- Distrowahl
- Linux Mint
- System:
Kernel: 6.14.0-34-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Laptop System: GIGABYTE product: G5 MF5 v: N/A
serial: <superuser required>
Mobo: GIGABYTE model: G5 MF5 serial: <superuser required> UEFI: INSYDE
v: FD12 date: 06/25/2025
Battery:
ID-1: BAT0 charge: 41.9 Wh (85.2%) condition: 49.2/52.5 Wh (93.7%)
volts: 16.6 min: 15.4 model: Notebook BAT status: not charging
Info: 10-core (6-mt/4-st) model: 13th Gen Intel Core i7-13620H bits: 64
type: MST AMCP arch: Raptor Lake rev: 2 cache: L1: 864 KiB L2: 9.5 MiB
L3: 24 MiB
Speed (MHz): avg: 555 high: 1000 min/max: 400/4700:4900:3600 cores: 1: 527
2: 400 3: 400 4: 400 5: 400 6: 400 7: 999 8: 1000 9: 400 10: 400 11: 707
12: 400 13: 401 14: 400 15: 853 16: 796 bogomips: 93388
Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-13 bus-ID: 00:02.0
Device-2: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: CLEVO/KAPOK driver: nvidia v: 580.95.05 arch: Lovelace
bus-ID: 01:00.0
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB bus-ID: 3-8:3
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa dri: iris gpu: i915
resolution: 1920x1080~144Hz
API: EGL v: 1.5 drivers: iris,nouveau,nvidia,swrast platforms:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa
v: 25.0.7-0ubuntu0.24.04.2 glx-v: 1.4 direct-render: yes renderer: Mesa
Intel Graphics (RPL-P)
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Gigabyte
Device-2: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
API: ALSA v: k6.14.0-34-generic status: kernel-api
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlp0s20f3 state: up mac: <filter>
vendor: CLEVO/KAPOK RTL8111/8168/8411 driver: r8169 v: kernel port: 3000
bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 3-10:4
lmp-v: 12
Local Storage: total: 3.64 TiB used: 1.5 TiB (41.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
temp: 31.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
temp: 32.9 C
ID-1: / size: 1.79 TiB used: 1.5 TiB (84.0%) fs: ext4 dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 96 MiB used: 36.9 MiB (38.5%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 44.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.05 GiB used: 9.32 GiB (30.0%)
Processes: 501 Uptime: 1h 26m Init: systemd target: graphical (5)
Packages: 2179 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Guten Tag
Ich bin Windows umsteiger und nutze Linux Mint jetzt seit einem dreiviertel Jahr. Mittlerweile auf meinen 2 Desktop PCs und meinem Laptop.
Bisher hatte ich auch keine Probleme bzw. konnte diese mit suchen und schlau-machen selbst lösen.
Seit einigen Wochen macht mein Laptop aber Probleme beim Starten, so das ich diesen zigmal an und aus machen muss bis ich mich anmelden kann.
Scheinbar macht der Nvidia Treiber Probleme, oder der GPU-Manager. (so meine Vermutung) wenn ich den Nvidia Treiber deinstalliere startet der Laptop wieder normal.
Aber auch beim Herunterfahren gibt es ab und zu Probleme.
Diese beiden Bilder dazu:
Ich habe den treiber mit der Ubuntu Treiberverwaltung installiert.
Mit sudo apt update & sudo apt upgrade kann ich das Problem auch nicht beheben da es nichts zu aktualisieren gibt.
marek@laptop-mint:~$ nvidia-smi
Sat Nov 1 16:21:35 2025
| NVIDIA-SMI 580.95.05 Driver Version: 580.95.05 CUDA Version: 13.0 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4050 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 40C P8 2W / 60W | 364MiB / 6141MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1169 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 17865 C+G ...86)\Battle.net\Battle.net.exe 13MiB |
Da der Laptop nicht startet wenn das Problem auftritt weis ich nicht wie ich an Fehler Logs kommen soll und wenn der Laptop startet besteht der Fehler ja nicht.
Seltsamer weise habe ich das Problem nicht auf meinen Desktop PCs, obwohl diese auch Mint installiert haben. Der eine hat eine Intel CPU mit integrierter GPU und extra Nvidia GPU, der andere hat eine AMD CPU mit integrierter GPU und extra Nvidia GPU. Dort tritt das Problemm aber nicht auf.
Auf meinem Laptop habe ich den Kernel 6.8 probiert und den Kernen 6.14, bei beiden tritt das Problem auf. Ich habe auch Probiert alle Kernel zu löschen, bis auf den aktuellsten, das hat aber auch nicht geholfen. Etliche male den Nvidia Treiber deinstallieren und neu installieren brachte auch keine Besserung. Den Treiber über die Konsole zu installieren hat auch nicht geholfen.
Mittlerweile bin ich echt Ratlos und auch das Tagelange suchen in verschiedenen Foren hat mich einer Lösung auch nicht näher gebracht.
Falls ich mir irgendwann einen neuen Laptop kaufe wird der eine AMD GPU haben, aber das hilft mir jetzt auch nicht weiter.
Ich bitte um Hilfe und nachsicht da ich als Linux Neuling eben noch viel zu lernen habe.
Liebe Grüße
Marek
