- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-83-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Laptop System: LENOVO product: 20U50063GE v: ThinkPad L14 Gen 1
serial: <superuser required>
Mobo: LENOVO model: 20U50063GE v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: R19ET42W (1.26 )
date: 05/27/2022
Battery:
ID-1: BAT0 charge: 17.9 Wh (44.9%) condition: 39.9/45.7 Wh (87.2%)
volts: 11.0 min: 11.1 model: SMP LNV-5B10W13896 status: discharging
Info: 6-core model: AMD Ryzen 5 PRO 4650U with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
Speed (MHz): avg: 1399 high: 1400 min/max: 1400/2100 boost: enabled cores:
1: 1400 2: 1400 3: 1400 4: 1400 5: 1397 6: 1400 7: 1397 8: 1400 9: 1400
10: 1400 11: 1400 12: 1400 bogomips: 50303
Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu
v: kernel arch: GCN-5 bus-ID: 06:00.0 temp: 31.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB bus-ID: 4-3:2
resolution: 3072x1728~60Hz
Radeon Graphics (radeonsi renoir ACO DRM 3.57 6.8.0-83-generic)
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 06:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
bus-ID: 06:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 06:00.6
API: ALSA v: k6.8.0-83-generic status: kernel-api
vendor: Lenovo RTL8111/8168/8411 driver: r8169 v: kernel port: 2400
bus-ID: 02:00.0
IF: enp2s0f0 state: down mac: <filter>
Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel bus-ID: 03:00.0
Bluetooth:
Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
type: USB bus-ID: 4-4:3
Report: hciconfig ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 5.2
lmp-v: 11
Local Storage: total: 238.47 GiB used: 218.31 GiB (91.5%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFS256GDE9X081N
size: 238.47 GiB temp: 35.9 C
ID-1: / size: 233.18 GiB used: 218.3 GiB (93.6%) fs: ext4
dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
System Temperatures: cpu: 32.8 C mobo: N/A gpu: amdgpu temp: 32.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 14.99 GiB used: 6.31 GiB (42.1%)
Processes: 412 Uptime: 11h 13m Init: systemd target: graphical (5)
Packages: 2774 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo Forum,
ich weiß nicht, ob ich meine Frage im richtigen Unterforum stelle - wusste aber nicht, wo ich sie sonst platzieren soll.
Ich arbeite jetzt ca. 2 Jahren mit Linux Mint auf meinem Lenovo L14 und bin soweit sehr glücklich damit.
Mittlerweile hatte ich aber öfter Probleme, weil mein Festplattenspeicher aufgebraucht war und dadurch seltsame Fehlermeldungen auftauchten.
Darum habe ich jetzt mal geguckt, ob ich eine zweite Festplatte in das Thinkpad L14 einbauen könnte - geht nicht.
Einzige Möglichkeit, die alte 250GB PCIe-SSD zu tauschen.
Davor habe ich aber ziemlich Respekt und deshalb meine Frage: Wie würdet ihr da vorgehen?
Kann man mit Timeshift alle Daten extern sichern und wieder aufspielen?
Kann man das vorhandene System (LM 22.1) genauso mit allen Einstellungen wieder einspielen?
Oder was ist eurer Ansicht nach der beste Weg?
Gibt es vielleicht sogar in den unendlichen Weiten des Netzes eine Schritt-für-Schritt-Anleitung?
Vielen Dank für eure Mühe
LG
Immiperium
