Code von Telegram ( 5 Zahlen ) kommt bei Installation nicht an
    Linux Mint
    volker@volker-A320M-S2H:~$ inxi -Fzxi
    Kernel: 6.8.0-79-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop System: Gigabyte product: A320M-S2H v: N/A
    serial: <superuser required>
    Mobo: Gigabyte model: A320M-S2H-CF v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F50 date: 11/28/2019
    Info: quad core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
    type: MCP arch: Zen/Zen+ note: check rev: 1 cache: L1: 384 KiB L2: 2 MiB
    L3: 4 MiB
    Speed (MHz): avg: 1346 high: 1400 min/max: 1400/3600 boost: enabled cores:
    1: 1400 2: 1258 3: 1400 4: 1326 bogomips: 28746
    Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3
    Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 bus-ID: 07:00.0 temp: 41.0 C
    resolution: 1920x1080~60Hz
    Radeon Vega 8 Graphics (radeonsi raven ACO DRM 3.57 6.8.0-79-generic)
    Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
    v: kernel bus-ID: 07:00.1
    Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 07:00.6
    API: ALSA v: k6.8.0-79-generic status: kernel-api
    vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 06:00.0
    IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    Local Storage: total: 223.57 GiB used: 22.94 GiB (10.3%)
    ID-1: /dev/sda vendor: Innovation IT model: N/A size: 223.57 GiB
    ID-1: / size: 218.51 GiB used: 22.94 GiB (10.5%) fs: ext4 dev: /dev/sda3
    ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat dev: /dev/sda2
    System Temperatures: cpu: 41.1 C mobo: 33.0 C gpu: amdgpu temp: 41.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 16 GiB note: est. available: 13.59 GiB used: 2.14 GiB (15.8%)
    Processes: 238 Uptime: 44m Init: systemd target: graphical (5)
    Packages: 1960 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    volker@volker-A320M-S2H:~$ ^C
    Moin zusammen,
    nun will ich Telegram auf Linux installieren, der Code nach dem Doppelklick auf die Datei kommt nicht auf meinem Telefon an. Nichts.
    Ich habe von der Telegramseite das Programm geladen und es ist unter Download, zwei Dateien. Nach dem Doppelklick, Eingabe meiner bereitas gegistrierten Nr. ( hatte ich unter Windows 10 ) kommt nicht auf meinem Telefon an.
    Wie kann ich Telegram installieren?
    Danke im Voraus
  • Hmmm, es wäre mal ganz gut zu wissen, von welcher Quelle du das Programm installiert hast.
    Fehlermeldungen und eventuell Screenshots wären hier vielleicht auch hilfreich.
    Ich verwende die Web-Version, die funktioniert tadellos.
    Telegram Web
    Access your Telegram messages from any mobile or desktop device.
    web.telegram.org
  • Warum installierst Du Telegramm nicht aus der Anwendungsverwaltung?
    Es ist immer besser die Programme aus den Repos zu nehmen.
  • Mein Vorschlag wäre, dir die Flatpak Version von Telegram zu laden, diese ist auch in der Anwendungsverwaltung von Linux Mint zu finden, auf deinem Telefon nun Telegram öffnen - Einstellungen - Geräte - Desktopgeräte verknüpfen - und dann den QR-Code scannen.
    Dazu muss ggf. in der Anwendungsverwaltung unter Einstellungen (Drei Punkte Menü) Flatpaks (Ungeprüfte Flatpaks anzeigen) eingeschaltet werden. Es ist, in Gegensatz zum angezeigten Text, kein Sicherheitsrisiko.
  • Was kommt aus der Konsole mit dem Befehl raus.
    Da wird nichts rauskommen weil der TE Telegramm nicht installiert haben dürfte, da er bestimmt den Tarball runter geladen hat.
    Siehe Screenshot.
    Die Vorgehensweise von Harry dürfte weiterhelfen.
  • Hallo????
    Leute, wenn ihr hier weiter so mit euren Meldungen nur so losballert, wird der Ersteller wahrscheinlich gar nicht mehr antworten.
    Ich würde mich auch überfordert fühlen an seiner Stelle !
    Also - Geduld und Warten ;)
  • Hallo ihr Lieben,
    vielen Dank für eure Tipps.
    Nein, sondern , wie schön, soo viele Tipps.
    Geladen habe ich Telegram von der offiziellen Telegram-Seite. Wie im Bild von KP59 ist die Datei bei mir angekommen. Ich habe "ungeprüfte Flatpaks anzeigen" markiert, dann erscheint "keine Anwendung zum öffnen von Telegram gefunden."
    "Einstellungen" Telegram am Telefon starten, geht nicht, es ist alt, kann telefonieren und SMS. Ich hatte Telegram auf Windows 10, beim neuen Rechner ging das ganz leicht, Tel.Nr. bestätigen, fertig, alle Kontakte wie gehabt.
    Nun probiere ich es aus der Linux Sammlung.
    Vielen Dank für eure Tipps.
    Edited 2 times, last by VolkerM: aktualisieren (September 16, 2025 at 6:03 PM).
  • Leider kein Code an mein Telefon gesendet. "ungeprüfte Flatpaks" habe ich markiert.
    Nun weiß nich nicht weiter.
    Tablett kaufen und Telegram dort nutzen?
  • OK - ich hatte das noch nie, Telegramm ohne Telegram fähigem Handy.
    Kannst du bitte kurz erklären wie das abläuft?
    Man meldet sich bei Telegram - jetzt mal angenommen in der Web-Version - an und dann soll ein Code an dein Handy geschickt werden?
    Kommt der per SMS, weil Telegramm kannst du ja dort nicht installieren?
    Das müsste doch funktionieren - hast du eventuell deine Nummer in einem falschen Format - +49.... oder so - eingegeben, so das eben kein SMS bei dir ankommt?
    Wie gesagt ich kenne diese Vorgangsweise nicht, darum rate ich mal ins Blaue ...
  • Geladen habe ich Telegram von der offiziellen Telegram-Seite. Wie im Bild von KP59 ist die Datei bei mir angekommen. Ich habe "ungeprüfte Flatpaks anzeigen" markiert, dann erscheint "keine Anwendung zum öffnen von Telegram gefunden."
    Da passt was nicht zusammen. Wenn du wirklich exakt die Datei aus dem Bild von KP59 hast, dann hat das nichts mit Flatpak zu tun.
    Ich schätze mal, du hast die heruntergeladene Datei tsetup.6.1.3.tar.xz einfach nicht entpackt, sondern versuchst die Datei Telegram direkt aus dem Archiv zu starten.
    Das geht so nicht. Daher bitte erst die tsetup.6.1.3.tar.xz entpacken. Dazu mit der rechten Maustaste draufklicken und im Kontextmenü Hier entpacken wählen. Daraufhin wird dir ein Ordner Telegram erstellt, in dem du die ausführbaren Dateien Telegram und Updater findest. Die Telegram per Doppelklick starten.
    So geht's dann weiter:
    Weiter auf Deutsch anklicken:
    Jetzt beginnen anklicken:
    QR-Code scannen oder mit Nummer anmelden:
    (Mangels Telegram-Account kann ich den Rest jetzt nicht testen.)
  • Ich nutze das Appimage von der Telegramseite und musste noch nie einen QR-Code scannen. Telefonnummer eingeben und auf Handy bestätigen. Telegram kann nur im Ursprung mit einem Handy eingerichtet werden auf dem die Telegram App läuft. Wenn das Handy nicht mehr existiert ist Essig.
