- dieter@dieter-Victus-by-HP-Gaming-Laptop-16-s1xxx:~$ inxi -Fxzi
Kernel: 6.8.0-59-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Laptop System: HP product: Victus by HP Gaming Laptop 16-s1xxx
v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 8C9C v: 79.30 serial: <superuser required> UEFI: Insyde
v: F.14 date: 01/13/2025
Battery:
ID-1: BAT1 charge: 83.2 Wh (100.0%) condition: 83.2/83.0 Wh (100.2%)
volts: 13.1 min: 11.6 model: Hewlett-Packard PABAS0241231 status: full
Info: 8-core model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64
type: MT MCP arch: Zen 4 rev: 2 cache: L1: 512 KiB L2: 8 MiB L3: 16 MiB
Speed (MHz): avg: 625 high: 2157 min/max: 400/5137 cores: 1: 400 2: 400
3: 400 4: 400 5: 1326 6: 400 7: 2157 8: 400 9: 400 10: 400 11: 400 12: 400
13: 1324 14: 400 15: 400 16: 400 bogomips: 121366
Device-1: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: Hewlett-Packard driver: nvidia v: 550.144.03 arch: Lovelace
bus-ID: 01:00.0
Device-2: AMD Phoenix3 vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: RDNA-3 bus-ID: 05:00.0 temp: 31.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP True Vision FHD Camera
driver: uvcvideo type: USB bus-ID: 3-1:2
loaded: amdgpu,nvidia unloaded: fbdev,modesetting,nouveau,vesa dri: radeonsi
gpu: amdgpu resolution: 1920x1080~144Hz
API: EGL v: 1.5 drivers: nvidia,radeonsi,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa
v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
Radeon Graphics (radeonsi gfx1103_r1 LLVM 19.1.1 DRM 3.57
6.8.0-59-generic)
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 01:00.1
Device-2: AMD Rembrandt Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_pci_ps v: kernel bus-ID: 05:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 05:00.6
API: ALSA v: k6.8.0-59-generic status: kernel-api
Device-1: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852be v: kernel port: 3000
bus-ID: 02:00.0
IF: wlo1 state: up mac: <filter>
vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel port: 2000
bus-ID: 03:00.0
Bluetooth:
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 1-5:2
Report: hciconfig ID: hci0 rfk-id: 5 state: up address: <filter> bt-v: 5.3
lmp-v: 12
Local Storage: total: 953.87 GiB used: 19.12 GiB (2.0%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVL81T0HELB-00BH1
size: 953.87 GiB temp: 32.9 C
ID-1: / size: 432.61 GiB used: 19.05 GiB (4.4%) fs: ext4 dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 96 MiB used: 72.2 MiB (75.2%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 36.4 C mobo: N/A gpu: amdgpu temp: 31.0 C
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 30.65 GiB used: 4.41 GiB (14.4%)
Processes: 396 Uptime: 1d 2h 22m Init: systemd target: graphical (5)
Packages: 2408 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Ich habe mir eine neue Festplatte für das Notebook geholt und möchte sie zusätzlich einbauen. Dann möchte ich Win11 auf der "alten" Festplatte behalten und auf der neu verbauten wieder LM22 installieren und die alte Festplatte komplett für win nutzen und die neue Platte für LM22. Kann ich das einfach mit einer Neuinstallation von Mint durchführen, oder bleibt mir nichts anderes übrig, als erst wieder win11 neu zu installieren und dann wieder LM22?
