Menüfeld nicht mehr sichtbar
    Linux Mint
    Kernel: 6.14.0-33-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Laptop System: Acer product: Swift SF315-52G v: V1.08
    serial: <superuser required>
    Mobo: KBL model: Erdinger_KL v: V1.08 serial: <superuser required>
    UEFI: American Megatrends v: 1.08 date: 12/21/2018
    Battery:
    ID-1: BAT0 charge: 34.7 Wh (100.0%) condition: 34.7/48.9 Wh (71.0%)
    volts: 16.4 min: 15.2 model: AC17B8K status: full
    Info: quad core model: Intel Core i7-8550U bits: 64 type: MT MCP
    arch: Coffee Lake rev: A cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 3409 high: 4001 min/max: 400/4000 cores: 1: 4000 2: 4001
    3: 400 4: 3934 5: 3500 6: 4000 7: 3738 8: 3703 bogomips: 31999
    Device-1: Intel UHD Graphics 620 vendor: Acer Incorporated ALI driver: i915
    v: kernel arch: Gen-9.5 bus-ID: 00:02.0
    Device-2: NVIDIA GP108M [GeForce MX150] vendor: Acer Incorporated ALI
    driver: nvidia v: 550.163.01 arch: Maxwell bus-ID: 01:00.0
    Device-3: Chicony HD WebCam driver: uvcvideo type: USB bus-ID: 1-7:5
    loaded: modesetting,nvidia unloaded: fbdev,nouveau,vesa dri: iris gpu: i915
    resolution: 3840x2160~60Hz
    API: EGL v: 1.5 drivers: iris,nouveau,nvidia,swrast platforms:
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.163.01
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce MX150/PCIe/SSE2
    Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
    driver: snd_soc_avs v: kernel bus-ID: 00:1f.3
    API: ALSA v: k6.14.0-33-generic status: kernel-api
    Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
    IF: wlp2s0 state: up mac: <filter>
    IF-ID-1: surfshark_ipv6 state: unknown speed: N/A duplex: N/A
    mac: <filter>
    IP v6: <filter> type: noprefixroute scope: global
    IF-ID-2: surfshark_wg state: unknown speed: N/A duplex: N/A mac: N/A
    IP v4: <filter> type: noprefixroute scope: global
    Bluetooth:
    Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    bus-ID: 1-6:3
    Report: hciconfig ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
    lmp-v: 8
    RAID:
    Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 bus-ID: 00:17.0
    Local Storage: total: 476.94 GiB used: 34.62 GiB (7.3%)
    ID-1: /dev/sda vendor: Intenso model: SSD size: 476.94 GiB
    ID-1: / size: 467.89 GiB used: 34.61 GiB (7.4%) fs: ext4 dev: /dev/sda2
    System Temperatures: cpu: 61.0 C pch: 54.0 C mobo: N/A gpu: nvidia
    temp: 54 C
    Fan Speeds (rpm): N/A
    Memory: total: 20 GiB available: 19.41 GiB used: 3.79 GiB (19.5%)
    Processes: 317 Uptime: 14m Init: systemd target: graphical (5)
    Packages: 2119 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Wenn ich unten links den Linux Knopf drücke sehe ich plötzlich nur noch die oberen 3 Zeilen der Menüauswahl. Es sieht aus als wäre es nach unten verschoben. Was kann ich da tun?
