- Distrowahl
- Linux Mint
- inxi -Fzxi
Kernel: 6.14.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Mini-pc System: Micro (HK) Tech product: EliteMini Series v: N/A
serial: <superuser required>
Mobo: Shenzhen Meigao Equipment model: TNBOE serial: <superuser required>
UEFI: American Megatrends LLC. v: DNB20T V1.01 date: 01/06/2025
Info: quad core model: Intel N150 bits: 64 type: MCP arch: Alder Lake rev: 0
cache: L1: 384 KiB L2: 2 MiB L3: 6 MiB
Speed (MHz): avg: 750 high: 899 min/max: 700/3600 cores: 1: 700 2: 700
3: 899 4: 702 bogomips: 6451
Device-1: Intel Alder Lake-N [Intel Graphics] driver: i915 v: kernel
arch: Gen-12.2 bus-ID: 00:02.0
Device-2: Logitech Webcam C270 driver: snd-usb-audio,uvcvideo type: USB
bus-ID: 3-3.2:10
resolution: 1280x1024~60Hz
v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel Graphics (ADL-N)
Device-1: Intel Alder Lake-N PCH High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3
bus-ID: 3-3.2:10
API: ALSA v: k6.14.0-35-generic status: kernel-api
Device-1: Intel CNVi: Wi-Fi driver: iwlwifi v: kernel bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac: <filter>
Device-2: Intel Ethernet I226-V driver: igc v: kernel port: N/A
bus-ID: 01:00.0
IF: enp1s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 3-10:7
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 2.29 TiB used: 858.61 GiB (36.7%)
ID-1: /dev/nvme0n1 model: HighRel 512GB SSD size: 476.94 GiB temp: 33.9 C
ID-2: /dev/sda vendor: Toshiba model: MQ04UBD200 size: 1.82 TiB type: USB
ID-1: / size: 412.26 GiB used: 166.84 GiB (40.5%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 62.6 MiB (65.2%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.36 GiB used: 3.48 GiB (22.6%)
Processes: 258 Uptime: 27m Init: systemd target: graphical (5)
Packages: 2705 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Auf diesem LinuxMint Desktop gelingt es mir nicht, dass mein Bluetooth-Lautsprecher (Icybox IB-SP001-BT) erkannt wird. Ich habe bisher kaum Erfahrung mit bluetooth, am Smartphone wird der Lautsprecher jedoch problemlos erkannt. Ich habe schon viel im Netz gesucht nach Lösungen - ohne Erfolg. Ein anderer Lautsprecher, der mit Klinkenstecker verbunden wird, gibt Audios vom PC problemlos wieder.
Ich gehe wie folgt vor: ich schalte den Bluetooth Lautsprecher ein, stelle ihn auf den Desktop, schalte am PC die Bluetooth-Einstellungen ein, klicke auf "suche" - nichts passiert. Irgendwann vor ein paar Tagen wurde der Lautsprecher mal kurz für 1 sec erkannt, dann war er wieder weg.
Ich habe eben am Terminal noch dies probiert:
bluetoothctl
Waiting to connect to bluetoothd...[bluetooth]# Agent registered
[bluetooth]# scan on
[bluetooth]# SetDiscoveryFilter success
[bluetooth]# Discovery started
[bluetooth]# [CHG] Controller C8:58:B3:BE:3C:59 Discovering: yes
ist die angezeigte MAC-Adresse die von meinem BluetootLautsprecher? In jedem Fall gibt der Lautsprecher keinen Ton aus. (und wie gesagt: am Smartphone tut er das).
Hat jemand eine Idee dazu?
