Probleme beim Booten, scheinbar macht der NVIDIA Treiber Probleme
    Linux Mint
    Kernel: 6.14.0-34-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Laptop System: GIGABYTE product: G5 MF5 v: N/A
    serial: <superuser required>
    Mobo: GIGABYTE model: G5 MF5 serial: <superuser required> UEFI: INSYDE
    v: FD12 date: 06/25/2025
    Battery:
    ID-1: BAT0 charge: 41.9 Wh (85.2%) condition: 49.2/52.5 Wh (93.7%)
    volts: 16.6 min: 15.4 model: Notebook BAT status: not charging
    Info: 10-core (6-mt/4-st) model: 13th Gen Intel Core i7-13620H bits: 64
    type: MST AMCP arch: Raptor Lake rev: 2 cache: L1: 864 KiB L2: 9.5 MiB
    L3: 24 MiB
    Speed (MHz): avg: 555 high: 1000 min/max: 400/4700:4900:3600 cores: 1: 527
    2: 400 3: 400 4: 400 5: 400 6: 400 7: 999 8: 1000 9: 400 10: 400 11: 707
    12: 400 13: 401 14: 400 15: 853 16: 796 bogomips: 93388
    Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel arch: Gen-13 bus-ID: 00:02.0
    Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
    vendor: CLEVO/KAPOK driver: nvidia v: 580.95.05 arch: Lovelace
    bus-ID: 01:00.0
    Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB bus-ID: 3-8:3
    loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa dri: iris gpu: i915
    resolution: 1920x1080~144Hz
    API: EGL v: 1.5 drivers: iris,nouveau,nvidia,swrast platforms:
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa
    v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
    Intel Graphics (RPL-P)
    Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Gigabyte
    Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
    API: ALSA v: k6.14.0-34-generic status: kernel-api
    Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3
    IF: wlp0s20f3 state: up mac: <filter>
    vendor: CLEVO/KAPOK RTL8111/8168/8411 driver: r8169 v: kernel port: 3000
    bus-ID: 04:00.0
    IF: enp4s0 state: down mac: <filter>
    Bluetooth:
    Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 3-10:4
    lmp-v: 12
    Local Storage: total: 3.64 TiB used: 1.5 TiB (41.3%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
    temp: 31.9 C
    ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
    temp: 32.9 C
    ID-1: / size: 1.79 TiB used: 1.5 TiB (84.0%) fs: ext4 dev: /dev/nvme1n1p2
    ID-2: /boot/efi size: 96 MiB used: 36.9 MiB (38.5%) fs: vfat
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 44.0 C mobo: N/A
    Fan Speeds (rpm): N/A
    Memory: total: 32 GiB note: est. available: 31.05 GiB used: 9.32 GiB (30.0%)
    Processes: 501 Uptime: 1h 26m Init: systemd target: graphical (5)
    Packages: 2179 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Guten Tag
    Ich bin Windows umsteiger und nutze Linux Mint jetzt seit einem dreiviertel Jahr. Mittlerweile auf meinen 2 Desktop PCs und meinem Laptop.
    Bisher hatte ich auch keine Probleme bzw. konnte diese mit suchen und schlau-machen selbst lösen.
    Seit einigen Wochen macht mein Laptop aber Probleme beim Starten, so das ich diesen zigmal an und aus machen muss bis ich mich anmelden kann.
    Scheinbar macht der Nvidia Treiber Probleme, oder der GPU-Manager. (so meine Vermutung) wenn ich den Nvidia Treiber deinstalliere startet der Laptop wieder normal.
    Aber auch beim Herunterfahren gibt es ab und zu Probleme.
    Diese beiden Bilder dazu:
    Ich habe den treiber mit der Ubuntu Treiberverwaltung installiert.
    Mit sudo apt update & sudo apt upgrade kann ich das Problem auch nicht beheben da es nichts zu aktualisieren gibt.
    marek@laptop-mint:~$ nvidia-smi
    Sat Nov 1 16:21:35 2025
    | NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
    | GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
    | Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
    | | | MIG M. |
    | 0 NVIDIA GeForce RTX 4050 ... Off | 00000000:01:00.0 Off | N/A |
    | N/A 40C P8 2W / 60W | 364MiB / 6141MiB | 0% Default |
    | | | N/A |
    | Processes: |
    | GPU GI CI PID Type Process name GPU Memory |
    | ID ID Usage |
    | 0 N/A N/A 1169 G /usr/lib/xorg/Xorg 4MiB |
    | 0 N/A N/A 17865 C+G ...86)\Battle.net\Battle.net.exe 13MiB |
    Da der Laptop nicht startet wenn das Problem auftritt weis ich nicht wie ich an Fehler Logs kommen soll und wenn der Laptop startet besteht der Fehler ja nicht.
    Seltsamer weise habe ich das Problem nicht auf meinen Desktop PCs, obwohl diese auch Mint installiert haben. Der eine hat eine Intel CPU mit integrierter GPU und extra Nvidia GPU, der andere hat eine AMD CPU mit integrierter GPU und extra Nvidia GPU. Dort tritt das Problemm aber nicht auf.
    Auf meinem Laptop habe ich den Kernel 6.8 probiert und den Kernen 6.14, bei beiden tritt das Problem auf. Ich habe auch Probiert alle Kernel zu löschen, bis auf den aktuellsten, das hat aber auch nicht geholfen. Etliche male den Nvidia Treiber deinstallieren und neu installieren brachte auch keine Besserung. Den Treiber über die Konsole zu installieren hat auch nicht geholfen.
    Mittlerweile bin ich echt Ratlos und auch das Tagelange suchen in verschiedenen Foren hat mich einer Lösung auch nicht näher gebracht.
    Falls ich mir irgendwann einen neuen Laptop kaufe wird der eine AMD GPU haben, aber das hilft mir jetzt auch nicht weiter.
    Ich bitte um Hilfe und nachsicht da ich als Linux Neuling eben noch viel zu lernen habe.
    Liebe Grüße
    Marek
    Edited once, last by Marek9 (November 1, 2025 at 4:37 PM).
  • Ebenfalls Neuling hier. Ich hatte auch Ärger beim Starten. Auch war ein Live-Boot Mint teilweise nicht möglich. Was ich mal gemacht habe ist das Bios auf die Standard-Einstellungen zu setzten und im Fall von mehreren GPUs nur eine primäre zu aktivieren und die zusätzliche Grafik der CPU bewusst abgestellt. Ich hatte dazu auch GRUB Probleme. Das System startete dann manchmal gar nicht den Monitor oder kam in den Log-in hinein - alles sehr zufällig.
    Das Forum hatte mir empfohlen nach einem Systemstart mit Log-in den Befehl zu starten
    sudo journalctl -b -p err -x >journal.txt
    Das gibt noch mal Meldungen aus die beim Start nicht richtig funktioniert haben. Vielleicht hilft das dem Forum weiter.
    Ich habe bei mir mit einem Ventoy diverse ISOs auf einen USB Stick gelegt. Das Iso Boot-repair hat mir den Grub oder was immer da schief lag gefixt. Später habe ich dann aus dem Terminal nochmal den Grub aus dem Terminal aktualisiert.
    In der Treiberverwaltung läuft bei mir nun der nvidia driver 580.95.05... und der ganze Spuk ist vorbei. Gestartet bin ich mit 22.1 und habe inzwischen Mint 22.2 am Start. Kernel 6.14.0-34 zeigt sich hier. Das war eine Sache, die ich einmal in der Aktualisierungsverwaltung/Ansicht/Kernel geklickt habe. Seit dem ist hier Ruhe und Freude am Start. Win10 fliegt demnächst von der Platte.
    Linux Mint Anfänger und dankbar für Tipps und Ticks
  • Hallo und danke für deine Antwort.
    Der Befehl: sudo journalctl -b -p err -x >journal.txt, gibt bei mir keinen Text aus. Falls dort nur Errors ausgegeben werden, gibt es wohl keine.
    Im Bios kann ich die Intel GPU nicht deaktivieren. Gigabyte hat hier offenbar ein extrem abgespecktes Bios verbaut.
    Das Grub startet bei mir ohne Probleme, dann kommt das erste Mint Splash und wenn dann die Graka aktiviert wird entsteht der Fehler erst.
  • Der Befehl leitet die Ausgabe in die Datei journal.txt um. Am Bildschirm wird da nichts angezeigt. Du musst dir den Inhalt der Datei ansehen.
  • Hey ,
    ist eventuell Secure boot eingeschaltet ? das war bei mir das Problem das der Nvidia Treiber nicht funktioniert hat.
  • Hallo und danke für die Antwort.
    Nein, secure boot habe ich schon vor der Mint Installation deaktiviert.
    Sonst schau hier mal rein
    mir hatte es geholfen als ich den Emroll Mok erneuert hatte somit kommte ich Secure boot sogar anlassen und der Nvidia Treiber läuft seitdem perfekt.
    How to Install Nvidia Drivers in Linux Mint
    How to install Nvidia drivers in Linux Mint using the driver manager; installing more recent drivers through apt install; and enrolling MOK keys in Secure Boot.
    www.virtualcuriosities.com
  • Sonst schau hier mal rein
    https://www.virtualcuriosities.com/articles/1788/…s-in-linux-mint
    Danke für den Tip.
    Hab den Treiber deinstalliert, secureboot aktiviert, mokkey übertragen und mit secureboot den Treiber 580 neu installiert.
    Mal abwarten ob das Problem jetzt weiterhin so häufig auftritt.
    Oh, ok, war mir nicht bewusst.
    Hier die Ausgabe von: sudo journalctl -b -p err -x >journal.txt, bevor secureboot aktiviert wurde.
    Nov 01 16:44:13 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.MHBR], AE_NOT_FOUND (20240827/psargs-332)
    Nov 01 16:44:13 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PTID.PBAR], AE_NOT_FOUND (20240827/dsfield-500)
    Nov 01 16:44:13 laptop-mint kernel: integrity: Problem loading X.509 certificate -22
    Nov 01 16:44:13 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^RP28.PXSX.WIST], AE_NOT_FOUND (20240827/psargs-332)
    Nov 01 16:44:13 laptop-mint kernel: ACPI Error: Aborting method \_SB.PC00.CNVW.IFUN due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
    Nov 01 16:44:13 laptop-mint kernel: ACPI Error: Aborting method \_SB.PC00.CNVW._DSM due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
    Nov 01 16:44:14 laptop-mint kernel:
    Nov 01 17:43:39 laptop-mint nvidia-persistenced[1096]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 122 has read and write permissions for those files.
    Nov 01 17:43:39 laptop-mint systemd[1]: Failed to start nvidia-persistenced.service - NVIDIA Persistence Daemon.
    ░░ Subject: A start job for unit nvidia-persistenced.service has failed
    ░░ Defined-By: systemd
    ░░ Support: http://www.ubuntu.com/support
    ░░ A start job for unit nvidia-persistenced.service has finished with a failure.
    ░░ The job identifier is 956 and the job result is failed.
    Nov 01 17:43:40 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.ETMD], AE_NOT_FOUND (20240827/psargs-332)
    Nov 01 17:43:40 laptop-mint kernel: ACPI Error: Aborting method \_SB.IETM._OSC due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
    Nov 01 17:43:40 laptop-mint bluetoothd[848]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Nov 01 17:43:40 laptop-mint bluetoothd[848]: sap-server: Operation not permitted (1)
    Nov 01 17:43:40 laptop-mint bluetoothd[848]: Failed to set mode: Failed (0x03)
    Nov 01 17:43:43 laptop-mint lightdm[1350]: gkr-pam: couldn't unlock the login keyring.
    Nov 01 17:43:43 laptop-mint systemd[1357]: Failed to start openrazer-daemon.service - Daemon to manage razer devices in userspace.
    ░░ Subject: A start job for unit UNIT has failed
    ░░ A start job for unit UNIT has finished with a failure.
    ░░ The job identifier is 37 and the job result is failed.
    Nov 01 17:43:46 laptop-mint systemd[1]: Failed to start casper-md5check.service - casper-md5check Verify Live ISO checksums.
    ░░ Subject: A start job for unit casper-md5check.service has failed
    ░░ A start job for unit casper-md5check.service has finished with a failure.
    ░░ The job identifier is 122 and the job result is failed.
    Nov 01 17:43:50 laptop-mint lightdm[1490]: gkr-pam: unable to locate daemon control file
    Nov 01 17:53:34 laptop-mint systemd-coredump[7342]: Process 6958 (CrBrowserMain) of user 1000 dumped core.
                                                       Stack trace of thread 265:
                                                       #0  0x00000000e9853626 n/a (/app/lib/i386-linux-gnu/libgcc_s.so.1 + 0x1c626)
                                                       ELF object binary architecture: Intel 80386
    ░░ Subject: Speicherabbild für Prozess 6958 (CrBrowserMain) generiert
    ░░ Documentation: man:core(5)
    ░░ Prozess 6958 (CrBrowserMain) ist abgebrochen worden und
    ░░ ein Speicherabbild wurde generiert.
    ░░ Üblicherweise ist dies ein Hinweis auf einen Programmfehler und sollte
    ░░ als Fehler dem jeweiligen Hersteller gemeldet werden.
    Und folgende Ausgabe nachdem secureboot aktiviert wurde:
    Nov 01 19:20:25 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.MHBR], AE_NOT_FOUND (20240827/psargs-332)
    Nov 01 19:20:25 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PTID.PBAR], AE_NOT_FOUND (20240827/dsfield-500)
    Nov 01 19:20:25 laptop-mint kernel: integrity: Problem loading X.509 certificate -22
    Nov 01 19:20:26 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [^^RP28.PXSX.WIST], AE_NOT_FOUND (20240827/psargs-332)
    Nov 01 19:20:26 laptop-mint kernel: ACPI Error: Aborting method \_SB.PC00.CNVW.IFUN due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
    Nov 01 19:20:26 laptop-mint kernel: ACPI Error: Aborting method \_SB.PC00.CNVW._DSM due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
    Nov 01 20:19:50 laptop-mint nvidia-persistenced[1095]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 122 has read and write permissions for those files.
    Nov 01 20:19:50 laptop-mint systemd[1]: Failed to start nvidia-persistenced.service - NVIDIA Persistence Daemon.
    Nov 01 20:19:50 laptop-mint kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_TZ.ETMD], AE_NOT_FOUND (20240827/psargs-332)
    Nov 01 20:19:50 laptop-mint kernel: ACPI Error: Aborting method \_SB.IETM._OSC due to previous error (AE_NOT_FOUND) (20240827/psparse-529)
    Nov 01 20:19:51 laptop-mint bluetoothd[845]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
    Nov 01 20:19:51 laptop-mint bluetoothd[845]: sap-server: Operation not permitted (1)
    Nov 01 20:19:51 laptop-mint bluetoothd[845]: Failed to set mode: Failed (0x03)
    Nov 01 20:19:54 laptop-mint lightdm[1344]: gkr-pam: couldn't unlock the login keyring.
    Nov 01 20:19:54 laptop-mint systemd[1351]: Failed to start openrazer-daemon.service - Daemon to manage razer devices in userspace.
    ░░ The job identifier is 30 and the job result is failed.
    Nov 01 20:19:56 laptop-mint systemd[1]: Failed to start casper-md5check.service - casper-md5check Verify Live ISO checksums.
    ░░ The job identifier is 149 and the job result is failed.
    Nov 01 20:20:08 laptop-mint lightdm[1483]: gkr-pam: unable to locate daemon control file
  • Secure boot on oder off ist nicht mehr so ein Thema. Fast Boot solltest Du abstellen, falls noch aktiviert. UEFI Boot an, kein Legacy Boot oder was dein Mainboard kann ist meiner Meinung nach auch fein.
    ACPI Fehler soll man wohl ignorieren können. https://forums.linuxmint.com/viewtopic.php?t=405808
    Gibt es für dein Mainboard ein Bios Update? Das steht bei den meisten Fehlern an erster Stelle, wenn ich deine Fehler suche.
  • Guten Morgen
    Secureboot hat das Problem nicht behoben, heute morgen musste ich den Laptop wieder mehrfach an und aus machen bis ich mich anmelden konnte.
    Das Bios hab ich vorgestern aktualisiert, hat nicht geholfen.
    Fast Boot ist deaktiviert.
    Legacy Boot und so gibt es in diesem Bios nicht, wie gesagt, das ist extrem abgespeckt im vergleich zu den Desktop PCs.
    Aus dem Log geht hervor das es mit "nvidia-persistenced" Probleme gibt, kann man das irgendwie beheben?
  • kim88 November 2, 2025 at 10:17 AM
    Changed the title of the thread from “Probele beim Booten, scheinbar macht der NVIDIA Treiber Probleme” to “Probleme beim Booten, scheinbar macht der NVIDIA Treiber Probleme”.
  • Was ich noch im Netz fand deutet an, dass man die Nvidia Pakete alle runter wirft und so frisch aufsetzt, indem man den Quelloffenen Treiber installiert, alles von Nvidia löscht und dann neu einspielt. Keine Gewähr, dass das hier nicht mehr Schaden anrichtet:
    Hier eine Methode:
    Treiberverwaltung und den OpenSource Treiber wählen und neu starten.
    Anwendungverwaltung bzw. Paketverwaltung und alte Kofigurationen entfernen. Neu starten.
    Treiberverwaltung und Nvidia 580er Treier installieren. Neu starten.
    (Originalqulle)
    Go to Driver Mgr and choose the open source driver. Restart,
    Use Synaptic to completely uninstall the problem Nvidia. Restart.
    Go to Driver Mgr again and install the Nvidia again. Restart.
    Ein Anderer schreibt das hier: Es löscht alles nvidia bezogene (mit dem Holzhammer) und installiert einen Mint Nvidia Teil.
    sudo apt-get purge *nvidia*
    sudo apt-get install nvidia-prime-applet
    Rechner neu starten. Dann über die Treiberverwaltung den Opensource Treiber verwenden. Ein mal mehr Neustarten.
    Wenn alles läuft kann man dann zu der Treiberverwaltung wieder zum 580er Treiber zurückkehren. Angeblich ohne purge und co.
    Diese Vorgehensweise habe ich schon ausprobiert, leider auch ohne erfolg.
  • Ich denke es kann dann Sinn machen mal eine andere Distro zu probieren. Das wären meine nächsten Ansätze, wenn ich aus den Problemen nicht herauskommen würde.
    https://bazzite.gg/ kann man beim ISO Download schon an die Hardware anpassen.
    https://cachyos.org/ ist eher Fortgeschrittenen empfohlen, jedoch sollte es modern und gut anpassbar sein.
  • Ich hab Cachy gestern auf meinem Laptop installiert. Das Problem tritt nicht mehr auf, obwohl auch hier der Treiber 580 installiert ist.
    Leider gefällt mir KDE nicht und das Cinnamon von Cachy ist bei weitem nicht so wie bei LM.
    Mal sehen, evtl probier ich die Tage mal LMDE.
    Gelöst ist das Problem aber immer noch nicht. Ich habe seit fast einem Jahr LM auf dem Laptop benutzt, ohne Probleme und habe mich dabei sehr an LM gewöhnt was ich eigentlich gerne weiter nutzen möchte.
  • Ja, verstehe Dich gut. Geht mir auch so. Aber wenn alles klemmt stimmt an der Basis etwas nicht. Ich habe mir für meinen "win10 runter mint rauf" Vorgang eine Backuptheorie zurecht gelegt und hoffe, dass alles funktioniert. Wenn nicht mache ich mal einen Ausflug zu anderen Distros.
    Du kannst die Linuxe auch parallel nutzen.
  • Während ich am LMDE installieren war dachte ich mir, wenn Cachy mit Kernel 6.17 läuft warum dann nicht auch mint.
    Also nochmal mint installiert und Kernel 6.17 aufgespielt. Hatte dann zwar nicht mehr das Problem beim starten, dafür aber einige andere Probleme, vermutlich weil mint den "fremden" Kernel nicht mochte.
    Hab dann LMDE installiert und eingerichtet. Läuft fehlerfrei mit Nvidia Treiber 550.
    Hab dann mint installiert und versucht Treiber 550 zu installieren, ging aber nicht, auch über Konsole nicht weil trotz befehl für Treiber 550 der Treiber 580 installiert wurde mit dem das start Problem wieder auftritt.
    Jetzt nutze ich LMDE das läuft wenigstens fehlerfrei.
  • Ändert aber nichts daran das irgend ein komischer Fehler bei mint besteht, also wenn jemand noch Vorschläge hat, würde ich die gerne ausprobieren.
  • Ich weiss nicht, ob das hilft, aber der NVIDIA-580er Treiber funktioniert in der Open-Version bei mir besser als der reine properitäre 580er. Ich muss aber faiererweise dazu sagen, dass ich wegen dem permanenten NVIDIA-Geaste unter Linux Mint weg von der Distro bin.
    *MSI Raider GE66 UGS* -Intel Core I7 12700H- *16 GB RAM* -NVIDIA Geforce RTX 3070Ti Laptop GPU-
    *1 TB SSD* -512 MB SD- *17" QHD 240 Hz interner Monitor* -27" FHD Samsung externer Monitor- *SteelSeries Arctic Nova 7 Wireless Headset*
    Hallo und danke für deinen Beitrag.
    Ich habe den 580 open und den "normalen" 580 probiert. Bei beiden das selbe Problem.
    Ich habe mint zuerst mit dem Treiber 550 genutzt. Lief ohne Probleme, über ein halbes Jahr. Erst mit den neueren Treibern 570, 575, 580 fingen die Probleme an. (Aber nur auf meinem Laptop, meine beiden Desktop-PCs laufen mit Mint und dem Treiber 580 Perfekt)
    Ich hab aber keinerlei Ahnung von Treibern und Kerneln und kann daher auch keine Einschätzung abgeben was das Problem sein könnte. Mir bleibt nur zu hoffen das zukünftig neuere Treiber oder ein neueres Ubuntu als unterbau das Problem beheben.
    Edited once, last by Marek9 (November 11, 2025 at 5:19 PM).
