- Distrowahl
- Linux Mint
- volker@volker-A320M-S2H:~$ inxi -Fzxi
Kernel: 6.8.0-79-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop System: Gigabyte product: A320M-S2H v: N/A
serial: <superuser required>
Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F50 date: 11/28/2019
Info: quad core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB L2: 2 MiB
L3: 4 MiB
Speed (MHz): avg: 1346 high: 1400 min/max: 1400/3600 boost: enabled cores:
1: 1400 2: 1258 3: 1400 4: 1326 bogomips: 28746
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel arch: GCN-5 bus-ID: 07:00.0 temp: 41.0 C
resolution: 1920x1080~60Hz
Radeon Vega 8 Graphics (radeonsi raven ACO DRM 3.57 6.8.0-79-generic)
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 07:00.1
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 07:00.6
API: ALSA v: k6.8.0-79-generic status: kernel-api
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 223.57 GiB used: 22.94 GiB (10.3%)
ID-1: /dev/sda vendor: Innovation IT model: N/A size: 223.57 GiB
ID-1: / size: 218.51 GiB used: 22.94 GiB (10.5%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
System Temperatures: cpu: 41.1 C mobo: 33.0 C gpu: amdgpu temp: 41.0 C
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 13.59 GiB used: 2.14 GiB (15.8%)
Processes: 238 Uptime: 44m Init: systemd target: graphical (5)
Packages: 1960 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
volker@volker-A320M-S2H:~$ ^C
Moin zusammen,
nun will ich Telegram auf Linux installieren, der Code nach dem Doppelklick auf die Datei kommt nicht auf meinem Telefon an. Nichts.
Ich habe von der Telegramseite das Programm geladen und es ist unter Download, zwei Dateien. Nach dem Doppelklick, Eingabe meiner bereitas gegistrierten Nr. ( hatte ich unter Windows 10 ) kommt nicht auf meinem Telefon an.
Wie kann ich Telegram installieren?
Danke im Voraus
