Linux Mint-Installation auf neuem Laptop - WLAN lässt sich nicht aktivieren
    Linux Mint
    Kernel: 6.8.0-64-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Laptop System: HP product: Victus by HP Gaming Laptop 15-fb3xxx v: N/A
    serial: <superuser required>
    Mobo: HP model: 8DD0 v: 52.12 serial: <superuser required> UEFI: AMI
    v: F.03 date: 12/24/2024
    Battery:
    ID-1: BAT0 charge: 63.8 Wh (91.0%) condition: 70.1/70.1 Wh (100.0%)
    volts: 17.6 min: 15.4 model: HP Primary status: charging
    Info: 8-core model: AMD Ryzen 9 8945HS w/ Radeon 780M Graphics bits: 64
    type: MT MCP arch: Zen 4 rev: 2 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
    Speed (MHz): avg: 903 high: 5140 min/max: 400/5263 cores: 1: 400 2: 400
    3: 400 4: 400 5: 400 6: 400 7: 5140 8: 400 9: 400 10: 400 11: 400 12: 2056
    13: 2055 14: 400 15: 400 16: 400 bogomips: 127766
    Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
    vendor: Hewlett-Packard driver: nouveau v: kernel arch: Lovelace
    bus-ID: 01:00.0
    Device-2: AMD Phoenix3 vendor: Hewlett-Packard driver: amdgpu v: kernel
    arch: RDNA-3 bus-ID: 06:00.0 temp: 51.0 C
    Device-3: Luxvisions Innotech HP Wide Vision HD Camera driver: uvcvideo
    type: USB bus-ID: 1-3:2
    loaded: amdgpu,modesetting unloaded: fbdev,vesa dri: radeonsi gpu: amdgpu
    resolution: 1920x1080~144Hz
    API: EGL v: 1.5 drivers: kms_swrast,nouveau,radeonsi,swrast platforms:
    API: OpenGL v: 4.6 compat-v: 4.3 vendor: amd mesa
    v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
    Radeon Graphics (radeonsi gfx1103_r1 LLVM 19.1.1 DRM 3.57
    6.8.0-64-generic)
    Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
    bus-ID: 01:00.1
    Device-2: AMD Rembrandt Radeon High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 06:00.1
    Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
    driver: snd_pci_ps v: kernel bus-ID: 06:00.5
    Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 06:00.6
    API: ALSA v: k6.8.0-64-generic status: kernel-api
    vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel port: e000
    bus-ID: 02:00.0
    Device-2: Realtek vendor: Hewlett-Packard driver: N/A port: d000
    bus-ID: 04:00.0
    Bluetooth:
    Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB
    bus-ID: 1-4:3
    address: <filter>
    Local Storage: total: 953.87 GiB used: 18.88 GiB (2.0%)
    ID-1: /dev/nvme0n1 vendor: Micron model: MTFDKBA1T0QGN-1BN1AABHA
    size: 953.87 GiB temp: 38.9 C
    ID-1: / size: 937.33 GiB used: 18.88 GiB (2.0%) fs: ext4 dev: /dev/nvme0n1p2
    dev: /dev/nvme0n1p1
    ID-1: swap-1 type: file size: 2 GiB used: 256 KiB (0.0%) file: /swapfile
    System Temperatures: cpu: 65.1 C mobo: N/A gpu: amdgpu temp: 52.0 C
    Fan Speeds (rpm): fan-1: 2688 fan-2: 0
    Memory: total: 16 GiB note: est. available: 14.88 GiB used: 2.82 GiB (18.9%)
    Processes: 449 Uptime: 2h 22m Init: systemd target: graphical (5)
    Packages: 1954 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo Linuxguides,
    ich habe auf einem neuen Laptop ohne System Linux Mint installiert, bekomme aber das WLAN nicht konfiguriert bzw. es wird in der Auswahl nicht angezeigt.
    Bei "Netzwerkeinstellungen" sehe ich nur "Kabelgebunden", "Loopback" und "Netzwerk-Proxy".
    Bei "Netzwerkverbindungen" sehe ich nur "Ethernet" mit dem Unterpunkt "Kabelgebundene Verbindung 1".
    LAN funktioniert, ich hätte aber auch gern WLAN. Was kann ich noch tun?
    Falls es hilft: das Kommando "rfkill list" liefert
    0: hci0: Bluetooth
    	Soft blocked: yes
    	Hard blocked: no
    Auch da kein WLAN zu sehen.
    ip a liefert:
    Der Laptop ist der HP Victus 15-fb3194ng der hat keinen WLAN-Schalter und auch meine FN-Tastenkombination für WLAN on/off (zumindest kann ich keine sehen).
    Jede Hilfe ist willkommen.
    Edited once, last by Gunther (July 19, 2025 at 9:36 PM).
    der Kernel in deinem System ist vom März 2024 und dein Laptop irgendwann aus 2024. Ich gehe davon aus das die Hardware noch nicht komplett unterstützt wird.
    Ich würde mal den neusten Kernel installieren den dir Mint anbietet, wenn das nicht geht mal Fedora aufn Stick schmeisen, starten und schauen ob da das WLAN funktioniert. Das wäre meine Prognose.
    MfG Linus
    Acer Nitro 5 | i5 11400h | Nvidia GeForce GTX 1650/Intel UHD | 16 Gigabyte DDR4 RAM | 512 GB SSD | Fedora 44
    Raspberry Pi 5 | 4 Gigabyte RAM | Ubuntu Server 26.04 Pro
  • Hallo Linus,
    danke für die schnelle Antwort. Die Aktualisierungsverwaltung sagt mir, dass ich auf dem neuesten Stand bin, auch nach dem "Auffrischen".
    Ich nehme an dass das dann auch für den Kernel gilt?
    Dann probiere ich mal einen Fedora-Stick zu erstellen.
    LG, Gunther
  • Geh in der Aktualisierungsverwaltung oben auf Ansicht und dann auf Kernel, da gibt es neuere Kernel
  • Super 1000-Dank das hat geholfen!
    Nach der Installation des Kernels 6.14.0-24 und 2x Neustarten habe ich jetzt WLAN.
    Netzwerk-Kabel ist entfernt, WLAN läuft.
    Vielen Dank nochmal. :-))
  • DenalB July 19, 2025 at 10:09 PM
