FritzBox-NAS unter Fedora 42 KDE
    Fedora
    Kernel: 6.17.4-200.fc42.x86_64 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    Desktop: KDE Plasma v: 6.4.5 Distro: Fedora Linux 42 (KDE Plasma Desktop
    Edition)
    Type: Desktop Mobo: Gigabyte model: Z690 GAMING X DDR4
    serial: <superuser required> UEFI: American Megatrends LLC. v: F27
    date: 09/12/2023
    Info: 14-core (6-mt/8-st) model: 13th Gen Intel Core i5-13600KF bits: 64
    type: MST AMCP arch: Raptor Lake rev: 1 cache: L1: 1.2 MiB L2: 20 MiB
    L3: 24 MiB
    Speed (MHz): avg: 800 min/max: 800/5100:3900 cores: 1: 800 2: 800 3: 800
    4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
    14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 bogomips: 139776
    Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
    / 6900 XT] vendor: XFX Speedster MERC 319 driver: amdgpu v: kernel
    arch: RDNA-2 bus-ID: 03:00.0
    Display: wayland server: Xwayland v: 24.1.8 compositor: kwin_wayland
    driver: gpu: amdgpu resolution: 1: 2880x1620~60Hz 2: 2880x1620~60Hz
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.9 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi navi21 LLVM
    20.1.8 DRM 3.64 6.17.4-200.fc42.x86_64)
    API: Vulkan v: 1.4.313 drivers: radv,llvmpipe surfaces: N/A devices: 2
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
    Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3
    Device-2: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
    driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    Device-3: Corsair HS80 MAX WIRELESS Gaming Receiver
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 1-8:4
    API: ALSA v: k6.17.4-200.fc42.x86_64 status: kernel-api
    Server-1: PipeWire v: 1.4.9 status: active
    Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    port: 3000 bus-ID: 08:00.0
    IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 2.73 TiB used: 39.92 GiB (1.4%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
    size: 931.51 GiB temp: 36.9 C
    ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 990 PRO 2TB size: 1.82 TiB
    temp: 38.9 C
    ID-1: / size: 1.82 TiB used: 39.54 GiB (2.1%) fs: btrfs dev: /dev/nvme1n1p3
    ID-2: /boot size: 973.4 MiB used: 369.3 MiB (37.9%) fs: ext4
    dev: /dev/nvme1n1p2
    ID-3: /boot/efi size: 598.8 MiB used: 19.3 MiB (3.2%) fs: vfat
    dev: /dev/nvme1n1p1
    ID-4: /home size: 1.82 TiB used: 39.54 GiB (2.1%) fs: btrfs
    dev: /dev/nvme1n1p3
    ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
    System Temperatures: cpu: 39.0 C mobo: 30.0 C gpu: amdgpu temp: 51.0 C
    Fan Speeds (rpm): N/A gpu: amdgpu fan: 476
    Memory: total: 32 GiB available: 31.16 GiB used: 6.28 GiB (20.2%)
    Processes: 642 Uptime: 49m Init: systemd target: graphical (5)
    Packages: 14 note: see --rpm Compilers: N/A Shell: Bash v: 5.2.37
    inxi: 3.3.39
    So, ich versuche (mal wieder) verzweifelt, meinen USB-Stick, der an der Fritzbox hängt, mit ChatGPT zum Laufen zu bekommen.
    Leider habe ich in Dolphin ein anderes Problem als mit einer anschließend angelegten Verknüpfung.
    Da ich leider nicht in der Lage bin, alles, was ich gemacht habe, vollständig wiederzugeben, stammt die folgende Zusammenfassung von ChatGPT.
    Ich hoffe, sie sagt mehr aus, als wenn ich jetzt hier alles manuell eintippen würde.
    _________________________________________________________________
    FritzBox-NAS unter Fedora 42 KDE – Schreib-/Löschrechte unlogisch verteilt
    • Fedora 42 (KDE Plasma / Wayland)
    • FritzBox 7590 AX – Fritz.NAS aktiviert
    • USB-Stick: FAT32, Freigabe mit „Lesen & Schreiben“
    • Zugriff über LAN
    Ziel:
    USB-Stick der FritzBox vom Desktop aus dauerhaft nutzen (lesen / schreiben / löschen).
    Zusammenfassung: FritzBox-NAS-Zugriff unter Fedora 42 KDE – Schreib-/Löschrechte inkonsistent
    System
    • Fedora 42 (KDE Plasma, Wayland)
    • FritzBox 7590 AX (SMB / Fritz.NAS aktiv)
    • USB-Stick an FritzBox: FAT32, Freigabe mit „Lesen & Schreiben“ für Benutzer
    • Zugriff per LAN, keine Gastfreigabe
    Ziel
    Fester Zugriff auf den FritzBox-USB-Stick (NAS) vom Desktop aus, mit voller Schreib- und Löschmöglichkeit.
    Erwünscht war eine Desktop-Verknüpfung, die dauerhaft funktioniert – auch nach Neustart.
    Was gemacht wurde
    1. fstab-Eintrag erstellt
      //fritz.box/FRITZ.NAS /media/fritzusb cifs credentials=/etc/samba/credentials-fritz,uid=1000,gid=1000,iocharset=utf8,vers=3.0,_netdev,x-systemd.automount 0 0
      → Mount funktioniert, Laufwerk erscheint unter /media/fritzusb.
    • Symptom:
      • Dateien löschbar, aber nicht kopierbar / schreibbar → „Zugriff verweigert“.
    • SMB-Verbindung über Dolphin getestet (smb://fritz.box/FRITZ.NAS/...)
      → Zugriff möglich, Dateien kopierbar, aber nicht löschbar („Keine Berechtigung“).
    • Desktop-Verknüpfung manuell erstellt
      • Anfangs per cat erzeugt → file:///media/fritzusb → zeigte auf fstab-Mount
      • Danach mehrfach angepasst (smb://-Pfad, KWrite-Bearbeitung etc.)
      • Zwischenzeitlich Fehler wie:
        • „/home/abraxas/smb://… existiert nicht“
        • „Unzulässige Adresse (URL)“
        • „Zugriff verweigert“
      • Schlussendlich korrekte Erstellung über:
        Rechtsklick → Neu → Verknüpfung mit Adresse → smb://fritz.box/...
    Vermutung / Analyse
    • Die FritzBox behandelt CIFS-Kernel-Mounts und KIO-SMB-Zugriffe als zwei verschiedene Clients mit getrennten Berechtigungen.
    • FAT32-Formatierung des USB-Sticks limitiert Samba-Rechte zusätzlich.
    • Ergebnis: Schreibvorgänge oder Löschvorgänge scheitern je nach Zugriffsart.
    Der USB-Stick funktioniert unter Windows und auch auf einem anderen Rechner (Werkstatt-PC) problemlos – dort lassen sich Dateien lesen, schreiben und löschen.
    Das Problem tritt nur unter Fedora 42 KDE auf und hängt eindeutig mit den unterschiedlichen Zugriffswegen zusammen:
    • Kernel-CIFS-Mount (fstab)
      → Fedora-Kernel-Treiber für SMB, arbeitet direkt auf Dateisystemebene
    • KIO-SMB (Dolphin / Plasma)
      → KDEs eigener Netzwerk-Client, läuft über Benutzer-Sitzung
    Beide melden sich unterschiedlich bei der FritzBox an, wodurch diese verschiedene Rechte vergibt.
    Das Verhalten ist also kein FritzBox-Fehler, sondern ein Zugriffs- bzw. Authentifizierungsproblem in Fedora/KDE.
    _____
    So, ich hoffe, mit der Beschreibung kann jetzt jemand etwas anfangen – ich hätte das selbst wohl kaum so formulieren können. 8|
    Edited once, last by Abraxas (October 25, 2025 at 7:53 PM).
  • Ich habe in der FB die NAS-Freigae und User erstellt. SMBv1 aktiviert und den USB-Fernanschluß.
    Über Dolphin dann Netzwerk/freigegebene Ordner (SMB) den NAS-Speicher der FB geöffnet und den Adresslink aus Dolphin für die Verknüpfung auf dem Desktop genutzt. Darüber konnte ich Dateien/Ordner erstellen, kopieren und löschen.
    Fedora 43 KDE
  • Über Dolphin kann ich zwar auf den Stick schreiben, aber nichts löschen; über den Desktop-Ordner ist es genau umgekehrt – dort kann ich löschen, aber keine Dateien hinzufügen.
    Habe auch mal den Usernamen jetzt mit in die Adress-URL gesetzt, keinerlei Änderung (war vorher nicht drinnen).
    Und Entschuldigung, ich habe jetzt zwar nicht die größte Ahnung bis keine, aber SMBv1 zu aktivieren halte ich für keine gute Idee (vor allem über Windows läuft das seit Jahren problemlos).
    Edited once, last by Abraxas (October 25, 2025 at 11:42 AM).
  • Finale Lösung (funktioniert zumindest bisher)
    Nach etlichen Tests (fstab, KIO-Samba, Flatpak-KDE-Zugriffe usw.) hat sich nun folgender Weg als zuverlässig erwiesen (zumindest jetzt bei mir):
    Mount-Ordner anlegen
    sudo mkdir -p /mnt/fritznas
    Credentials-Datei erstellen
    sudo nano /etc/samba/credentials_fritz
    Inhalt:
    username=DEINBENUTZERNAME
    password=DEINPASSWORT
    Rechte setzen:
    sudo chmod 600 /etc/samba/credentials_fritz
    Eintrag in /etc/fstab
    //fritz.box/FRITZ.NAS/USB-SanDisk3-2Gen1-01 /mnt/fritznas cifs credentials=/etc/samba/credentials_fritz,iocharset=utf8,uid=1000,gid=1000,file_mode=0777,dir_mode=0777,nounix,noserverino 0 0
    Testen
    sudo mount -a
    ls /mnt/fritznas
    Link auf den Schreibtisch
    ln -s /mnt/fritznas ~/Schreibtisch/FritzNAS
    Ergebnis
    • Voller Lese-, Schreib- und Löschzugriff
    • Keine Passwortabfrage
    • Automatisches Mounten beim Systemstart
    • Funktioniert zuverlässig auch nach Reboot
    Hinweis:
    Zugriffe über smb:// in Dolphin oder alte Desktop-Links vermeiden – die verwenden KDEs KIO-Samba und führen zu den beschriebenen Rechteproblemen.
    Mit freundlichen grüßen: ChatGpt5 und der Assistent an der Tastatur abraxas
