- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-85-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASUSTeK model: PRIME H310M-A R2.0 v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 1605
date: 07/14/2020
Info: 6-core model: Intel Core i5-9400F bits: 64 type: MCP arch: Coffee Lake
rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 9 MiB
Speed (MHz): avg: 2438 high: 3213 min/max: 800/4100 cores: 1: 800 2: 2713
3: 2798 4: 3213 5: 2513 6: 2591 bogomips: 34798
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GK208B [GeForce GT 710] driver: nvidia v: 470.256.02
arch: Fermi 2 bus-ID: 01:00.0
loaded: nvidia unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: kms_swrast,nouveau,nvidia,swrast platforms:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 710/PCIe/SSE2
Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
Device-2: NVIDIA GK208 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-3: Focusrite-Novation Focusrite Scarlett 2i2 2nd Gen
driver: snd-usb-audio type: USB bus-ID: 1-4:4
API: ALSA v: k6.8.0-85-generic status: kernel-api
vendor: ASUSTeK RTL8111H driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 4.43 TiB used: 151.1 GiB (3.3%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SA2000M8250G size: 232.89 GiB
temp: 28.9 C
ID-2: /dev/sda vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
ID-3: /dev/sdb vendor: Western Digital model: WD40EZAZ-00SF3B0
ID-4: /dev/sdc vendor: Intenso model: SSD Sata III size: 111.79 GiB
ID-1: / size: 45.1 GiB used: 32 GiB (70.9%) fs: ext4 dev: /dev/sdc5
ID-2: /boot/efi size: 96 MiB used: 31.6 MiB (32.9%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 37.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 40%
Memory: total: 16 GiB available: 15.55 GiB used: 2.12 GiB (13.7%)
Processes: 258 Uptime: 17m Init: systemd target: graphical (5)
Packages: 2168 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo Forum,
bin vor 2 Jahren privat auf Linux umgestiegen und versuche gerade unser 2-Personen-Büro ebenfalls von Win10 auf Linux Mint umsteigen zu lassen (Mein Büropartner ist voller Zweifel und will gar nichts damit zu tun haben, hoffe, dass ich ihn mit einem gut funktionierendem System doch noch beruhigen kann).
Zur Situation:
Wir haben zwei Desktop-Rechner die über LAN miteinander verbunden sind. In der Hauptsache tauschen wir in unserem Netzwerk Textdokumente aus. Hin und wieder bearbeiten wir Tonaufnahmen (bislang mit Cubase) und auch mal ein Video (Sony Vegas). Ich habe jetzt auf beiden Rechnern LM 22.1. installiert im Dualboot und versuche nun Schritt für Schritt unsere Anforderungen auf Linux zum Laufen zu bringen. Leider doch nicht so einfach, wie ich dachte.
Problem:
Zur Zeit scheitere ich schon daran, dass ich das Thunderbirdprofil, was ich in Win10 benutze nicht auf Linux zum Laufen bekomme, weil mit TB immer sagt
"Das Profil konnte nicht erstellt werden. Eventuell ist der gewählte Ordner schreibgeschützt.
[Exception... "Component returned failure code: 0x80520015 (NS_ERROR_FILE_ACCESS_DENIED) [nsIToolkitProfileService.createProfile]" nsresult: "0x80520015 (NS_ERROR_FILE_ACCESS_DENIED)" location: "JS frame :: chrome://mozapps/content/profile/createProfileWizard.js :: onFinish :: line 250" data: no]"
Das TB-Profil befindet sich auf einer Partition die ich nur für Linux reserviert habe. eigentlich sollte diese Partition auch immer sofort beim Start gemounted sein, aber das ist sie nicht und ich muss sie immer erst anklicken, um sie einzubinden. Aber selbst danach kommt die Fehlermeldung wie oben beschrieben.
Hat jemand ein paar Ideen, was ich versuchen könnte?
Grüße Immiperium
