Dolphin erkennt Festplatten nicht
    Linux Mint
    Kernel: 6.14.0-33-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Mobo: ASUSTeK model: TUF GAMING B850-PLUS WIFI v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1079
    date: 07/21/2025
    Info: 8-core model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: N/A
    rev: 0 cache: L1: 640 KiB L2: 8 MiB L3: 96 MiB
    Speed (MHz): avg: 2254 high: 5246 min/max: 600/5271 boost: enabled cores:
    1: 5204 2: 603 3: 3892 4: 5224 5: 603 6: 5244 7: 5246 8: 603 9: 5232 10: 603
    11: 603 12: 603 13: 603 14: 603 15: 603 16: 603 bogomips: 150108
    Device-1: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0
    Device-2: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 0e:00.0
    temp: 36.0 C
    loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
    gpu: amdgpu resolution: 1920x1080~60Hz
    Radeon Graphics (radeonsi gfx1201 LLVM 20.1.2 DRM 3.61 6.14.0-33-generic)
    Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
    Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0e:00.1
    Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0e:00.6
    Device-4: DSEA A/S EPOS GSX 300 driver: hid-generic,snd-usb-audio,usbhid
    type: USB bus-ID: 5-1.1:4
    API: ALSA v: k6.14.0-33-generic status: kernel-api
    Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    port: d000 bus-ID: 09:00.0
    Device-2: Realtek vendor: AzureWave driver: rtw89_8922ae v: kernel
    port: c000 bus-ID: 0a:00.0
    IF: wlp10s0 state: down mac: <filter>
    Bluetooth:
    Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
    bus-ID: 1-6:3
    lmp-v: 12
    Local Storage: total: 25.47 TiB used: 2.32 TiB (9.1%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 4TB size: 3.64 TiB
    temp: 28.9 C
    ID-2: /dev/sda vendor: Western Digital model: WD60EZAX-00C8VB0
    ID-3: /dev/sdb vendor: Western Digital model: WD60EZAX-00C8VB0
    ID-4: /dev/sdc vendor: Crucial model: CT4000BX500SSD1 size: 3.64 TiB
    ID-5: /dev/sdd vendor: Samsung model: SSD 870 QVO 8TB size: 7.28 TiB
    ID-1: / size: 3.58 TiB used: 26.33 GiB (0.7%) fs: ext4 dev: /dev/nvme0n1p2
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 44.5 C mobo: N/A
    Fan Speeds (rpm): N/A
    GPU: device: amdgpu temp: 30.0 C fan: 0 device: amdgpu temp: 37.0 C
    Memory: total: 48 GiB note: est. available: 46.22 GiB used: 3.64 GiB (7.9%)
    Processes: 407 Uptime: 44m Init: systemd target: graphical (5)
    Packages: 2228 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo an Alle!
    Kleines Problem (hoffentlich), bin gerade zu Mint gewechselt, zuvor Windows seit 95, also alles neu und schwerer als gedacht.
    Habe Dolphin über die Softwareverwaltung installiert da mir das Gruppieren von Dateien doch arg fehlt und Dolphin hier auch deswegen genannt wurde. Soweit alles gut solange ich mich auf der Systemfestplatte befinde. Sobald ich jedoch eine andere Festplatte mit Dolphin aufrufe kommt eine Fehlermeldung. "Die Datei oder der Ordner /mnt/datagrab existiert nicht."
    Nemo kann auf sämtliche Festplatten zugreifen und sie wurden alle über 'Laufwerke' eingebunden (automatisch bei Systemstart). Ideen?
    Schonmal vielen Dank, Grüsse, Klaus
  • Ein Dateimanager gräbt sich tief ins System ein Ich würde jeweils den zum System gehörenden nutzen, oder auf jeden Fall installiert lassen.
    Dolphin = Qt und
    Nemo = Gtk
    Deshalb passt Dolphin nicht soo gut in Cinnamon ein.
    Ist aber nur meine Meinung, der hier bestimmt gleich widersprochen wird.
  • Hast Du '/mnt/datagrab' denn schon erstellt?
    Denke schon, siehe Screenshot und mit Nemo kann ich ja drauf zugreifen...
    Dolphin = Qt und
    Nemo = Gtk
    Würde Nemo ja gerne nutzen, gefällt mir auch besser, wenn ich doch nur irgendwie die Dateien gruppieren könnte, in Nemo sieht das alles so chaotisch aus und die Funktion vermiss ich echt...
  • Ja Ok.
    Hast Du Dir mal die Listenansicht bei Nemo angesehen. Ok, so wie bei Dolphin wird es nicht aussehen. Es wird nur sortiert (ohne die Striche dazwischen).
    Ich habe eben auch kein System mit Nemo laufen, sonst würde ich mal nachsehen. Vielleicht Morgen.
  • Das Schöne an der gruppierten Ansicht ist einerseits die Übersichtlichkeit, andererseits kann man auf den Miniaturansichten grob erkennen was die Bilder darstellen zum bearbeiten etc. Hab auch noch keine Möglichkeit in Nemo gefunden eine ähnliche Seitenleiste mit Detailinformationen wie in Dolphin auf der rechten Seite aufzurufen. Vielleicht wäre dies eine Möglichkeit.
    Bin für jede Hilfe dankbar, aber bitte nicht stressen
  • Hmm. Am besten nochmal ls -la /mnt/
    Die Ausgabe bitte im Codeblock posten, von Prompt zu Prompt.
    klaus@Desk-K:~$ ls -la /mnt/
    insgesamt 28
    drwxr-xr-x  7 root  root  4096 Sep 30 21:28  .
    drwxr-xr-x 23 root  root  4096 Sep 29 16:36  ..
    drwxr-xr-x  2 root  root  4096 Sep 29 21:47  15f72c25-d0e2-4c45-acb0-7627d3614784
    drwx------  4 klaus klaus 4096 Sep 30 21:28  data
    drwx------  3 klaus klaus 4096 Sep 30 21:28  datagrab
    drwx------  4 klaus klaus 4096 Sep 29 15:27 'Steam Data'
    drwx------  4 klaus klaus 4096 Sep 30 21:28  SteamDataZwo8TB
    klaus@Desk-K:~$
    So richtig?
  • Wenn Du weißt, wie man eine Sicherungskopie von /etc/fstab anlegt und bei Bedarf über ein Notfallsystem (vom Stick gebootet) wieder herstellt, könntest Du versuchen, den Eintrag in Zeile 16 mit diesem zu ersetzen:
    UUID=7a72a0cd-a3c9-47a4-995d-31d3ebcdaf9a /mnt/datagrab  auto  defaults,nofail,noatime  0  2
    Aber aufgepasst! Veränderungen an der /etc/fstab können dazu führen, dass das System nicht mehr startet.
    Sorry, das trau ich mir nicht zu, bin erst seit paar Tagen dabei und so wichtig ist es dann auch nicht wenn die Gefahr besteht mir das System zu zerschießen. Wäre schön gewesen aber dann muss ich mich irgendwie anders arrangieren.
    Vielen Dank für Deine Hilfe!
  • Nur als Idee, ich benutze weder Nemo noch Dolphin.
    Ist Dolphin als Flatpak installiert? Vielleicht mal flatpak list posten.
    Das war die Lösung, war als Flatpack installiert. Jetzt als Systempaket installiert und alles läuft wie es soll, Top.
    Vielen Dank :) ... an Alle :thumbup:
