- Distrowahl
- Linux Mint
- Kernel: 6.14.0-29-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: Micro-Star model: MPG Z590M GAMING EDGE WIFI (MS-7D12)
v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC. v: E.30
date: 12/23/2024
Info: 8-core model: 11th Gen Intel Core i9-11900KF bits: 64 type: MT MCP
arch: Rocket Lake rev: 1 cache: L1: 640 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 2189 high: 5190 min/max: 800/5100:5300 cores: 1: 1586
2: 800 3: 800 4: 2231 5: 1791 6: 2350 7: 5100 8: 800 9: 5112 10: 2400
11: 1418 12: 3056 13: 800 14: 5190 15: 800 16: 800 bogomips: 112128
Device-1: NVIDIA GA102 [GeForce RTX 3080 Lite Hash Rate]
vendor: Micro-Star MSI driver: nvidia v: 580.65.06 arch: Ampere
bus-ID: 01:00.0
gpu: nv_platform,nvidia,nvidia-nvswitch resolution: 1: 1680x1050~60Hz
2: 3840x1080~120Hz
API: EGL v: 1.5 drivers: nouveau,nvidia,swrast platforms:
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.65.06
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3080/PCIe/SSE2
Device-1: Intel Tiger Lake-H HD Audio vendor: Micro-Star MSI
Device-2: NVIDIA GA102 High Definition Audio vendor: Micro-Star MSI
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-3:2
API: ALSA v: k6.14.0-29-generic status: kernel-api
Device-1: Intel Ethernet I225-V vendor: Micro-Star MSI driver: igc v: kernel
port: N/A bus-ID: 04:00.0
Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel bus-ID: 05:00.0
IF: wlp5s0 state: up mac: <filter>
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:7
lmp-v: 12
Local Storage: total: 3.66 TiB used: 525.06 GiB (14.0%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: PC SN730
SDBPNTY-1T00-1032 size: 953.87 GiB temp: 40.9 C
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
temp: 41.9 C
ID-3: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-1: / size: 937.33 GiB used: 524.88 GiB (56.0%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 511 MiB used: 7.1 MiB (1.4%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 57 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Memory: total: 32 GiB available: 31.22 GiB used: 6.63 GiB (21.2%)
Processes: 404 Uptime: 1h 4m Init: systemd target: graphical (5)
Packages: 2520 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo Irgendwie mag mein Rechner die Luft in der neuen Heimat nicht und macht Probleme.
Jetzt kann er keine Netzwerkverbindung über Kabel aufbauen.
Meldet immer Versuch gescheitert.
Jemand eine Idee ?
Gruss MM
