GE-Proton10-1 veröffentlicht
  • Moin!
    Quicky-Gaming-News:
    Der beliebte Proton-Fork "Proton-GE" ist ab sofort in der Version 10-1 verfügbar. Diese Variante basiert auf Wine 10 und bringt dessen Neuerungen mit, darunter:
    • GE-Proton rebased on top of Valve's Proton 10 Bleeding Edge
    • Wine-Wayland has been enabled and patches from upstream wine backported for it. YMMV (Your mileage may vary). Thanks Etaash-mathamsetty for the backporting as well as the wine-wayland specific patch fixes for various games.
    • Dualsense controller patches from ClearlyClaire https://gitlab.winehq.org/wine/wine/-/merge_requests/7238 rebased (thanks loathingKernel)
    • FSR patches rebased (thanks loathingKernel)
    • Nvidia Reflex low latency patches rebased
    Protonfixes:
    • Marvel Rivals EGS fix added (thanks termdisc)
    • Fix added for The Testament of Sherlock Holmes (thanks UsernamesAreNotMyThing)
    • Fix added for Borderlans: The Pre-Sequel (thanks loathingKernel)
    • Fix added for Elder Scrolls IV: Oblivion Remastered (thanks Reilley64)
    • Fix added for Breath of Fire 4 (GOG) (Thanks ImLinguin)
    • Fixes added for Star Citizen (Thanks mactan-sc)
    • Fix added for Yosumin (Thanks UsernamesAreNotMyThing)
    • Fix added for DOOM 2016 (GOG) (Thanks ImLinguin)
    • Fix added for Lord of the Rings Online (thanks mdmatthias/MathiasDillain)
    • Fix added for Once Human (Thanks jcdickinson)
    • Fix added for Shadows of Adam (Thanks UsernamesAreNotMyThing)
    • Save import fix added for Metaphor ReFantazio (Thanks UsernamesAreNotMyThing)
    • Save import fix added for Persona 3 Reload (Thanks UsernamesAreNotMyThing)
    • Fix added for Liminal Border Part III (thanks R1kaB3rN)
    • Fix added for Mojika Truth Rears Its Head (thanks superboo7)
    (Adblocker aktiviert?)
    Mehr Infos auf Englisch:
    mfg: Actionschnitzel
    Meine Projekte:
    GuideOS Logo PiGro-Aid Logo
  • Cachy war etwas schneller. Da kam die neue Version bereits 1 oder 2 Tage vorher raus ... Zumindest lässt sich mit beiden Version nun wieder Battle.net in Lutris starten. Hatte da vor ein paar Tagen ein Problem mit dem Agent. War damit auch nicht allein.
  • Ich hoffe, dass der Marktanteil von Linux Ende 2025 bei 6-8% liegt und ein Umdenken in der Industrie einsetzt.
  • Soeben wurde GE-Proton10-2 veröffentlicht. ;)
    Hotfix release:
    • Fixes missing comma in proton script causing prefix issues (this was also a valve upstream issue)
    • Fixes accidental import of the steam ffmpeg libraries instead of the ones we build and ship (this was an accidental copy/paste when porting changes from Proton 10) -- this should fix video playback in a lot of titles as they worked in proton 9
    • Removes setting ENABLE_HDR_WSI -- this option is only specific for the vk_hdr_layer (https://github.com/Zamundaaa/VK_hdr_layer) hack, which is -not- needed as of mesa 25.1 and can cause washed out colors. If you previously used this, it's advised to remove it, and update mesa to 25.1 if you want HDR.
    • added a few patches for allowing more launchers to work in wayland (epic, battlenet, star citizen)
    • added patch to allow 32 bit EOS overlay to work for Among Us.
    • added raw input patches for winewayland (un-accelerated mouse)
    • added touchpad scrolling support patch for winewayland
    • xalia library updates imported from upstream
    • dxvk updated to latest git
    • vkd3d-proton updated to latest git
    Quelle: Release GE-Proton10-2 Released · GloriousEggroll/proton-ge-custom · GitHub
  • Und weiter geht's ...
    Release GE-Proton10-3 Released · GloriousEggroll/proton-ge-custom · GitHub
    Hotfix release:
    • added envvar needed for winewayland patch fixes to work (automatically set when PROTON_ENABLE_WAYLAND is set)
    • added patch so that PROTON_ENABLE/DISABLE_HIDRAW works as expected.
    Important note:
    PLEASE do NOT manually set DISPLAY= when trying to enable winewayland. ALL that is needed is PROTON_ENABLE_WAYLAND=1. When you manually disable DISPLAY= it can break many applications that need to render natively, in particular things like launchers or things that need to render with OpenGL or Vulkan directly. (not via dxvk/vkd3d).
    Na das klingt ja mal interessant eventuell springt ja jetzt die maus nimmer in der gegend hin und her bei manchen games
  • Warum machst du das nicht zentral in den Steam-Einstellungen für alle Spiele und stellst bei den Spielen dann ggf. abweichende Versionen ein?
    Für Steam geht das, aber auf dem Deck muss ich immer in den Desktop-Mode und Herioc setzt immer nur den gewählten PräFix ein, ändern muss man das manuell.
    Meine Projekte:
