Eintrag "Desktop" in den Systemeinstellungen fehlt
    Linux Mint
    Kernel: 6.14.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Mobo: ASUSTeK model: PRIME B650-PLUS v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 3287
    date: 09/20/2025
    Info: 12-core model: AMD Ryzen 9 9900X3D bits: 64 type: MT MCP MCM arch: N/A
    rev: 0 cache: L1: 960 KiB L2: 12 MiB L3: 128 MiB
    Speed (MHz): avg: 985 high: 3852 min/max: 600/5575 boost: enabled cores:
    1: 604 2: 604 3: 604 4: 604 5: 604 6: 604 7: 604 8: 604 9: 604 10: 604
    11: 3852 12: 604 13: 604 14: 604 15: 604 16: 604 17: 604 18: 604 19: 604
    20: 604 21: 3618 22: 604 23: 604 24: 3490 bogomips: 210790
    Device-1: AMD vendor: Tul / PowerColor driver: amdgpu v: kernel
    bus-ID: 03:00.0
    loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
    gpu: amdgpu resolution: 3840x2160~144Hz
    Radeon Graphics (radeonsi gfx1200 LLVM 20.1.2 DRM 3.61 6.14.0-35-generic)
    Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0f:00.6
    API: ALSA v: k6.14.0-35-generic status: kernel-api
    Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    port: e000 bus-ID: 0a:00.0
    Local Storage: total: 2.79 TiB used: 137.13 GiB (4.8%)
    ID-1: /dev/nvme0n1 vendor: HP model: SSD FX900 Pro M.2 2TB size: 1.86 TiB
    temp: 34.9 C
    ID-2: /dev/nvme1n1 vendor: HP model: SSD EX920 1TB size: 953.87 GiB
    temp: 20.9 C
    ID-1: / size: 1.83 TiB used: 123.41 GiB (6.6%) fs: ext4 dev: /dev/nvme0n1p2
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 40.8 C mobo: 36.5 C gpu: amdgpu temp: 51.0 C
    Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
    Memory: total: 64 GiB available: 62.45 GiB used: 2.92 GiB (4.7%)
    Processes: 416 Uptime: 16m Init: systemd target: graphical (5)
    Packages: 2362 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo.
    Nachdem ich endlich alles eingerichtet habe, nachdem ich hier gescheitert bin: RTX 2070 Super gegen eine RT 9060 XT getauscht. Leistung enttäuscht => MATE
    Ich hatte dort nicht mehr geschrieben, dass ich neu mit MATE installiert habe.
    Jedenfalls gefiel mir dieses nicht so und um die ganzen Scherereien der Cinnamon-Neuinstallation zu umgehen, habe ich dann unter MATE den Cinnamon-Desktop nachinstalliert. nicht ideal, aber es läuft soweit alles, was ich will.
    Nur eine Sache: In den Systemeinstellungen habe ich seltsamerweise keinen Eintrag für Desktop, also wo man u.a. die angezeigten Symbole auf dem Schreibtisch festlegen kann. Ist kein Beinbruch, aber den Papierkorb hätte ich schon gerne dort gesehen.
    Habe mir einen anderen per Verknüpfung gebastelt, aber der funktioniert nur "halb", weil das Icon nicht wechselt, außerdem kein Kontextmenü zum Leeren bietet.
    Gibt es eine Möglichkeit, wie ich den Eintrag in den Systemeinstellungen wieder her bekommen, ohne neu Aufsetzen von Linux?
  • hast du den eintrag in der user-dirs.dirs angepasst, die ist üblicherweise im $HOME/.config/ verzeichnis und ich könnte mir gut vorstellen, dass das bei dir verstellt ist irgendwie
    viele Grüße aus dem Norden
  • Hallo torsten.breswald
    Die Datei habe ich und der Desktop-Eintrag ist drin. Es sieht so aus, als würde dort geregelt, welche User-Ordner du siehst.
    Eine Datei wird es sein, wo man das einstellen kann. Aber ich schätze, eher *irgendwo* im Dateisystem.
  • Im Startmenü unter Einstellungen ist "Schreibtisch" auch nicht zu finden? Dann schau mal im Verzeichnis usr/share/applications, ob dort "Schreibtisch" vorhanden ist. Falls ja, kannst du es mit Doppelklick starten. Man müsste dann mal schauen, ob mit der Datei etwas nicht stimmt. Falls nicht, ist sie wohl irgendwie gelöscht worden und muss wiederhergestellt werden.
    Ansonsten kannst du die Schreibtischeinstellungen auch aus der Shell aufrufen mit
    cinnamon-settings desktop
    Natürlich kannst du dir auch einen Starter auf dem Desktop mit dem Befehl anlegen.
  • Die cinnamon-settings desktop ist vorhanden. Klicke ich sie doppelt, öffnet sich Systemeinstellungen -- aber eben ohne den Menüpunkt "Schreibtisch". Öffne sie mit einem Texteditor, steht da in der Hauptsache drin:
    [Desktop Entry]
    Icon=cs-desktop
    Exec=cinnamon-settings desktop
    Type=Application
    OnlyShowIn=X-Cinnamon;
    Categories=Settings;
    Name=Desktop ...
    Es kommt noch mehr, aber nur Name und Comment in verschiedenen Sprachen. Ich müsste (später) mal den Installationsstick booten und mir dort den Inhalt ansehen. Ich denke aber nicht, dass in der Datei was zu holen ist, dafür steht zu wenig drin, außer es fehlt die Hälfte...
    Edit: Habe gerade auf einem anderen Rechner Cinnamon vom Stick gebootet, da ist in der Datei auch nicht mehr enthalten. Aber die Einstellungen haben dort einen Eintrag "Desktop", auch in Deutsch. Aver von dem Stick habe ich ja nicht installiert, sondern vom MATE-Stick. Unter MATE ist der Eintrag auch vorhanden.
    Ich schätze mal, das ist eine Nebenwirkung vom Cinnamon nachinstallieren...
    Edited once, last by udo (November 15, 2025 at 10:54 AM).
  • Wenn es dir erst einmal nur um eine schnelle Lösung für das Papierkorbsymbol geht, kannst du das im Terminal mit
    gsettings set org.nemo.desktop trash-icon-visible true
    aktivieren. Du kannst auch den dconf-editor installieren und das damit grafisch erledigen.
  • habe ich dann unter MATE den Cinnamon-Desktop nachinstalliert
    Meiner Meinung nach keine gute Idee. Denn Mate ist ein Fork von Gnome 2.x und Cinnamon ein Fork von Gmome 3.x ... Das gibt ein Kuddel-Muddel in gemeinsam genutzten Konfigurationsdateien.
    Mein Rat: Entscheide Dich für einen Desktop und bleibe dabei.
    Hardware
  • O.K.
    Was früher einmal der Ordner "Desktop" in /home war, ist schon lange der Ordner "Schreibtisch".
    Wenn Du das ändern willst musst Du die "dirs" entsprechend ändern
    Hier mal die von Fedora, sollte bei Dir auch so aussehen:
  • Das hat funktioniert. Zuvor habe ich mir im dconf-Editor schon einen Wolf gesucht.
    Ein Gschmäckle bleibt natürlich: Ist es das einzige, das fehlt? Sehe ich freilich ja erst im Lauf der Zeit. Warum fehlt ausgerechnet dieser Menüpunkt (dieser Menüpunkt allen gesehen ist rel. unwichtig, wenn man die fraglichen Symbole mit dem Befehl einschalten kann). Hat die Nachinstallation nicht richtig funktioniert).
    Der Systemmonitor z.B. fehlt auch, habe mir den Taskmanager nachinstalliert. Alles kein Problem. Aber die Frage ist, habe ich im Prinzip ein beschädigtes System (unvollständig sowieso) , obwohl scheinbar alles perfekt funktioniert und sind es nur "die paar fehlenden Dinge"?
    Würde ich ja gerne machen. Aber ich habe ein Riesentheater mit der direkten Cinnamon-Installation gehabt, wegen der AMD-Grafikkarte + integrierter AMD-Grafik. Mit einem UHD-Monitor hatte ich keine Chance, auf den Desktop zu gelangen. Mit XFCE und MATE kein Problem. Gut, dachte ich, installierst du MATE, so unterschiedlich sieht das ja auf der Mint-Homepage nicht aus. Pustekuchen, gefiel mir nicht. Mit einer nvidia war die Cinnamon-Installation uch nicht reibungslos und ich musste im Kompatibilitätsmodus installieren, aber der proprietäre Treiber hat es wieder rausgerissen. Unter "komplett" AMD wurde immer die integrierte Grafik verwendet. Daran bin ich verzweifelt.
    Edited once, last by udo (November 15, 2025 at 12:01 PM).
  • Hast du vielleicht nur "Cinnamon" installiert? Richtig wäre nämlich "Mint-meta-cinnamon".
    Ansonsten kannst du mal einen neuen User anlegen und gucken, ob da auch "Schreibtisch" in den Systemeinstellungen fehlt. Falls nicht, ist in deiner Userkonfiguration etwas kaputt. Falls es dort auch fehlt, kannst du die relevanten Pakete mit
    sudo apt install --reinstall cinnamon-settings-daemon cinnamon-control-center nemo
    noch einmal installieren und anschließend neu starten.
  • Mit einem neuen User ist das auch kaputt. Ja ich habe nur sudo apt install cinnamon ausgeführt. Das war also der Haken an der Sache? Ich werde deinen Vorschlag gleich mal testen. Erst mal einen Snapshot erstellen...
    Edit: Habe den Befehl ausgeführt, aber der Menüpunkt fehlt weiterhin. Aber egal, vielleicht entscheide ich mich ja trotzdem noch dazu, Cinnamon direkt zu installieren. Dazu müsste ich nur wissen, wie das mit UHD ohne Kompatibilitätsmodus funktioniert. Ohne komme ich im Live-Modus nämlich nur bis zum Mint-Zeichen, aber nicht auf den Desktop, um LM zu installieren...
    Wenn sich das Thema "eintrag-desktop-in-den-systemeinstellungen-fehlt" erledigt hat, dann erstelle bitte einen neuen Thread. Danke. und das "gelöst" auch noch markieren
  • unameDer Grund, weswegen ich den Menüpunkt vermisste, wurde mit dem Workaround umgangen, die Ursache ist noch nicht beseitigt. Warum soll einen neuen Thread erstellen? Mit der gleichen Frage?
  • Warum soll einen neuen Thread erstellen? Mit der gleichen Frage?
    Nein, mit der Frage:
    „Viele Leute glauben zu denken, dabei ordnen sie lediglich ihre Vorurteile neu." (William James)
    „Toleranz ist gut, aber nicht gegenüber den Intoleranten.“ ( Wilhelm Busch)
  • Ja, da kann ich nur das Icon-Raster einstellen. Und wenn ich unten auf Schreibtisch-Einstellungen klicke, komme ich auf die Systemeinstellungen, wo der Menüpunkt fehlt...
    Da ich einen neuen Thread eröffnet habe, bitte ich euch, dort weitermachen. Dort erfrage ich die Ursache, warum ich so viele Schwierigkeiten mit Cinnamon habe:
    udo
    November 15, 2025 at 12:56 PM
