- Distrowahl
- Ubuntu
- System:
Kernel: 6.14.0-34-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
Desktop: KDE Plasma v: 5.27.12 Distro: Kubuntu 24.04.3 LTS (Noble Numbat)
base: Ubuntu
Type: Desktop Mobo: Gigabyte model: Z270-Gaming K3 v: x.x
serial: <superuser required> UEFI: American Megatrends v: F8
date: 07/06/2017
Info: quad core model: Intel Core i7-7700 bits: 64 type: MT MCP
arch: Kaby Lake rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 800 min/max: 800/4200 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 57600
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] vendor: Gigabyte
driver: nvidia v: 580.95.05 arch: Pascal bus-ID: 01:00.0
gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nouveau,nvidia,swrast platforms:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
Device-2: NVIDIA GP106 High Definition Audio vendor: Gigabyte
API: ALSA v: k6.14.0-34-generic status: kernel-api
Server-1: JACK v: 1.9.21 status: off
Server-2: PipeWire v: 1.0.5 status: active
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: d000 bus-ID: 06:00.0
IF: enp6s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter driver: ath9k
v: kernel bus-ID: 0b:00.0
IF: wlp11s0 state: up mac: <filter>
Local Storage: total: 2.73 TiB used: 123.12 GiB (4.4%)
ID-1: /dev/sda vendor: Seagate model: ST2000NT001-3M3101 size: 1.82 TiB
ID-2: /dev/sdb vendor: Western Digital model: WD10EZEX-00BBHA0
ID-1: / size: 389.24 GiB used: 123.11 GiB (31.6%) fs: ext4 dev: /dev/sdb3
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sdb1
ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) file: /swap.img
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 51 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.3 GiB used: 2.57 GiB (8.2%)
Processes: 316 Uptime: 24m Init: systemd target: graphical (5)
Packages: 3515 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo zusammen,
ich habe mal eine generelle Frage.
Ich bin im August von Windows 10 zu Linux gewechselt. Ich habe Mint und Ubuntu Studio installiert, bin aber häufiger auf Ubuntu unterwegs. Ich habe insg. 3 Festplatten in meinem Computer:
* System 1: Linux mit dem linux-eigenen Dateisystem (1 Partition mit Mint, 1 mit Ubuntu)
* Datenfestplatte (im NTFS Format, damit ich noch weiter von Win zugreifen kann)
* System 2: Windows 10 (vom Strom abgeklemmt, wird nur angeschlossen, wenn ich mal da rein muss)
* Und dann habe ich noch zwei Festplatten in externen Gehäusen über USB. Die Dateisysteme sind da ebenfalls NTFS.
Heute ist Ubuntu beim Versuch, das erfolgreich abgeschlossene Backup von letzter Woche fortzuführen, 2x eingefroren (ich hatte letztes Wochenende von allen meinen Verzeichnissen das erste Mal mit Grsync ein Full-Backup auf meine USB-Backupplatte (ebenfalls NTFS) gemacht und wollte den "Job" heute nochmal ausführen, obwohl sich an meinen Dateien nicht viel geändert hat). Sämtliche Affengriffe funktionieren in dem Moment nicht. Am Ende ging nur noch ein Hard Reset...
Beim ersten Mal hatte ich Glück: sowohl die interne Festplatte als auch die externe USB Festplatte konnten ohne Probleme wieder eingehängt werden. Dann fror es beim zweiten Versuch wieder ein (obwohl es nur ein "dry run" war) und wieder reagierte nichts. Also wieder Hard Reset...
Dieses Mal konnte ich die Platten weder in Mint noch in Ubuntu einhängen. Ich bin also über Windows rein, dort konnte die Datenfestplatte wieder geöffnet werden, aber die Backupplatte musste repariert werden.
Mal abgesehen von meiner Angst, durch solche Aktionen irgendwann mal wirklich was zu schrotten - ich verliere an einem Sonntag wie heute und auch schon letzte Woche unfassbar viele Stunden. Ich fühle mich extrem unsicher, wenn ich jedes Mal so Probleme mit Backups kriege. Am Ende bin ich wieder in Windows und mache da mein Backup, weil es da zu 100 % funktioniert und auch noch nie Probleme gab.
Ich könnte das Backup noch einmal aus Mint probieren (falls Ubuntu das Problem sein sollte), aber ehrlich gesagt traue ich mich das gerade nicht mehr.
Meine Fragen, die ich habe:
* Gibt es irgendwelche sanfteren Methoden, wenn es zu diesen Freezes kommt?
* Ist ein Linux-Dateisystem weniger anfällig für Datenverlust/Dateisystemfehler nach Abstürzen als NTFS? Oder sind da alle gleich?
* Stellt es ein so großes Problem dar, wenn ich über Linux mit den beiden NTFS-Platten arbeite/Backups mache?
* An einem Backup-Programm ist mir wichtig, dass die Methode "Differenziell" ist. Das habe ich in Grsync gefunden. Ausserdem finde ich es auch ganz nett, dass direkt Dateien/Ordner kopiert werden und keine Imagedateien o. Ä. erstellt werden. Gibt es ein anderes, besseres Programm für mein Vorhaben?
Vielen Dank im Voraus für eure Hilfe.
