PC wird nicht ausgeschaltet
    Linux Mint
    Kernel: 6.14.0-33-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Mini-pc Mobo: Trigkey model: S5 v: V2.0 serial: <superuser required>
    UEFI: American Megatrends LLC. v: 5800H506 date: 03/29/2023
    Info: 8-core model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 2 rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
    Speed (MHz): avg: 1464 high: 2742 min/max: 400/4373 boost: enabled cores:
    1: 1114 2: 1114 3: 1777 4: 1114 5: 1788 6: 1114 7: 1795 8: 1114 9: 1114
    10: 1114 11: 2742 12: 2234 13: 1114 14: 1114 15: 1114 16: 1958
    bogomips: 57492
    Device-1: AMD Lucienne driver: amdgpu v: kernel arch: GCN-5 bus-ID: 04:00.0
    temp: 41.0 C
    resolution: 1280x1024~60Hz
    Radeon Graphics (radeonsi renoir ACO DRM 3.61 6.14.0-33-generic)
    Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 04:00.1
    Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_rn_pci_acp3x
    v: kernel bus-ID: 04:00.5
    Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel v: kernel
    bus-ID: 04:00.6
    API: ALSA v: k6.14.0-33-generic status: kernel-api
    driver: r8169 v: kernel port: f000 bus-ID: 01:00.0
    IF: enp1s0 state: down mac: <filter>
    Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 02:00.0
    IF: wlo1 state: up mac: <filter>
    IF-ID-1: br-458e92114726 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
    IP v4: <filter> scope: global
    IP v6: <filter> scope: link
    IF-ID-2: br-e794bf89f8f1 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
    IF-ID-3: docker0 state: down mac: <filter>
    IF-ID-4: veth2647cc2 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    IF-ID-5: veth71f9fc3 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    IF-ID-6: vethccabbd0 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
    Bluetooth:
    Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-3:3
    address: <filter>
    Local Storage: total: 494.67 GiB used: 72.22 GiB (14.6%)
    ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P3PSSD8 size: 465.76 GiB
    temp: 37.9 C
    ID-2: /dev/sda vendor: Intenso model: Rainbow Line size: 28.91 GiB
    type: USB
    ID-1: / size: 456.89 GiB used: 69.35 GiB (15.2%) fs: ext4
    dev: /dev/nvme0n1p2
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 46.9 C mobo: N/A gpu: amdgpu temp: 42.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 12 GiB note: est. available: 12.57 GiB used: 8.67 GiB (69.0%)
    Processes: 458 Uptime: 15m Init: systemd target: graphical (5)
    Packages: 2198 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Umsteiger von Windows auf Linux Mint braucht Hilfe bei folgendem Problem:
    PC wird nach runterfahren nicht ausgeschaltet
    erst lange Betätigung des On/Off-Schalters schaltet den PC aus
    aber: Bereitschaftsmodus funktioniert, danach wird PC nach runterfahren auch richtig ausgeschaltet
    gleiche Phänome treten auch beim Booten vom Live-Stick auf
    ausschalten im Terminal bringt keine Änderung
    "acpi=force" bringt keine Änderung
    "Fast Boot" ist ausgeschaltet
    unter Win 11 wurde der PC richtig ausgeschaltet
    Wer kann helfen?
  • Kurze Zwischenfrage:
    Wie lange hast du gewartet bis du den PC mit dem Schalter abgeschaltet hast?
    Es kann vorkommen, das der PC ca. 90 Sekunden - und die können lang werden wenn man wartet - braucht, um alles richtig zu beenden bzw. Prozesse zu schließen.
  • Ich hab das auch seit 3 Jahren. Ich weiß bis heute nicht woran es liegt.
  • Mein Notebook hat das auch hin und wieder. Manchmal kann er ein mit Fstab gemountetes Netzlaufwerk nicht beenden, das dauert dann halt 90sek. und dann schaltet er sich ab. Beim herunter fahren kann ich bei Ubuntu mit <ESC> den Status sehen womit er sich gerade vergnügt...
    Im Falle des TO müsste man erst mal schauen, ob die 90 Sekunden das Problem sind. Wie du schon schreibst würde man erstens entsprechende Meldungen beim runter fahren beobachten und der PC würde dann nach der entsprechenden Zeit auch ausschalten. Da wäre natürlich am Besten, die Ursache zu beheben. Wenn man aber einfach will, dass die Wartezeit reduziert wird kann man in der Datei /etc/systemd/system.conf die Variable DefaultTimeoutStopSec "scharf schalten (das Kommentar-Gatter # am Anfang der Zeile entfernen) und den Wert auf z.B. 5 Sekunden stellen (DefaultTimeoutStopSec=5s).
    Wenn der PC wirklich einfach nicht runter fahren will könnte evtl. ein Bios Update helfen.
  • Ein kurzer Hinweis zu den 90 Sekunden, die Tuxine gennant hat. Der Themenstarter verwendet Linux Mint 22.2, da ist die Zeit auf 10 Sekunden verkürzt. Das wurde mit "Wilma" eingeführt, siehe Releasenotes unter https://www.linuxmint.com/rel_wilma.php. ("For your convenience, the shutdown timeout is reduced to 10s.")
    Unterwegs im Fluch(t)modus.
  • Der PC bekommt kein ACPI-Signal für das Ausschalten.Wahrscheinlich werden alle Module entladen, aber das Signal geht nicht zum Board.(wird blockiert)
    -Mehrere Ansatzmöglichkeit:
    -Ich kann nur meine Erfahrung weiter geben. Probleme sind dann immer mit Kernelversionen aufgetreten. Ich nutze den 6.8er. Nach der Umstellung von 5.15 auf 6.8 gab es immer Probleme mit dem ACPI und Ausschalten.
    -Es kann jetzt der Kernel 6.14 sein. Evtl warten bis es ein Update gibt , oder mal den 6.8er verwenden.Bios-Einstellungen auf alle Fälle auf Default (Load Default Settings)setzen.Pc im Vorfeld stromlos machen.Normal mit Linux hoch fahren.
    -Laut Hardwareliste hat der eine Bluetoothfunktion. Kann sein, dass hier ein Gerät nicht beendet wird. Außerdem mal alle USB-Geräte abziehen(Drucker, anderes Keyboard, Maus , Funk-Dongel). Ich hatte eine alte Rustdesk-Versionen ,die auch Probleme bereitete.
    Evtl mal die Befehle im Terminal verwenden.
    Herunterfahren des Systems
    • Verwenden Sie poweroff oder shutdown -h now, um das System herunterzufahren.
    • Wenn Ihr System systemd verwendet, können Sie auch systemctl poweroff
      Evtl mal dmesg -w im Terminalfenster verwenden und mal schauen ob nach einem Neustart da eine Fehlermeldung beim Herunterfahren gibt.ACPI-Fehler, Laufwerke usw.
    Wogegen ich wieder das "Gefühl" habe "unter Win11" wurde das ausgeschaltet. Als ob da ein Multiboot verwendet wird und hier Konflikte mit ACPI und UEFI-Modus mit aktiviertem Secure Boot und TPM 2.0 vorliegt. Irgendetwas stimmt da nicht.evtl z.B. eine Windows-Richtlinie die im Bios festgeschrieben ist. Deswegen würde das Phänomen auch mit den Live-Sticks erklären.
    Vielen Dank für die Info - da ich kein Mint am Start habe, ist dies wohl leider an mir vorüber gegangen.
    Hoffentlich merke ich es mir auch ;)
