- Distrowahl
- Sonstiges
- System:
Kernel: 6.15.7-2-cachyos arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
Desktop: KDE Plasma v: 6.4.3 Distro: CachyOS base: Arch Linux
Type: Mini-pc System: Micro (HK) Tech product: Venus series v: 1.0
serial: <filter>
Mobo: Shenzhen Meigao Equipment model: F7BSD v: 1.1 serial: <filter>
UEFI: American Megatrends LLC. v: 1.05 date: 12/15/2023
Info: 8-core model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 rev: 1 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
Speed (MHz): avg: 1101 min/max: 419/5138 boost: enabled cores: 1: 1101
2: 1101 3: 1101 4: 1101 5: 1101 6: 1101 7: 1101 8: 1101 9: 1101 10: 1101
11: 1101 12: 1101 13: 1101 14: 1101 15: 1101 16: 1101 bogomips: 121366
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 driver: amdgpu v: kernel
arch: RDNA-3 bus-ID: c4:00.0 temp: 35.0 C
Device-2: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
type: USB bus-ID: 1-1.2.1:9
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_wayland driver: gpu: amdgpu resolution: 2560x1440~144Hz
API: EGL v: 1.5 drivers: radeonsi,swrast platforms:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.6-cachyos1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix LLVM 20.1.8 DRM 3.63 6.15.7-2-cachyos)
API: Vulkan v: 1.4.321 drivers: radv surfaces: N/A devices: 1
de: kscreen-console,kscreen-doctor wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
[Rembrandt/Strix] driver: snd_hda_intel v: kernel bus-ID: c4:00.1
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor
driver: snd_pci_ps v: kernel bus-ID: c4:00.5
Device-3: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
driver: snd_hda_intel v: kernel bus-ID: c4:00.6
Device-4: Creative Live! Cam Sync 1080p V2 driver: snd-usb-audio,uvcvideo
Device-5: Logitech [G533 Wireless Headset Dongle]
driver: hid-generic,snd-usb-audio,usbhid type: USB bus-ID: 7-1.2:3
API: ALSA v: k6.15.7-2-cachyos status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.4.6 status: active
Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: f000
bus-ID: 02:00.0
IF: enp2s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 1-5:4
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: yes address: N/A
Local Storage: total: 10.96 TiB used: 55.6 GiB (0.5%)
ID-1: /dev/nvme0n1 vendor: Kingston model: OM8PGP41024Q-A0
size: 953.87 GiB temp: 30.9 C
ID-2: /dev/nvme1n1 vendor: TeamGroup model: TM8FPD001T size: 953.87 GiB
temp: 30.9 C
ID-3: /dev/sda vendor: Seagate model: ST5000LM000-2AN170 size: 4.55 TiB
type: USB
ID-4: /dev/sdb vendor: Seagate model: ST5000DM000-1FK178 size: 4.55 TiB
type: USB
ID-1: / size: 98.42 GiB used: 13.51 GiB (13.7%) fs: btrfs
dev: /dev/nvme0n1p1
ID-2: /boot size: 1.97 GiB used: 120.3 MiB (6.0%) fs: vfat
dev: /dev/nvme0n1p2
ID-3: /home size: 839.78 GiB used: 41.98 GiB (5.0%) fs: ext4
dev: /dev/nvme0n1p6
ID-4: /var/log size: 98.42 GiB used: 13.51 GiB (13.7%) fs: btrfs
dev: /dev/nvme0n1p1
ID-5: /var/tmp size: 98.42 GiB used: 13.51 GiB (13.7%) fs: btrfs
dev: /dev/nvme0n1p1
ID-1: swap-1 type: zram size: 23.25 GiB used: 908 KiB (0.0%) dev: /dev/zram0
System Temperatures: cpu: 38.6 C mobo: N/A gpu: amdgpu temp: 34.0 C
Fan Speeds (rpm): N/A
Memory: total: 24 GiB available: 23.25 GiB used: 3.14 GiB (13.5%)
Processes: 359 Uptime: 21m Init: systemd
Packages: 1472 Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Bash v: 5.3.0
inxi: 3.3.38
ich habe folgendes Problem.
Ich habe noch diesen alten Drucker Brother MFC-5460CN und möchte ihn unter CachyOS betreiben.
Leider kann ich die Treiber nicht installieren, habe es schon nach der Anleitung der Arch Linux Seite (https://wiki.archlinux.de/title/Brother-Drucker) versucht, aber ich bekomme den Drucker nicht ans laufen.
Es gibt von Brother sowohl .rpm als auch .deb Treiber.
Kann einer helfen?
