Fedora 42: Fehler beim Aktualisieren in der Konsole wegen Multimedia und Codecs
    Fedora
    Kernel: 6.16.7-201.blu.fc42.x86_64 arch: x86_64 bits: 64 compiler: gcc
    v: 15.2.1
    Desktop: KDE Plasma v: 6.4.5 Distro: Fedora Linux 42 (KDE Plasma Desktop
    Edition)
    Type: Desktop Mobo: Micro-Star model: MAG X570 TOMAHAWK WIFI (MS-7C84)
    v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: 1.J0
    date: 09/04/2025
    Info: 12-core model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
    rev: 0 cache: L1: 768 KiB L2: 6 MiB L3: 64 MiB
    Speed (MHz): avg: 3600 min/max: 563/4674 boost: enabled cores: 1: 3600
    2: 3600 3: 3600 4: 3600 5: 3600 6: 3600 7: 3600 8: 3600 9: 3600 10: 3600
    11: 3600 12: 3600 13: 3600 14: 3600 15: 3600 16: 3600 17: 3600 18: 3600
    19: 3600 20: 3600 21: 3600 22: 3600 23: 3600 24: 3600 bogomips: 182405
    Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a
    ssse3 svm
    Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
    7800 XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3
    bus-ID: 2f:00.0
    Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB bus-ID: 5-3.3:3
    Display: wayland server: Xwayland v: 24.1.8 compositor: kwin_wayland
    driver: gpu: amdgpu resolution: 3440x1440~144Hz
    API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.0.2 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi navi32 LLVM
    20.1.1 DRM 3.64 6.16.7-201.blu.fc42.x86_64)
    API: Vulkan v: 1.4.313 drivers: radv,llvmpipe surfaces: N/A devices: 2
    de: kscreen-console,kscreen-doctor wl: wayland-info x11: xdriinfo,
    xdpyinfo, xprop, xrandr
    Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    driver: snd_hda_intel v: kernel bus-ID: 2f:00.1
    Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 31:00.4
    Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    API: ALSA v: k6.16.7-201.blu.fc42.x86_64 status: kernel-api
    Server-1: PipeWire v: 1.4.8 status: active
    Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel port: f000 bus-ID: 26:00.0
    IF: enp38s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Bluetooth:
    Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 1-4:2
    Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11
    Local Storage: total: 7.51 TiB used: 3.31 TiB (44.1%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB
    temp: 35.9 C
    ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 2TB
    size: 1.82 TiB temp: 29.9 C
    ID-3: /dev/sda vendor: Samsung model: SSD 850 EVO 1TB size: 931.51 GiB
    temp: 25 C
    ID-4: /dev/sdb vendor: Western Digital model: WD20EZBX-00AYRA0
    size: 1.82 TiB temp: 29 C
    ID-5: /dev/sdc vendor: Western Digital model: WD20EZBX-00AYRA0
    size: 1.82 TiB temp: 30 C
    ID-6: /dev/sdd vendor: Samsung model: SSD 850 PRO 256GB size: 238.47 GiB
    temp: 24 C
    ID-1: / size: 930.51 GiB used: 29.49 GiB (3.2%) fs: btrfs
    dev: /dev/nvme0n1p2
    ID-2: /boot/efi size: 1022 MiB used: 19.3 MiB (1.9%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-3: /home size: 930.51 GiB used: 29.49 GiB (3.2%) fs: btrfs
    dev: /dev/nvme0n1p2
    ID-4: /opt size: 930.51 GiB used: 29.49 GiB (3.2%) fs: btrfs
    dev: /dev/nvme0n1p2
    ID-5: /var/log size: 930.51 GiB used: 29.49 GiB (3.2%) fs: btrfs
    dev: /dev/nvme0n1p2
    ID-6: /var/tmp size: 930.51 GiB used: 29.49 GiB (3.2%) fs: btrfs
    dev: /dev/nvme0n1p2
    ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
    System Temperatures: cpu: 41.1 C mobo: 35.5 C gpu: amdgpu temp: 57.0 C
    Fan Speeds (rpm): N/A gpu: amdgpu fan: 2
    Memory: total: 32 GiB available: 31.25 GiB used: 3.83 GiB (12.3%)
    Processes: 564 Uptime: 9m Init: systemd target: graphical (5)
    Packages: 29 note: see --rpm Compilers: N/A Shell: Bash v: 5.2.37
    inxi: 3.3.39
    Ich habe mir vor ein paar Tagen Fedora 42 KDE installiert. Bei der Konfiguration nach der Installation habe ich dann die RPM-Fusion-Repos aktiviert und Multimdeia und Codecs nachinstalliert. Dabei bin ich wie immer nach Anleitung bei Fedora vorgegangen.
    Configuration - RPM Fusion
    Howto/Multimedia - RPM Fusion
    Alles hat wunderbar geklappt. Doch nun werden mir Fehlermeldungen beim Aktualisieren von Fedora per Konsole angezeigt. Für mich sieht das so aus, als wären zwar neue Pakete verfügbar, die allerdings noch nicht auf den RPM-Fusion-Repos zu finden sind. Kann das sein? Was meint ihr?
  • Alles hat wunderbar geklappt. Doch nun werden mir Fehlermeldungen beim Aktualisieren von Fedora per Konsole angezeigt. Für mich sieht das so aus, als wären zwar neue Pakete verfügbar, die allerdings noch nicht auf den RPM-Fusion-Repos zu finden sind. Kann das sein? Was meint ihr?
    - nichts stellt
    Wird angeboten aber steht noch nicht zur Verfügung.
    Interne Indexierung nicht verfügbar. :?:
  • Wird angeboten aber steht noch nicht zur Verfügung.
    Dachte ich es mir doch. Also einfach etwas abwarten und dann sollten die Pakete auch aktualisiert werden. :)
    Was genau meinst du damit? Kann ich oder mein System da etwas ändern? :/
  • DenalB September 22, 2025 at 12:05 PM
  • Dachte ich es mir doch. Also einfach etwas abwarten und dann sollten die Pakete auch aktualisiert werden. :)
    Hi @DenalB
    Nein da kannst du nichts dran machen die haben das intern falsch aufgelöst und zugeordnet meines Erachtens.
    Warte ein bisschen das wird denen bald aufgehen. ;)
  • Ich habe dazu gerade ein passendes Thema in der Fedora Community gefunden.
    Mesa update issue : package mesa-vdpau-drivers-freeworld-25.0.2-2.fc42.i686 from rpmfusion-free requires mesa-filesystem(x86-32) = 25.0.2, but none of the providers can be installed
    Hello, Did anybody experience an update issue related to RPM Fusion & Mesa in past days when using Fedora 42 Silverblue ? I’m getting this error when trying…
    discussion.fedoraproject.org
    Das Problem tritt wohl immer auf, wenn es ein Update gibt. Die Entwickler arbeiten dran, dass neue Releases nicht erst durch Testing gehen, sondern direkt in Stable landen.
  • @DenalB
    Das gleiche Problem hatte ich übrigens auch. Mit dem ersten (oder war es beim zweiten?) "dnf upgrade" wurden dann auch die entsprechenden Pakete bereit gestellt. Also alles gut 👨🏻‍💻
  • Dauert im aktuellen Fall leider etwas länger. Aktuell wurden die Updates noch nicht bereitgestellt ... Also weiter warten.
  • Soeben konnte ich die Mesa Updates installieren. sudo dnf upgrade --refresh funktionierte. Direkt vorher noch ohne --refresh klappte es nicht.
    Also alles wieder gut. :)
  • sudo dnf upgrade --refresh
    Da habe ich ja zwecks Aktualisierung genau den "richtigen" Befehl zum alias in der .bashrc genommen.
    tux@fedora:~$ cat .bashrc | grep dnfup
    alias dnfup='sudo dnf upgrade --refresh -y && flatpak update'
    Thema erledigt
  • Da habe ich ja zwecks Aktualisierung genau den "richtigen" Befehl zum alias in der .bashrc genommen.
    Mein Alias ist farbiger und länger ... :D
    Aber "dnfup" ist cool. Hatte bisher "upd". ;)
    So mache ich es auch immer und bin immer gut gefahren sudo dnf upgrade --refresh.
