- Distrowahl
- Linux Mint
- System:
Kernel: 5.15.0-157-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Laptop System: Dell product: Precision M4800 v: 00
serial: <superuser required>
Mobo: Dell model: 0V5GVY v: A00 serial: <superuser required> UEFI: Dell
v: A15 date: 09/29/2015
Battery:
ID-1: BAT0 charge: 31.6 Wh (48.4%) condition: 65.3/86.6 Wh (75.5%)
volts: 10.8 min: 11.1 model: Samsung SDI DELL P8TC727 status: Discharging
Info: quad core model: Intel Core i7-4810MQ bits: 64 type: MT MCP
arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 2794 high: 2797 min/max: 800/3800 cores: 1: 2793
2: 2794 3: 2794 4: 2794 5: 2794 6: 2794 7: 2794 8: 2797 bogomips: 44694
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GK106GLM [Quadro K2100M] vendor: Dell driver: nvidia
v: 390.157 bus-ID: 01:00.0
Device-3: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:3
Display: x11 server: X.Org v: 1.21.1.4 driver: X:
loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa gpu: i915
resolution: 1920x1080~60Hz
OpenGL: renderer: Quadro K2100M/PCIe/SSE2 v: 4.6.0 NVIDIA 390.157
direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
Device-3: NVIDIA GK106 HDMI Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.15.0-157-generic running: yes
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0
Device-2: Broadcom BCM4352 802.11ac Wireless Network Adapter vendor: Dell
driver: wl v: kernel bus-ID: 03:00.0
RAID:
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 bus-ID: 00:1f.2
Local Storage: total: 1.6 TiB used: 1.61 TiB (100.5%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ACF050 size: 465.76 GiB
ID-2: /dev/sdb vendor: Micron model: M600 MSATA 256GB size: 238.47 GiB
ID-3: /dev/sdc type: USB vendor: A-Data model: SE880 size: 931.51 GiB
ID-1: / size: 915.32 GiB used: 381.25 GiB (41.7%) fs: ext4 dev: /dev/sdc2
ID-2: /boot/efi size: 507 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/sdc1
System Temperatures: cpu: 45.0 C mobo: 47.0 C sodimm: SODIMM C gpu: nvidia
temp: 53 C
Fan Speeds (RPM): cpu: 2080
Processes: 340 Uptime: 2h 38m Memory: 15.52 GiB used: 4.42 GiB (28.5%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 3931 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Hallo zusammen,
wollte heute mein Linux-Mint 21.3 auf eine neue Version 22 mit dem Tool mintupgrate updaten. Bekomme relativ am Anfang die Fehlermeldung "Das Depot »https://download.docker.com/linux/ubuntu virginia Release« enthält keine Release-Datei."
Habe das apt update ausgeführt. Bringt leider nichts. Gleiche Fehlermeldung.
Was mache ich da?
Gruß Holger
