- Distrowahl
- Linux Mint
- System:
Kernel: 6.14.0-33-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Mobo: ASUSTeK model: TUF GAMING B850-PLUS WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1079
date: 07/21/2025
Info: 8-core model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: N/A
rev: 0 cache: L1: 640 KiB L2: 8 MiB L3: 96 MiB
Speed (MHz): avg: 2254 high: 5246 min/max: 600/5271 boost: enabled cores:
1: 5204 2: 603 3: 3892 4: 5224 5: 603 6: 5244 7: 5246 8: 603 9: 5232 10: 603
11: 603 12: 603 13: 603 14: 603 15: 603 16: 603 bogomips: 150108
Device-1: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0
Device-2: AMD vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 0e:00.0
temp: 36.0 C
loaded: amdgpu unloaded: fbdev,modesetting,radeon,vesa dri: radeonsi
gpu: amdgpu resolution: 1920x1080~60Hz
Radeon Graphics (radeonsi gfx1201 LLVM 20.1.2 DRM 3.61 6.14.0-33-generic)
Device-1: AMD driver: snd_hda_intel v: kernel bus-ID: 03:00.1
Device-2: AMD Rembrandt Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0e:00.1
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 0e:00.6
Device-4: DSEA A/S EPOS GSX 300 driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 5-1.1:4
API: ALSA v: k6.14.0-33-generic status: kernel-api
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
port: d000 bus-ID: 09:00.0
Device-2: Realtek vendor: AzureWave driver: rtw89_8922ae v: kernel
port: c000 bus-ID: 0a:00.0
IF: wlp10s0 state: down mac: <filter>
Bluetooth:
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 1-6:3
lmp-v: 12
Local Storage: total: 25.47 TiB used: 2.32 TiB (9.1%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 990 PRO 4TB size: 3.64 TiB
temp: 28.9 C
ID-2: /dev/sda vendor: Western Digital model: WD60EZAX-00C8VB0
ID-3: /dev/sdb vendor: Western Digital model: WD60EZAX-00C8VB0
ID-4: /dev/sdc vendor: Crucial model: CT4000BX500SSD1 size: 3.64 TiB
ID-5: /dev/sdd vendor: Samsung model: SSD 870 QVO 8TB size: 7.28 TiB
ID-1: / size: 3.58 TiB used: 26.33 GiB (0.7%) fs: ext4 dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
System Temperatures: cpu: 44.5 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 30.0 C fan: 0 device: amdgpu temp: 37.0 C
Memory: total: 48 GiB note: est. available: 46.22 GiB used: 3.64 GiB (7.9%)
Processes: 407 Uptime: 44m Init: systemd target: graphical (5)
Packages: 2228 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo an Alle!
Kleines Problem (hoffentlich), bin gerade zu Mint gewechselt, zuvor Windows seit 95, also alles neu und schwerer als gedacht.
Habe Dolphin über die Softwareverwaltung installiert da mir das Gruppieren von Dateien doch arg fehlt und Dolphin hier auch deswegen genannt wurde. Soweit alles gut solange ich mich auf der Systemfestplatte befinde. Sobald ich jedoch eine andere Festplatte mit Dolphin aufrufe kommt eine Fehlermeldung. "Die Datei oder der Ordner /mnt/datagrab existiert nicht."
Nemo kann auf sämtliche Festplatten zugreifen und sie wurden alle über 'Laufwerke' eingebunden (automatisch bei Systemstart). Ideen?
Schonmal vielen Dank, Grüsse, Klaus
