDE / Mint 22.3 / GuideOS 1.0
  • Um welche Programme handelt es sich denn genau?
    System: CPU: Intel I5 14600KF , RAM: 32 GB , GPU: AMD Radeon RX7800XT, OS: Fedora 43 KDE Plasma
  • Man ruft im Menü 'Anwendungsverwaltung' auf und sucht das Programm und kann nur auf "installieren" klicken. Wenn es das Programm dort nicht gibt, dann eine DEB-Datei (von der Seite) nehmen. Gibt es die auch nicht, macht man etwas über das Terminal, aber es steht dann eine genaue Anleitung da. Ich hab mich nie gefragt, wo ich es installieren kann.
  • Für Flatpaks kann man auch in der eigenen .bashrc aliase anlegen (Beispiel)
    alias mpv='flatpak run io.mpv.Mpv'
  • also standardmäßig machst du alles über die offiziellen paketquellen und flatpaks sprich Anwendungsverwaltung, manche Hersteller bieten ihr Programm mit linux nicht über die paketquellen an, da musst du dann die quelle entsprechend hinzufügen, das wir dann meistens auf der Webseite beschrieben oder du lädst es dort als .deb datei herunter.
    Mach dir bloß klar, alle Programme die du als Systempaket sprich .deb installierst die nicht aus den offiziellen paketquellen kommen können potentiell Schadcode beinhaten, was in dem sinne gefährlich ist, da Systempakete als root installiert werden müssen und entsprechend viele rechte bekommen. Bei Flatpaks hat eine app nur die rechte die du ihr gibst, die Verwaltung läuft über das Programm Flatseal.
    Zudem gibt es noch Appimages, die lädst du einfach herunter, Rechtsklick, Eigenschaften, der datei erlauben sie als Programm auszuführen und dann einfach benutzen. Wenn du irgendwelche Fragen zu Spezialprogrammen hast melde dich einfach 👍
    MfG
    firefighterlp8
  • Hier ein sehr gutes Video dazu:
  • Stephan und aef100 ging es nicht um Flatpak? Appimage wäre dann wieder was anders. Es ist nicht gut HKaufmann noch mehr durcheinander zubringen. Seine Anfragen sind immer sehr schwierig, da er selten oder sehr spät seine Ausgangsfrage konkretisiert und man selber nur Rätseln kann was er wirklich will.
  • ging es nicht um Flatpak?
    Meiner Meinung nach hat er gefragt wie man Software sonst noch istallieren kann, weil nicht alles unter Flatpack zu finden ist.
    Es geht um BentiPDF. An sich ist es egal welches Programm. Jedes Programm was man manuell runterladen muß und entpackt muß irgenwo hin.
  • oder...Ordner anlegen und App-Images nutzen.
    Darum geht es . Wo soll der Ordner angelegt werden? Unter Wimdows gibte es zwei Hauptordner.
  • Meiner Meinung nach hat er gefragt wie man Software sonst noch istallieren kann, weil nicht alles unter Flatpack zu finden ist.
    Es geht um Programme die weder unter der Anwendungsverwaltung , Flatpak oder AppImage es gibt. Das Video ist klasse.
  • die weder unter der Anwendungsverwaltung , Flatpak oder AppImage es gibt
    Alles nicht oben genannte liegt bei mir in einem seperaten Ordner:
    Und gestartet werden diese per alias in der Konsole (Beispiel):
    alias yt='/home/tux/Programme/yt-dlp -o "%(title)s.%(ext)s"'
    Wozu dann ein extra Starter oder Eintrag in das Menü der Programme?
  • Es geht um BentiPDF. An sich ist es egal welches Programm. Jedes Programm was man manuell runterladen muß und entpackt muß irgenwo hin.
    Bevor du unter Linux irgendwas irgendwo runterlädst und installiert, immer zuerst schauen ob es in den Repos drinnen ist und dann über die Anwendungsverwalttung installieren.
  • Das läuft aber nur im Browser soweit ich weiß. Ich finde da keine lokale Installation
    MfG Nico
