- Distrowahl
- Linux Mint
- ystem:
Kernel: 6.8.0-64-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop System: CSL- GmbH & KG product: Ultra v: N/A
serial: <superuser required>
Mobo: ASUSTeK model: TUF GAMING B660-PLUS WIFI D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 2403
date: 03/28/2023
Info: 12-core (8-mt/4-st) model: 12th Gen Intel Core i7-12700F bits: 64
type: MST AMCP arch: Alder Lake rev: 2 cache: L1: 1024 KiB L2: 12 MiB
L3: 25 MiB
Speed (MHz): avg: 809 high: 900 min/max: 800/4800:4900:3600 cores: 1: 800
2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 897 10: 800 11: 900
12: 800 13: 800 14: 800 15: 800 16: 800 17: 800 18: 800 19: 800 20: 800
bogomips: 84480
Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: ASUSTeK driver: nouveau
v: kernel arch: Lovelace bus-ID: 01:00.0
loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nouveau,swrast platforms:
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.8-1ubuntu1~24.04.1
glx-v: 1.4 direct-render: yes renderer: NV196
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
API: ALSA v: k6.8.0-64-generic status: kernel-api
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
IF: wlo1 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0
IF: enp5s0 state: down mac: <filter>
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:7
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
lmp-v: 11
RAID:
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 bus-ID: 00:0e.0
Local Storage: total: 931.51 GiB used: 132.42 GiB (14.2%)
ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
temp: 31.9 C
ID-1: / size: 915.32 GiB used: 132.42 GiB (14.5%) fs: ext4
dev: /dev/nvme0n1p2
dev: /dev/nvme0n1p1
System Temperatures: cpu: 28.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB available: 15.43 GiB used: 2.02 GiB (13.1%)
Processes: 418 Uptime: 35m Init: systemd target: graphical (5)
Packages: 2275 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo zusammen.
Ich habe ein kleines Problemchen. Habe nun auch Linux Mint auf meinem Hauptrechner installiert. Alles funktioniert wie es soll , nur das mit den Treibern der Grafikkarte ist so eine Sache.
Wenn ich keine Treiber nutze kann ich die Auflösung auf 1920 x 1080 stellen. Wenn ich allerdings die vorgegebenen Nvidia Treiber installiere , dann habe ich nur eine Auflösung von 1024 x 768. Da kann ich auch nichts anderes einstellen. Deinstalliere ich den Treiber kann ich wieder auf 1920 x 1080 stellen. Habe jetzt alle 5 Treiber in der Treiberverwaltung getestet alle mit dem selben Ergebniss. Mache ich da etwas Falsch????
Gruß Chris
