Keine Eingabe möglich nach jeder Neuinstallation
    Kernel: 6.8.0-85-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASUSTeK model: PRIME X470-PRO v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 5204
    date: 07/29/2019
    Info: 8-core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
    rev: 2 cache: L1: 768 KiB L2: 4 MiB L3: 16 MiB
    Speed (MHz): avg: 2241 high: 3200 min/max: 2200/3900 boost: disabled
    cores: 1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2096 8: 2200
    9: 2200 10: 3200 11: 2200 12: 2200 13: 2065 14: 2200 15: 2109 16: 2200
    bogomips: 124566
    Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 570.172.08
    arch: Turing bus-ID: 09:00.0
    gpu: nvidia,nvidia-nvswitch resolution: 1: 2560x1440~60Hz
    2: 2560x1440~60Hz
    API: EGL v: 1.5 drivers: nouveau,nvidia,swrast platforms:
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.172.08
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
    Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 09:00.1
    Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 0b:00.3
    Device-3: Cambridge Silicon Radio B10Pro
    driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 5-3.1:4
    API: ALSA v: k6.8.0-85-generic status: kernel-api
    Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    port: e000 bus-ID: 07:00.0
    IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 2.51 TiB used: 847.38 GiB (33.0%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 250GB
    size: 232.89 GiB temp: 37.9 C
    ID-2: /dev/sda vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
    ID-3: /dev/sdb vendor: Western Digital model: WD20EZBX-00AYRA0
    ID-4: /dev/sdc vendor: Samsung model: SSD 840 EVO 250GB size: 232.89 GiB
    ID-1: / size: 237.47 GiB used: 52.54 GiB (22.1%) fs: btrfs dev: /dev/sda2
    ID-2: /boot/efi size: 96 MiB used: 37.4 MiB (38.9%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-3: /home size: 237.47 GiB used: 52.54 GiB (22.1%) fs: btrfs
    dev: /dev/sda2
    System Temperatures: cpu: 34.6 C mobo: 34.0 C gpu: nvidia temp: 50 C
    Fan Speeds (rpm): cpu: 824 case-1: 890 case-2: 0 case-3: 799 gpu: nvidia
    fan: 0%
    Power: 12v: 12.10 5v: N/A 3.3v: N/A vbat: N/A
    Memory: total: 64 GiB note: est. available: 62.71 GiB used: 6.04 GiB (9.6%)
    Processes: 446 Uptime: 3m Init: systemd target: graphical (5)
    Packages: 2340 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Guten Abend,
    ich habe eine Frage, die mich schon seit gefühlt Hunderten Installationen quält. Nach der Installation boote ich in das neue System, melde mich an, und dann... kann ich auf dem desktop keinen Rechtsklick ausfühen( um z.B. das Hintergrundbild zu ändern ) Tastatureingaben ( z.B. in einem Editor ) gehen auch nicht. Das System zeigt dieses Zeichen ( unten Mitte )
    Zur Abhilfe kann ich strg alt f2 drücken um auf eine Konsole zu wechseln, dann wieder zurück strg alt f7 - nun funktioniert alles. Kommt aber manchmal wieder!
    Im internet hab ich mal ne Lösung gefunden:
    sudo nano /usr/lib/udev/rules.d/97-hid2hci.rules
    Scroll to the bottom and find
    # CSR devices
    ATTR{idVendor}=="0a12|0458|05ac", ATTR{idProduct}=="1000", RUN+="hid2hci --method=csr --devpath=%p"
    Just below that add
    # CSR2 devices
    ATTR{idVendor}=="0a12", ATTR{idProduct}=="4007", RUN+="hid2hci --method=csr2 --devpath=%p"
    LABEL="hid2hci_end"
    Save, exit editor and reboot
    Das funktioniert anscheinend, aber was tue ich da eigendlich? Woran kann das liegen? Und ist das die richtige Vorgehensweise?
    Vielen Dank falls das Problem einer kennt.
  • Das Problem, das du beschreibst – kein Maus-Rechtsklick oder Tastatureingaben, bis du kurz auf eine andere TTY (z. B. Strg+Alt+F2) und zurück wechselst – hängt mit einem bekannten Bluetooth-/USB-Treiberproblem zusammen, das bestimmte Dongles betrifft, vor allem solche mit CSR-Chipsatz (Vendor-ID 0a12)
    Viele Bluetooth-USB-Sticks mit CSR-Chipsatz starten beim Booten im HID-Modus (Human Interface Device), um z. B. eine Bluetooth-Tastatur für das BIOS nutzbar zu machen. Unter Linux muss der Treiber jedoch den Stick in den HCI-Modus (Host Controller Interface) schalten, damit er korrekt als Bluetooth-Adapter funktioniert.
    Dieser Übergang wird normalerweise automatisch durch hid2hci gesteuert, das über die udev-Regeldatei /usr/lib/udev/rules.d/97-hid2hci.rules ausgeführt wird .
    Wenn dein Gerät aber eine leicht andere Produkt-ID verwendet (z. B. 0a12:4007 anstatt 0a12:1000 ), wird es von der Originalregel nicht erkannt – daher bleibt der Stick im falschen Modus und verursacht Einfrierungen oder fehlende Eingaben.
    Die Zeile, die du ergänzt hast:
    weist udev an, beim Systemstart dein CSR-Gerät automatisch aus HID- in HCI-Modus umzuschalten, indem der hid2hci Befehl mit der Methode csr2 ausgeführt wird.
    Damit funktioniert die Bluetooth-Kommunikation korrekt und der Bug tritt nicht mehr auf.
    Endgültig lösen kannst du das Problem, in dem du dir einen anderen mehr kompatiblem Bluetooth Dingle organisierst. Oder deine Peripherie per Kabel verbindest.
  • Hi
    Das ist ein Problem was aber vielfach bei Logitech auftritt wenn nicht die Original unifying Empfänger verwendet werden sondern normale Bluetooth Empfänger oder. ?
    Ist dir das schon mal anders untergekommen kim88 ?
    Gruß
  • Die Logitech Empfänger sind doch gar nicht Bluetooth sondern Funk? Keine Ahnung. Ich nutze zwar Logitech Hardware aber alle direkt über Bluetooth. Da ich nur Intel Hardware kaufe und da darauf achte das ich auch immer Intel Wlan/Bluetooth Chips in den Notebooks habe bin ich da nicht so bewandert.
    Intel pflegt die Wlan/Bluetooth Treiber für Linux sehr vorbildlich die funktionieren seit über 10 Jahren absolut einwandfrei. Ohne nachträglich irgendwas konfigurieren oder basteln zu müssen Out-of-the-Box mit dem Kernel.
  • Stimmt viele sind per Funk, aber die MX Serie kann beides wenn ich das richtig im Kopf habe.
    Die Intel Sachen verwende ich meist auch mit allen anderen vor allem Asus habe ich nur negative Erfahrungen gesammelt.
    Naja war nur rein Interesse halber.
    Ich bin wie immer zu Neugierig.;)
    thx
  • Ehrlich gesagt weiss ich nicht ob Intel Dongels verkauft. Intel W-Lan Module haben heute eigentlich Bluetooth immer direkt integriert. Aber es gibt sicherlich Dongles die dieses Problem nicht haben.
  • Was ich nicht verstehe: Wenn ich ein OS neu installiere, dann müssten dabei ja schon Treiberprobleme auftreten.
    Des weiteren sehe ich nach einer Installation nicht mehr das Installscript auf dem Desktop, sondern einen leeren Desktop oder Home und Papierkorb etc., warum ist auf dem Screenshot dann das Installscript zu sehen?
    Auch kann ich das Sperrsymbol unten nicht einem Treiberproblem zuordnen.
  • das kann ichso bestätigen mein usb mikrofon wird als hiddevice gemountet statt als mikrofon das behindert das booten immer leicht
    Immer schön Cremig bleiben!:)
