Kein Desktop im LM-Cinnamon-Live-Modus mit UHD-Monitor
    Kernel: 6.14.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Mobo: ASUSTeK model: PRIME B650-PLUS v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 3287
    date: 09/20/2025
    Info: 12-core model: AMD Ryzen 9 9900X3D bits: 64 type: MT MCP MCM arch: N/A
    rev: 0 cache: L1: 960 KiB L2: 12 MiB L3: 128 MiB
    Speed (MHz): avg: 852 high: 3618 min/max: 600/5575 boost: enabled cores:
    1: 604 2: 604 3: 604 4: 604 5: 604 6: 604 7: 3618 8: 604 9: 604 10: 604
    11: 604 12: 3557 13: 604 14: 604 15: 604 16: 604 17: 604 18: 604 19: 604
    20: 604 21: 604 22: 604 23: 604 24: 604 bogomips: 210789
    Device-1: AMD vendor: Tul / PowerColor driver: amdgpu v: kernel
    bus-ID: 03:00.0
    loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
    gpu: amdgpu resolution: 3840x2160~144Hz
    Radeon Graphics (radeonsi gfx1200 LLVM 20.1.2 DRM 3.61 6.14.0-35-generic)
    Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0f:00.6
    API: ALSA v: k6.14.0-35-generic status: kernel-api
    Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    port: e000 bus-ID: 0a:00.0
    Local Storage: total: 2.79 TiB used: 137.22 GiB (4.8%)
    ID-1: /dev/nvme0n1 vendor: HP model: SSD FX900 Pro M.2 2TB size: 1.86 TiB
    temp: 34.9 C
    ID-2: /dev/nvme1n1 vendor: HP model: SSD EX920 1TB size: 953.87 GiB
    temp: 16.9 C
    ID-1: / size: 1.83 TiB used: 123.51 GiB (6.6%) fs: ext4 dev: /dev/nvme0n1p2
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 41.1 C mobo: 36.2 C gpu: amdgpu temp: 51.0 C
    Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
    Memory: total: 64 GiB available: 62.45 GiB used: 3.81 GiB (6.1%)
    Processes: 435 Uptime: 21m Init: systemd target: graphical (5)
    Packages: 2363 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Aufgrund dieses Threads eröffne ich ein neues Thema: Eintrag "Desktop" in den Systemeinstellungen fehlt
    Die Hardware nochmal kompakt: Mainboard ASUS PRIME B650-PLUS, CPU AMD Ryzen 9 9900X3D, Grafik RX 9600 XT.
    Wenn ich mit dieser Hardware mit dem Cinnamon-Installations-Stick versuche normal zu booten, komme ich nur bis zum LM-Zeichen, der Hintergrund wird etwas heller und das war's. Mit dem Kompatibilitäts-Modus komme ich auf den Desktop (mit geringer Auflösung natürlich) und kann Cinnamon installieren.
    Nach dem Reboot komme ich auch nicht auf den Desktop, sodass ich erst mal mit den Advanced-Options booten muss, kaputte Pakete (direkt nach der Neuinstallation?) reparieren muss (da wird dann einiges gemacht) und dann komme ich mit UHD auf den Desktop. Aber in der Installation wird entweder die integrierte Grafik verwendet oder sogar Software-Rendering (wenn ich die iGPU im UEFI deaktiviert habe).
    Ich habe den Stick auf einem älterem AM4-Board (CPU hat keine integrierte Grafik) von Biostar X570 GT8 mit einer nvidia GTX 1070 getestet, dort geht das mit UHD. Der Stick funktioniert also prinzipiell einwandfrei.
    Die Frage: Warum hakt es mit der aktuellen Hardware. Sie ist ja auch nicht mehr brandneu, dass man die Fehlfunktion darauf schieben könnte. Im UEFI kann ich übrigens einstellen, was ich will. Es klappt nie. Wenn ich die Onboard-Grafik ausschalte, komme ich auch nur bis zum LM-Zeichen. Es ist nur mit Cinnamon, erstelle ich einen Stick mit MATE, XFCE oder Fedora, gibt es das Problem nicht.
    Wenn ich wüsste, wie ich sauber installieren kann, würde ich das sogar nochmal machen. Ich hatte von KI eine Datei 20-amdgpu.conf * erstellen lassen, die erzwingt, dass die Grafikkarte verwendet wird. Das funktioniert soweit, dass die Grafikkarte auch verwendet wird. Aber die kaputte Installation ging natürlich voraus, also hilft das auch nur bedingt, oder nicht? Jetzt ist die Datei nicht mehr drauf, da der Unterbau MATE ist, was aber auch suboptimal ist, wie ich feststellen musste...
    Section "Device"
    Identifier "AMD GPU"
    Driver "amdgpu"
    BusID "PCI:3:0:0"
    xrandr
    EndSection
  • Meiner Meinung nach keine gute Idee. Denn Mate ist ein Fork von Gnome 2.x und Cinnamon ein Fork von Gmome 3.x ... Das gibt ein Kuddel-Muddel in gemeinsam genutzten Konfigurationsdateien.
    Mein Rat: Entscheide Dich für einen Desktop und bleibe dabei.
    Damit würde sich dein Problem wohl lösen.
  • So wie ich den TE verstehe, geht es hier um eine Sitzung mit einer vom USB-Stick gestarteten Live-Version von LM 22.2 mit Cinnamon .... ?
    Hardware
