- Distrowahl
- Linux Mint
- System:
Kernel: 6.14.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: Micro-Star model: B450M PRO-VDH MAX (MS-7A38) v: 8.0
serial: <superuser required> UEFI: American Megatrends v: B.A0
date: 11/26/2020
Info: 6-core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 32 MiB
Speed (MHz): avg: 2316 high: 3600 min/max: 2200/4208 boost: enabled cores:
1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 3600
10: 2200 11: 2200 12: 2200 bogomips: 86395
Device-1: NVIDIA TU116 [GeForce GTX 1660 SUPER] driver: nvidia v: 580.95.05
arch: Turing bus-ID: 29:00.0
gpu: nv_platform,nvidia,nvidia-nvswitch resolution: 1920x1080~144Hz
API: EGL v: 1.5 drivers: nouveau,nvidia,swrast platforms:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1660
SUPER/PCIe/SSE2
Device-1: NVIDIA TU116 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 29:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 2b:00.4
Device-3: Corsair HS65 SURROUND driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-1:2
API: ALSA v: k6.14.0-35-generic status: kernel-api
vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel port: f000
bus-ID: 25:00.0
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-dc074b1b16bb state: down mac: <filter>
IP v4: <filter> scope: global
IF-ID-2: docker0 state: down mac: <filter>
Local Storage: total: 953.87 GiB used: 184.36 GiB (19.3%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW010T9 size: 953.87 GiB
temp: 36.9 C
ID-1: / size: 937.73 GiB used: 184.31 GiB (19.7%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 55.6 MiB (57.9%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 46.1 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 16 GiB available: 15.54 GiB used: 3.09 GiB (19.9%)
Processes: 346 Uptime: 18m Init: systemd target: graphical (5)
Packages: 2933 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hi,
ich habe auf meinem System Dinge installiert/ausprobiert, die am Ende doch nicht funktioniert haben oder mir nicht gefielen. (Zum Beispiel Fusion 360 über wine (hat schon bei der installation nicht funktioniert) oder KDE-Plasma-Desktop (hat funktioniert, aber cinnamon gefiel mir dann doch besser)).
Ich habe diese dann versucht zu deinstallieren. Mit remove, purge und autoremove natürlich. Und auch mit allen möglichen bezeichnungen, die die Programme haben könnten. Aber ich finde von all den deinstallierten programmen immer noch überreste im System.
Wenn die nur in den config files sind, kann ich die auch manuell löschen, klar. Aber die genannten Programme haben auch tiefer im System Spuren hinterlassen und das wird dann schon ganz schön aufwendig, die alle einzeln mit dem Terminal und sudo zu löschen. Und wenn ich da ausversehen die falsche Datei lösche (weil ich halt auch nicht alle Systemdatein kenne), kann das auch ordentlich schief gehen.
Wie kann ich also diese Remnants löschen?
Klar, Timeshift ist ne Option, aber da wird auch vieles wieder her gestellt, was ich nicht haben will (da stand auch was mit microsoft? Vielleicht, weil ich am Anfang noch mit Windows gedualbootet habe? Stellt Timeshift alte Partitionen anderer Systeme wieder her?) und sehr viele kryptisch aussehende Datein.
So ganz geheuer ist mir das auch nicht.
Gibt es da irgendwas, was man machen kann, oder ist der Ultima Ratio, eine Neuistallation von Mint, der einzige Ausweg?
