- wolfgang@wolfgang-HP-250-G8-Notebook-PC:~$ inxi -Fzxi
Kernel: 5.15.0-156-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
Desktop: Cinnamon 6.0.4 Distro: Linux Mint 21.3 Virginia
base: Ubuntu 22.04 jammy
Type: Laptop System: HP product: HP 250 G8 Notebook PC
v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 881D v: 50.34 serial: <superuser required> UEFI: Insyde
v: F.62 date: 07/04/2023
Battery:
ID-1: BAT1 charge: 41.1 Wh (100.0%) condition: 41.1/41.0 Wh (100.1%)
volts: 12.8 min: 11.3 model: Hewlett-Packard PABAS0241231 status: Full
Info: dual core model: 11th Gen Intel Core i3-1115G4 bits: 64 type: MT MCP
arch: Tiger Lake rev: 1 cache: L1: 160 KiB L2: 2.5 MiB L3: 6 MiB
Speed (MHz): avg: 966 high: 1047 min/max: 400/4100 cores: 1: 819 2: 979
3: 1047 4: 1021 bogomips: 23961
Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel
bus-ID: 0000:00:02.0
Device-2: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-5:2
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: modesetting
unloaded: fbdev,vesa gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT2)
v: 4.6 Mesa 23.2.1-1ubuntu3.1~22.04.3 direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3
Sound Server-1: ALSA v: k5.15.0-156-generic running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 4000
bus-ID: 0000:01:00.0
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A port: 3000
bus-ID: 0000:02:00.0
IF: wlo1 state: up mac: <filter>
Bluetooth:
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:3
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 3.0 lmp-v: 5.1
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 0000:00:0e.0
Local Storage: total: 476.94 GiB used: 94.11 GiB (19.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital
model: WD PC SN740 SDDPNQD-512G-1006 size: 476.94 GiB temp: 39.9 C
ID-1: / size: 467.89 GiB used: 94.08 GiB (20.1%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 31.6 MiB (6.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 2 GiB used: 1.2 MiB (0.1%) file: /swapfile
System Temperatures: cpu: 27.8 C mobo: 10.0 C
Fan Speeds (RPM): N/A
Processes: 267 Uptime: 1h 2m Memory: 7.5 GiB used: 2.42 GiB (32.3%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2460 Shell: Bash
v: 5.1.16 inxi: 3.3.13
Hallo zusammen,
nachdem ich schon drei Rechner von LinuxMint 22.1 auf LM22.2 „upgedated“ habe, wollte ich den vierten Rechner (Notebook) auch auf LM 22 aktualisieren.
Da auf dem Notebook aktuell noch LM21.3 installiert ist, bin ich wie im Video von Jean gezeigt vorgegangen um von LM21 auf LM 22 zu aktualisierten.
Ich habe Mintupgrade installiert und im Terminal mit sudo mintupgrade das Ganze gestartet.
Das Problem ist, der Upgradeprozess kommt beim Prüfen des apt-Puffers nicht weiter (s. Bild apt).
Wie dort geschrieben, habe ich apt update gestartet (zweites Terminalfenster geöffnet, Bild apt update) . Auch da ist nach dem „erneut Prüfen“ das gleiche Bild. Irgendwie sucht er Dateien für Skype, das es gar nicht mehr geben sollte.
Auf diesem Notebook hatte ich in der Vergangenheit auch Skype genutzt.
Skype hatte ich seinerzeit über die Anwendungsverwaltung installiert und nach Ende von Skype auch wieder über die Anwendungsverwaltung deinstalliert.
Trotzdem kommt auch seit dem Deinstallieren von Skype beim Aktualisieren immer folgende Fehlermeldung in der Aktualisierungsverwaltung:
Schießt man dieses Fenster, dann geht der Aktualisierungsprozess weiter. S. Bild Aktualisierung
Unter Anwendungen ist Skype nicht mehr zu finden.
Gehe ich in die Anwendungsverwaltung, dann wird seltsamerweise Skype noch zur Installation angeboten, es ist zu sehen, das Skype nicht installiert ist, aber nach obiger Fehlermeldung scheint was übrig geblieben zu sein.
Wie weiter vorgehen? Lässt sich das einfach zu beheben, oder ist es besser den Installationsstick zu nutzen.
Das Betriebssystem ist Linux Mint 21.3 Cinnamon, Version 6.0.4;
Linux-Kerrnel 5.15.0-156-generic:
