Querstreifen beim Booten
    Fedora
    desktopPC25@fedora:~$ inxi -Fzxi
    Kernel: 6.15.7-200.fc42.x86_64 arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    Desktop: KDE Plasma v: 6.4.3 Distro: Fedora Linux 42 (KDE Plasma Desktop
    Edition)
    Type: Desktop System: Dell product: Inspiron 7777 AIO v: 1.2.23
    serial: <superuser required>
    Mobo: Dell model: 02NK77 v: A02 serial: <superuser required>
    UEFI-[Legacy]: Dell v: 1.2.23 date: 09/26/2022
    Battery:
    Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
    charge: 100% (should be ignored) status: discharging
    Device-2: hidpp_battery_1 model: Logitech K850 Performance Wireless
    Keyboard charge: 100% (should be ignored) status: discharging
    Info: 6-core model: Intel Core i7-8700T bits: 64 type: MT MCP
    arch: Coffee Lake rev: A cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
    Speed (MHz): avg: 900 min/max: 800/4000 cores: 1: 900 2: 900 3: 900 4: 900
    5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900 bogomips: 57600
    Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Dell
    driver: i915 v: kernel arch: Gen-9.5 bus-ID: 00:02.0
    Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Dell
    driver: nvidia v: 575.64.03 arch: Pascal bus-ID: 01:00.0
    Device-3: Realtek Integrated_Webcam_FHD driver: uvcvideo type: USB
    bus-ID: 1-10:8
    Device-4: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    bus-ID: 1-6:2
    Display: wayland server: Xwayland v: 24.1.8 compositor: kwin_wayland
    driver: gpu: i915 resolution: 1920x1080~60Hz
    API: EGL v: 1.5 drivers: iris,nvidia,swrast platforms:
    active: gbm,wayland,x11,surfaceless,device inactive: device-1
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.4 glx-v: 1.4
    direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
    API: Vulkan v: 1.4.313 drivers: intel,nvidia,llvmpipe surfaces: N/A
    devices: 3
    de: kscreen-console,kscreen-doctor gpu: nvidia-settings,nvidia-smi
    wl: wayland-info x11: xdriinfo, xdpyinfo, xprop, xrandr
    Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3
    Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 01:00.1
    Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    bus-ID: 1-6:2
    API: ALSA v: k6.15.7-200.fc42.x86_64 status: kernel-api
    Server-1: PipeWire v: 1.4.7 status: active
    Device-1: Intel Ethernet I219-V vendor: Dell driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6
    Device-2: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Dell driver: ath10k_pci v: kernel bus-ID: 03:00.0 temp: 44.0 C
    Bluetooth:
    Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB bus-ID: 1-14:9
    Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8
    Local Storage: total: 1.14 TiB used: 19.2 GiB (1.6%)
    ID-1: /dev/nvme0n1 vendor: Toshiba model: KBG30ZMS256G NVMe 256GB
    size: 238.47 GiB temp: 34.9 C
    ID-2: /dev/sda vendor: Seagate model: ST1000LM049-2GH172 size: 931.51 GiB
    ID-1: / size: 930.51 GiB used: 18.79 GiB (2.0%) fs: btrfs dev: /dev/sda3
    ID-2: /boot size: 973.4 MiB used: 422.5 MiB (43.4%) fs: ext4
    dev: /dev/sda2
    ID-3: /home size: 930.51 GiB used: 18.79 GiB (2.0%) fs: btrfs
    dev: /dev/sda3
    ID-1: swap-1 type: zram size: 8 GiB used: 0 KiB (0.0%) dev: /dev/zram0
    System Temperatures: cpu: 42.0 C pch: 46.0 C mobo: N/A
    Fan Speeds (rpm): cpu: 1762
    Memory: total: 16 GiB note: est. available: 15.3 GiB used: 4.29 GiB (28.1%)
    Processes: 386 Uptime: 16m Init: systemd target: graphical (5)
    Packages: N/A note: see --rpm Compilers: gcc: 15.1.1 Shell: Bash v: 5.2.37
    inxi: 3.3.38
    Mm und das passiert bei Fedora 42 KDE Edition. Grafikkarte alles richtig installiert. Kommt beim Booten vor.
    Erste Bildschirm Schwarz
    2te so. Ab und zu verschwindet es.
    Nervt langsam und ich weiß nicht, ob was kaputtgeht!
  • War da vorher mal Schrift? Also lesbare Schriftzeichen?
    Nein. Das Komische ist das es bei Manjaro, Mint, Env...OS nicht auftauchen tut, nur bei Fedora.
    Da will es irgendwie ein Prozess ausüben und das nicht Richtig.
    Edited once, last by DenalB: Codeblock eingefügt (July 29, 2025 at 1:22 PM).
  • Sowas kenne ich von früher, wenn die Graka langsam starb, aber da das nur bei einem OS auftritt, würde ich auf Probleme mit dem Grafiksubsystem tippen. Da kennt einer hier doch bestimmt Kernelparameter zum Austesten.
  • Graphics:
    Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] driver: i915 v: kernel
    Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] driver: nvidia v: 575.64.03
    Ich bin hier auch mal am Vermuten.
    Da dein Gerät zwei Grafikkarten hat, könnte es eventuell sein, dass Fedora damit beim booten nicht ganz klar kommt.
    Wenn der Kernel dann geladen ist wird die richtige Grafikkarte angesprochen.
  • Im UEFI/BIOS vielleicht die Grafik des IntelChips komplett deaktivieren könnte vielleicht dabei helfen. Hab auch einen Intel mit Grafik, den aber grundsätzlich deaktiviert, weil ich keine 2 parallelen Grafiken brauche.
    MPG Z690 CARBON WIFI (MS-7D30) v: 1.0 --- Intel Core i7-12700K --- Memory DDR 5 5600MHZ, 32 GB --- GeForce RTX 3060 --- Monitor 1: Gigabyte AORUS FV43U; --- SSD 980 PRO 1TB (2x) + MZVLW256HEHP-00000 size: 238.47 GiB + externe SSD: Samsung T7-Shield 4TB
    Linux Mint 22.3 (Zena); Cinnamon 6.6.9; Kernel: 7.0.0-38; NVidea-Treiber 610.57.04-0ubuntu0-24.04.3 (open)
  • Ich bin hier auch mal am Vermuten.
    ahhhh jetzt. Danke dir! Dann müsste ich mal, denn die Nvidia Deinstallieren den Treiber und noch startet und. Ich glaube es funktioniert auch mit intel
    Das habe ich schon gemacht und trotzdem die Streifen. Ich habe auch das Gefühl es tut nicht deaktivieren, wenn ich es im BIOS Deaktiviere grins. So weit war ich auch schon, das ist unheimlich! Wenn das so weiter geht, suche ich mir einen andere Disbu...
    Edited once, last by tuxine: Ein Beitrag von Achim567 mit diesem Beitrag zusammengefügt. (July 29, 2025 at 4:46 PM).
  • Ich habe auch das Gefühl es tut nicht deaktivieren, wenn ich es im BIOS Deaktiviere
    Mal ganz ohne Grins - wenn das BIOS ein Setting nicht annimmt, ist entweder etwas im Argen oder es wird nötig sein, ein Admin bzw. Supervisor Password für das BIOS einzurichten. Einige BIOS / UEFIs scheinen inzwischen danach zu verlangen, um sich einerseits Einstellungen wirklich zu merken oder sogar bestimmte Einstellungen überhaupt erst anzubieten.
  • Mal ganz ohne Grins - wenn das BIOS ein Setting nicht annimmt, ist entweder etwas im Argen oder es wird nötig sein, ein Admin bzw. Supervisor Password für das BIOS einzurichten. Einige BIOS / UEFIs scheinen inzwischen danach zu verlangen, um sich einerseits Einstellungen wirklich zu merken oder sogar bestimmte Einstellungen überhaupt erst anzubieten.
    ok. gut zu wissen. So nebenbei habe den Nvidia Treiber deinstalliert Lach ist immer noch Aktiv. Wahnsinn.Ich glaube ich suche mir eine andere Disbu: Manjaro mm, oder Mint, oder......mmm
  • Wie stellst du fest dass der Treiber noch aktiv ist?
    Wie hast du ihn deinstalliert?
    esktopPC25@fedora:~$ lshw -c video | grep configuration
    WARNING: you should run this program as super-user.
          configuration: driver=nouveau latency=0
          configuration: driver=i915 latency=0
    WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
    Deinstalliert : sudo dnf remove \*nvidia\*
    Aktive: lshw -c video | grep configuration
    Edited 2 times, last by tuxine: Ein Beitrag von Achim567 mit diesem Beitrag zusammengefügt. (July 29, 2025 at 4:44 PM).
  • @Achim567
    Wenn du deinem vorherigen Beitrag etwas hinzufügen hast, kannst du ihn editieren.
    Bitte vermeide Doppelposts.
    Ich habe deine beiden Beiträge zusammen geführt.
  • @Achim567
    ohh
