2x Anmelden beim Start
    EndeavourOS
    Kernel: 6.17.5-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    Desktop: KDE Plasma v: 6.5.0 Distro: EndeavourOS base: Arch Linux
    Type: Desktop Mobo: MSI model: Z170-A PRO (MS-7971) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.K0
    date: 07/10/2018
    Info: quad core model: Intel Core i7-6700K bits: 64 type: MT MCP
    arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 800 min/max: 800/4200 cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 bogomips: 63999
    Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
    7800 XT] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-3
    bus-ID: 03:00.0
    Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
    unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu
    resolution: 1920x1080~60Hz
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.5-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 21.1.4 DRM 3.64 6.17.5-arch1-1)
    API: Vulkan v: 1.4.328 drivers: radv surfaces: N/A devices: 1
    de: kscreen-console,kscreen-doctor wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
    Device-1: Intel 100 Series/C230 Series Family HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
    Device-2: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    Device-3: DSEA A/S Sennheiser Main Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-12:5
    API: ALSA v: k6.17.5-arch1-1 status: kernel-api
    Server-1: PipeWire v: 1.4.9 status: active
    vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 05:00.0
    IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 2.17 TiB used: 1.03 TiB (47.4%)
    ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO M.2 1TB size: 931.51 GiB
    ID-2: /dev/sdb vendor: OCZ model: AGILITY3 size: 119.24 GiB
    ID-3: /dev/sdc vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
    ID-4: /dev/sdd vendor: Intenso model: SSD Sata III size: 236 GiB
    ID-1: / size: 930.51 GiB used: 533.39 GiB (57.3%) fs: btrfs dev: /dev/sda2
    ID-2: /boot/efi size: 1022 MiB used: 588 KiB (0.1%) fs: vfat
    dev: /dev/sda1
    ID-3: /home size: 930.51 GiB used: 533.39 GiB (57.3%) fs: btrfs
    dev: /dev/sda2
    ID-4: /var/log size: 930.51 GiB used: 533.39 GiB (57.3%) fs: btrfs
    dev: /dev/sda2
    ID-1: swap-1 type: file size: 40 GiB used: 0 KiB (0.0%) file: /swap/swapfile
    System Temperatures: cpu: 30.0 C pch: 34.5 C mobo: N/A gpu: amdgpu
    temp: 32.0 C
    Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
    Memory: total: 32 GiB available: 31.3 GiB used: 2.91 GiB (9.3%)
    Processes: 304 Uptime: 9m Init: systemd
    Packages: 1816 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3 inxi: 3.3.39
    Es ist echt merkwürdig. Seit heute muß ich mich beim hochfahren meines EndeavourOS mit KDE 2x anmelden. Ich habe mich auch nicht vertippt. Ich hab dies auch mehrmals getestet.
    Das einzige was ich seit gestern geändert habe, ist den Swap zu erhöhen.
    Ich weiß echt nicht woran das liegen kann. Habt ihr eine Idee?
  • Bei mir lag das mal am mounten einer Netzwerkverknüpfung mit Wlan. Mit Kabel war das weg. Das mounten des Laufwerks war schneller geladen als ich mich angemeldet habe und musste mich deshalb 2 x anmelden.
    Das kann es nicht sein. Mein NAS läuft 24/7 und ist per Kabel angeschlossen.
    Ob das was mit dem Plasma Update zu tun hat?
    Das kann ich mir schon eher vorstellen.
  • Gestern wurde plasma-desktop upgegraded.
    Eben, deshalb der Gedanke. Habe gestern auch das Update eingespielt aber keine Probleme bemerkt.
    Ich würde einfach ein paar Tage warten, dann gibt bestimmt wieder Updates und alles läuft wieder :D
  • Eben, deshalb der Gedanke. Habe gestern auch das Update eingespielt aber keine Probleme bemerkt.
    Hoffen wir's
  • Hör mal Bulvai
    Kommt hier zum Zeitpunkt der Anmeldung irgendeine besondere Ausgabe zustande ?
    journalctl -u plasma --since "2025-10-25 11:00"
    Ich habe hier mal den heutigen Tag 25.10.2025 und als Beispiel 11:00 Uhr gewählt
    Wahrscheinlich "no entries" also keine Eintragung.
    Nur um mal was auszuschliessen.
    Gruss
  • Code
    [bulvai@Haitabu ~]$ journalctl -u plasma --since "2025-10-25 8:00"
    -- No entries --
    [bulvai@Haitabu ~]$
    Jetzt auf einmal verhält sich KDE wieder normal. Die doppelte Anmeldung ist jetzt anscheinend weg.
  • Ich habe die Bits unbewußt mit meinen Gedanken manipuliert.
