mad@mad-ThinkStation-S30:~$ inxi -Fzxi
Kernel: 6.14.0-35-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop System: LENOVO product: 4351D2G v: ThinkStation S30
serial: <superuser required>
Mobo: LENOVO model: LENOVO v: 0B98401 PRO serial: <superuser required>
UEFI: LENOVO v: A2KT45AUS date: 05/21/2014
Battery:
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400 Plus
charge: 100% (should be ignored) status: discharging
Device-2: hidpp_battery_1 model: Logitech MX Keys Wireless Keyboard
Info: 10-core model: Intel Xeon E5-2690 v2 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 4 cache: L1: 640 KiB L2: 2.5 MiB L3: 25 MiB
Speed (MHz): avg: 1320 high: 2400 min/max: 1200/3600 cores: 1: 1200
2: 1200 3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200
11: 1200 12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 17: 2400 18: 1200
19: 1200 20: 2400 bogomips: 120003
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP104GL [Quadro P4000] driver: nvidia v: 580.95.05
arch: Pascal bus-ID: 03:00.0
gpu: nvidia,nvidia-nvswitch resolution: 3840x2160~60Hz
API: EGL v: 1.5 drivers: nouveau,nvidia,swrast platforms:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: Quadro P4000/PCIe/SSE2
Device-1: Intel C600/X79 series High Definition Audio vendor: Lenovo
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1
API: ALSA v: k6.14.0-35-generic status: kernel-api
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8852be v: kernel port: c000 bus-ID: 06:00.0
IF: wlp6s0 state: up mac: <filter>
Bluetooth:
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 4-1.1:3
lmp-v: 12
Local Storage: total: 4.09 TiB used: 2.3 TiB (56.3%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
ID-2: /dev/sdb vendor: Seagate model: ST4000VN008-2DR166 size: 3.64 TiB
ID-1: / size: 456.89 GiB used: 104.47 GiB (22.9%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 29.0 C mobo: N/A gpu: nvidia temp: 34 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 46%
Memory: total: 64 GiB available: 62.71 GiB used: 2.16 GiB (3.4%)
Processes: 404 Uptime: 13m Init: systemd target: graphical (5)
Packages: 2755 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Display More
Guten Tag,
Meine Bluetooth Maus möchte nicht mehr arbeiten.
Es handelt sich um eine "Logitech M720 Triathlon"
Also ein Gerät, welches ich durch Tastendruck zwischen drei Rechnern umscharten kann.
An meinen stationären PC will sie nicht mehr.
Die anderen beiden (Thinkpad mit LM / Arbeitslaptop Win11) funktioniernen.
Ich habe verucht neu zu koppeln. Er erkennt sie, aber die Maus blinkt weiterhin im Koppelmodus, obwohr das BT Tool behauptet sie wäre gekoppelt.
Kann man das irgendwie resetten?
BT an sich funktioniert z.B. mit Lautsprecher.
