Steam: Nichts geht mehr...
  • steam.sh[57934]: Running Steam on fedora 43 64-bit
    steam.sh[57934]: STEAM_RUNTIME is enabled automatically
    setup.sh[57987]: Steam runtime environment up-to-date!
    steam.sh[57934]: Log already open
    steam.sh[57934]: Steam client's requirements are satisfied
    CProcessEnvironmentManager is ready, 6 preallocated environment variables.
    [2025-11-23 15:54:39] Startup - updater built Nov 22 2025 07:00:25
    [2025-11-23 15:54:39] Startup - Steam Client launched with: '/home/peter/.local/share/Steam/ubuntu12_32/steam' '-srt-logger-opened'
    11/23 15:54:39 minidumps folder is set to /tmp/dumps
    11/23 15:54:39 Init: Installing breakpad exception handler for appid(steam)/version(1763795278)/tid(58038)
    [2025-11-23 15:54:39] Process started with command-line: '/home/peter/.local/share/Steam/ubuntu12_32/steam' '-child-update-ui' '-child-update-ui-socket' '8' '-srt-logger-opened'
    [2025-11-23 15:54:39] Using update UI: console
    11/23 15:54:39 Init: Installing breakpad exception handler for appid(steam)/version(0)/tid(58039)
    [2025-11-23 15:54:39] Create window
    [2025-11-23 15:54:39] Loading cached metrics from disk (/home/peter/.local/share/Steam/package/steam_client_metrics.bin)
    [2025-11-23 15:54:39] Using the following download hosts for Public, Realm steamglobal
    [2025-11-23 15:54:39] 1. https://client-update.fastly.steamstatic.com, /, Realm 'steamglobal', weight was 900, source = 'update_hosts_cached.vdf'
    [2025-11-23 15:54:39] 2. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 400, source = 'update_hosts_cached.vdf'
    [2025-11-23 15:54:39] 3. https://client-update.steamstatic.com, /, Realm 'steamglobal', weight was 1, source = 'baked in'
    [2025-11-23 15:54:39] Installation wird überprüft …
    [2025-11-23 15:54:39] Verifying file sizes only
    [2025-11-23 15:54:39] Set percent complete: 0
    [2025-11-23 15:54:39] Set percent complete: -1
    [2025-11-23 15:54:39] Set status message: Installation wird überprüft …
    [----] Installation wird überprüft …
    [2025-11-23 15:54:39] Verification complete
    UpdateUI: skip show logo
    [2025-11-23 15:54:39] Destroy window
    Steam logging initialized: directory: /home/peter/.local/share/Steam/logs
    [2025-11-23 15:54:39] ProcessNextMessage: socket disconnected
    [2025-11-23 15:54:39] No more messages are expected - exiting
    XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xf5fdd090
    XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xf5fdb800
    11/23 15:54:40 minidumps folder is set to /tmp/dumps
    11/23 15:54:40 Init: Installing breakpad exception handler for appid(steamsysinfo)/version(1763795278)/tid(58062)
    Running query: 1 - GpuTopology
    WARNING: radv is not a conformant Vulkan implementation, testing use only.
    Response: gpu_topology {
    gpus {
    name: "AMD Radeon RX 9070 (RADV GFX1201)"
    vram_size_bytes: 17095983104
    driver_id: k_EGpuDriverId_MesaRadv
    driver_version_major: 25
    driver_version_minor: 2
    driver_version_patch: 7
    luid: 0
    gpus {
    name: "llvmpipe (LLVM 21.1.5, 256 bits)"
    vram_size_bytes: 3221225472
    driver_id: k_EGpuDriverId_MesaLLVMPipe
    luid: 0
    default_gpu_id: 1
    Exit code: 0
    Saving response to: /tmp/steampFNdPO - 113 bytes
    steamwebhelper.sh[58079]: Starting steamwebhelper under bootstrap steamrt steam runtime via: /home/peter/.local/share/Steam/steamrt64/steam-runtime-steamrt/_v2-entry-point
    steamwebhelper.sh[58079]: Starting steamwebhelper with steamrt steam runtime at /home/peter/.local/share/Steam/steamrt64/steam-runtime-steamrt/_v2-entry-point
    Steam Runtime Launch Service: starting steam-runtime-launcher-service
    Steam Runtime Launch Service: steam-runtime-launcher-service is running pid 58186
    bus_name=com.steampowered.PressureVessel.LaunchAlongsideSteam
    exec ./steamwebhelper -nocrashdialog -lang=de_DE -cachedir=/home/peter/.local/share/Steam/config/htmlcache -steampid=58038 -buildid=1763795278 -steamid=0 -logdir=/home/peter/.local/share/Steam/logs -uimode=7 -startcount=0 -steamuniverse=Public -realm=Global -clientui=/home/peter/.local/share/Steam/clientui -steampath=/home/peter/.local/share/Steam/ubuntu12_32/steam -launcher=0 --valve-initial-threadpool-size=4 --valve-enable-site-isolation --enable-smooth-scrolling --password-store=basic --log-file=/home/peter/.local/share/Steam/logs/cef_log.txt --disable-quick-menu --disable-component-update --gaia-url=http://disabled.invalid --enable-features=PlatformHEVCDecoderSupport --disable-features=WinRetrieveSuggestionsOnlyOnDemand,SpareRendererForSitePerProcess,DcheckIsFatal,BlockPromptsIfIgnoredOften,ValveFFmpegAllowLowDelayHEVC
    Desktop state changed: desktop: { pos: 0, 0 size: 3440,1440 } primary: { pos: 0, 0 size: 3440,1440 }
    Caching cursor image for default, size 32x32, serial 267, cache size = 0
    sh: Zeile 1: lsb_release: Kommando nicht gefunden
    WARNING: Glycin running without sandbox.
    reaping pid: 58039 -- steam
    [2025-11-23 15:56:40] Background update loop checking for update. . .
    [2025-11-23 15:56:40] Suche nach verfügbaren Updates …
    [2025-11-23 15:56:40] Downloading manifest: https://client-update.fastly.steamstatic.com/steam_client_ubuntu12
    [2025-11-23 15:56:40] Manifest download: send request
    [2025-11-23 15:56:41] Manifest download: waiting for download to finish
    [2025-11-23 15:56:41] Manifest download: finished
    [2025-11-23 15:56:41] Download skipped: /steam_client_ubuntu12 version 1763795278, installed version 1763795278, existing pending version 0
    [2025-11-23 15:56:41] Nothing to do
    fsync: up and running.
    Hardware
    Silent Base 802 - X870E Hero - Ryzen7 9800X3D - DarkRockPro5 - 2x16GB DDR5 - RX 9070 - DarkPower14 850W
    UltraGear 39" 3440x1440
  • Hallo. Ich wieder. Ich habe eine weitere HDD ins System gehangen, NTFS formatiert und meine Steam Library dorthin kopiert. Test unter Windows, alles funktioniert. Test unter Mint, gleiches Problem wie zuvor, die Spiele starte, tun so als ob und stoppen dann wieder.
    Am Dateisystem selbst scheint es also NICHT zu liegen.
  • die Spiele starte, tun so als ob und stoppen dann wieder.
    Selbes Problem hatte ich damals, als ich meine Steam-Bibliothek sowohl von Windows als auch von Linux aus nutzen wollte. Die Spiele starteten so einfach nicht. Ich hatte meinen Plan dann verworfen und die Spiele-SSD im EXT4-Dateisystem neu formatiert. So konnte ich die Spiele zwar nicht mehr von Windows aus starten, aber in Linux hatte Steam nun keine Probleme mehr, die Spiele zu starten.
    Danach hatte ich hier mal gelesen, dass es wohl ein Rechteproblem gewesen sein könnte. Das konnte und wollte ich dann allerdings nicht mehr ausprobieren.
  • So, ich habe jetzt schließlich eine weitere Platte eingehangen, alles kopiert, die bisher verwendete Platte mit NTFS formatiert und in Steam eingefügt, ein paar Spiele installiert und siehe da, sie funktionieren. Was auch immer es verursacht hatte, bleibt ein Rätsel, aber ist nun überwunden.
    Danke an alle Beitragenden.
  • jamaica2912 Das freut mich zu hören. Ich habe auch alles neu installiert. Ich hatte mein System von PCIe3 auf PCIe5 geupgraded. Vielleicht lag`s daran.
    Hardware
  • Das glaubt mir kein Mensch. Nun ist alles wieder so kaputt wie vorher.
    Ich habe gestern eine Keepass Datei aufgemacht, editiert und konnte sie plötzlich auf dem nun komplett neu eingerichteten und NTFS formatierten Drive nicht mehr abspeichern. "Keine Berechtigung." Mir ist nun aufgefallen, dass die Rechte für user und gruppe alle auf "root" stehen plötzlich.
    Ich habe gestern zahlreiche Anwendungsaktualisierungen installiert, keine Ahnung ob es daran liegt.
    Das ursprüngliche Fehlverhalten von Steam ist nun auch wieder da. Spiele starten nicht mehr.
    Ich werde dem so allmählich überdrüssig, es kann doch nicht sein, dass Mint permanent einfach über Nacht irgendwas verändert und alles zerschießt...||
  • Hilf mir doch bitte kurz nochmal wie ist die Platte gemountet ? Welche Berechtigungen hast du gesetzt ?
    /dev/disk/by-uuid/1EE8C6DD3545DCFE /media/Data ntfs3 nofail,auto,rw
    Bis gestern funktionierte alles so wie es ist. Jetzt kann ich nicht mal mehr meine KeePass Datei editieren und speichern, wegen mangelnder Rechte und muss das immer mit privilegierten Rechten umschiffen.
