Direkte Verbindung PC zu Drucker mit LAN-Kabel schlägt fehl
    Linux Mint
    Kernel: 6.14.0-29-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: Micro-Star model: MPG Z590M GAMING EDGE WIFI (MS-7D12)
    v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: E.30
    date: 12/23/2024
    Info: 8-core model: 11th Gen Intel Core i9-11900KF bits: 64 type: MT MCP
    arch: Rocket Lake rev: 1 cache: L1: 640 KiB L2: 4 MiB L3: 16 MiB
    Speed (MHz): avg: 2189 high: 5190 min/max: 800/5100:5300 cores: 1: 1586
    2: 800 3: 800 4: 2231 5: 1791 6: 2350 7: 5100 8: 800 9: 5112 10: 2400
    11: 1418 12: 3056 13: 800 14: 5190 15: 800 16: 800 bogomips: 112128
    Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate]
    vendor: Micro-Star MSI driver: nvidia v: 580.65.06 arch: Ampere
    bus-ID: 01:00.0
    gpu: nv_platform,nvidia,nvidia-nvswitch resolution: 1: 1680x1050~60Hz
    2: 3840x1080~120Hz
    API: EGL v: 1.5 drivers: nouveau,nvidia,swrast platforms:
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.65.06
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
    Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
    Device-2: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
    Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB bus-ID: 1-3:2
    API: ALSA v: k6.14.0-29-generic status: kernel-api
    Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
    port: N/A bus-ID: 04:00.0
    Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel bus-ID: 05:00.0
    IF: wlp5s0 state: up mac: <filter>
    Bluetooth:
    Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 1-14:7
    lmp-v: 12
    Local Storage: total: 3.66 TiB used: 525.06 GiB (14.0%)
    ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730
    SDBPNTY-1T00-1032 size: 953.87 GiB temp: 40.9 C
    ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
    temp: 41.9 C
    ID-3: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
    ID-1: / size: 937.33 GiB used: 524.88 GiB (56.0%) fs: ext4
    dev: /dev/nvme0n1p2
    ID-2: /boot/efi size: 511 MiB used: 7.1 MiB (1.4%) fs: vfat
    dev: /dev/nvme0n1p1
    System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 57 C
    Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
    Memory: total: 32 GiB available: 31.22 GiB used: 6.63 GiB (21.2%)
    Processes: 404 Uptime: 1h 4m Init: systemd target: graphical (5)
    Packages: 2520 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo Irgendwie mag mein Rechner die Luft in der neuen Heimat nicht und macht Probleme.
    Jetzt kann er keine Netzwerkverbindung über Kabel aufbauen.
    Meldet immer Versuch gescheitert.
    Jemand eine Idee ?
    Gruss MM
  • Eifelkuno , fang doch mal von vorne an bitte, was für ein Drucker ( Hersteller, Typ ) , wie war der Drucker an den PC angeschlossen, USB oder Netzwerk? Wie soll er jetzt angeschlossen werden. Bitte nicht böse sein aber deine angaben sind recht unpräzise, ich werde daraus nicht schlau.
    Q4OS - HP Elitebook 840 G4, Intel Core I5vPro, 16 GB Ram, SSD 256 GB, 1TB Hdd
    Ich bin bestimmt nicht böse, dafür sind hier viel zu viele hilfsbereite Menschen. Also es ist ein HP Color Laser Jet Pro mfp 281 fdw. Da der zu weit für das Usb Kabel wegsteht habe ich mit einem Netzwerkabel den Drucker direkt mit dem PC Verbunden (Crossover aktiviert) Es kommt aber immer die Meldung oben rechts Aktivierung der Netzwerkverbindung Fehlgeschlagen. Die Verbindung Router PC geht über W -lan. Der Drucker kann zwar auch W Lan aber das geht mal und mal nicht. Im Moment will es gar nicht.
  • Soweit ich mich erinnere müssen bei HP-Druckern auch die WLan-Verbindung über ein USB-Kabel eingerichtet werden.
    Ich gehe davon aus das Du hplip installiert hast.
  • Eifelkuno
    Ich verstehe Dich so, dass Du aufgrund der großen Entfernung (über 5 m ?) den Drucker per LAN-Kabel an den PC angeschlossen hast?
    Ich habe nachgeschaut, das in Deinem Protokoll angegebene MSI-Board kann selbständig erkennen, ob ein Crossoverkabel oder ein normales LAN-Kabel angeschlossen ist.
    Da dürfte also nicht das Problem liegen und eine LAN-Verbindung sollte grundsätzlich funktionieren.
    Du solltest evtl. aktiviertes Crossover deaktivieren, es ist nicht nötig und bringt ggfls. nur Irritationen.
    Es gibt aber noch weitere Bedingungen, die stimmen müssen bei einer solchen Direktverbindung:
    1) Der LAN-Port muss am Drucker aktiv sein, das kann in den Netzwerkeinstellungen des Druckers (am Display) eingestellt werden.
    2) Dort stellt man auch die IP-Adresse des Druckers ein. Das muss im Fall einer Direktverbindung i.d.R. manuell geschehen.
    Bei einer Direktverbindung wählst Du am besten den sogenannten LinkLocal-Bereich (169.254.XXX.XXX), eine Adresse könnte wie folgt lauten:
    169.254.169.254 (Einfacher geht natürlich auch: 169.254.169.1 )
    3) Dann ist es erforderlich, dass der LAN-Port des Rechners ebenfalls eine IP-Adresse aus der Range 169.254.169.XXX bekommt
    Also etwa 169.254.169.253 (Einfacher geht natürlich auch: 169.254.169.2 ) Die letzte Ziffer muss sich halt von der der IP-Adresse vom Drucker unterscheiden.
    4) an beiden Geräten muss die IP-Adressenvergabe manuell erfolgen, DHCP muss für den verwendeten LAN-Port deaktiviert sein.
    Dann sollte es funktionieren, sofern das Kabel ok ist ....
    Edited 4 times, last by stromzoo (September 15, 2025 at 7:39 PM).
  • Hat der Drucker den überhaupt mal funktioniert? Ist ja nicht das erstemal das darüber geschrieben wurde. Nur es gab keine Rückmeldung ob und wenn wie es funktioniert hat. Falls es mit USB ging, dann einfach eine Verlängerung dafür besorgen bevor man eine Baustelle nach der anderen hat!
    Stimmt grundsätzlich.
    Der HP-Drucker hat vermtl. eine USB 2.0-Schnittstelle. Eine Verbindung USB2.0 zu USB 2.0 darf aber für einen stabilen Betrieb die Länge von 5m nicht überschreiten. Auch nicht, wenn ein Kabel durch ein weiteres verlängert wird.
    Mit aktiven USB-Boostern erreicht man stabil eine Verdoppelung auf 10m, maximal 15m.
    Abgesehen, davon, dass wir nicht wissen, wie weit die beiden Geräte auseinanderstehen, dürfte der Weg über einen aktiven USB-Booster (der zudem Strom benötigt) etwas teurer sein, als ein entsprechend langes LAN-Kabel, was anscheinend vorhanden ist.
    Edited 2 times, last by stromzoo (September 15, 2025 at 7:45 PM).
  • Ich habe noch nie einen Drucker direkt über LAN mit einem PC verbunden, deswegen würde ich den Drucker über LAN mit der Router verbinden. Da die beiden Geräte bereits miteinander, wie auch immer, kommuniziert haben, sollte Treiber u.s.w bereits vorhanden sein.
    Mint sollte dann in der Lage sein den Drucker im Netzwerk entweder automatisch oder über eine manuelle Suche, entweder in der Druckerverwaltung im Startmenü oder in CUPS, zu erkennen und entweder automatisch richtig anzusprechen oder die Änderung der Druckerverbindung anzubieten.
    Währe m.E. der einfachere Weg
    Ja vor dem umzug hat er das Da war das Kabel aber nicht direkt angeschlossen sonder lief über den Router
    Der Router ist noch viel weiter Weg. Dann wäre es einfacher was mit USB zu Basteln
  • Der Router ist noch viel weiter Weg.
    Das ist doch kein Problem, der Drucker muss doch nicht neben dem PC stehen, er kann auch in der Nähe des Routers platziert werden. Musst du halt mal ein paar Meter laufen. Ich schreibe aus Erfahrung, meiner steht auch in einen anderen Raum, ebenfalls in der Nähe vom Router.
  • Ich bin bestimmt nicht böse, dafür sind hier viel zu viele hilfsbereite Menschen. Also es ist ein HP Color Laser Jet Pro mfp 281 fdw. Da der zu weit für das Usb Kabel wegsteht habe ich mit einem Netzwerkabel den Drucker direkt mit dem PC Verbunden (Crossover aktiviert) Es kommt aber immer die Meldung oben rechts Aktivierung der Netzwerkverbindung Fehlgeschlagen. Die Verbindung Router PC geht über W -lan. Der Drucker kann zwar auch W Lan aber das geht mal und mal nicht. Im Moment will es gar nicht.
    ok ... welche IP Adresse hat dein Rechner und welcher der Drucker?
  • ohne Crossover bedarf es einen LAN Switch
    Genau. So würde ich es auch machen. Einen kleinen 4-Port-Switch anschaffen. Der kostet nicht die Welt und Du könntest noch weitere Geräte dort ins Netz bekommen (Spielekonsole, NAS, Smart-TV etc.).
    OK. Lese gerade, dass Dein Internet-Router weit weg steht. Dann wird es wohl schwierig sein, den Switch direkt mit dem Router zu verbinden.
    Ich frage mich nur, warum Dein PC eine stabile WLAN-Verbindung zum Router aufbaut, wenn der Drucker es nicht kann.
    Edited once, last by Axelinux (September 15, 2025 at 9:25 PM).
