Ein Fehler ist beim Update aufgetreten
    Linux Mint
    Kernel: 6.8.0-58-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 4301
    date: 03/04/2021
    Battery:
    Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
    charge: 55% (should be ignored) status: discharging
    Info: 8-core model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2
    rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 32 MiB
    Speed (MHz): avg: 2276 high: 3600 min/max: 2200/4426 boost: enabled cores:
    1: 2200 2: 2200 3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2024
    10: 2200 11: 2200 12: 2196 13: 3600 14: 2200 15: 2200 16: 2200
    bogomips: 114985
    Device-1: NVIDIA GA104 [GeForce RTX 3060] vendor: Gigabyte driver: nvidia
    v: 535.230.02 arch: Ampere bus-ID: 09:00.0
    gpu: nvidia,nvidia-nvswitch resolution: 3840x2160
    API: EGL v: 1.5 drivers: nvidia platforms: active: gbm inactive: N/A
    API: OpenGL v: 4.6.0 vendor: nvidia v: 535.230.02 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel
    bus-ID: 08:00.0
    Device-2: NVIDIA GA104 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 09:00.1
    Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 0b:00.4
    API: ALSA v: k6.8.0-58-generic status: kernel-api
    Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    port: e000 bus-ID: 03:00.0
    IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Local Storage: total: 6.6 TiB used: 2.29 TiB (34.8%)
    ID-1: /dev/sda vendor: Western Digital model: WD30EFRX-68EUZN0
    ID-2: /dev/sdb vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
    ID-3: /dev/sdc vendor: Samsung model: SSD 870 QVO 2TB size: 1.82 TiB
    ID-4: /dev/sdd vendor: Seagate model: ST2000DX001-1NS164 size: 1.82 TiB
    ID-1: / size: 1.79 TiB used: 95.28 GiB (5.2%) fs: ext4 dev: /dev/sdc2
    System Temperatures: cpu: 38.0 C mobo: 35.0 C gpu: nvidia temp: 50 C
    Fan Speeds (rpm): cpu: 1128 case-1: 0 case-2: 697 case-3: 0 gpu: nvidia
    fan: 0%
    Power: 12v: 10.08 5v: N/A 3.3v: N/A vbat: 3.25
    Memory: total: 16 GiB available: 15.51 GiB used: 3.76 GiB (24.2%)
    Processes: 376 Uptime: 1h 2m Init: systemd target: graphical (5)
    Packages: 2502 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo
    Ich eben ein Update erhalten gibt ein neuen Kernel, da kommt diese Meldung bevor ich weiter mache frage ich nach vor der Meldung kam eine anderer da stand einige Pakete konnten nicht vom Server heruntergeladen werden wollen sie weiter machen habe ich auf ja geklickt kam diese Meldung, was soll ich tun? einfach weiter machen?.
    Linux Mint 22.3 Zena
  • Für potentiell Hilfswillige wäre die komplette Ausgabe (von Prompt bis Prompt) von
    sudo apt update && sudo apt upgrade
    im Codeblock aussagekräftiger.
  • Versuch mal folgendes:
    sudo apt update
    sudo apt --fix-broken install
    sudo dpkg --configure -a
    Gibt es immer noch ein Problem, noch ein:
    sudo apt install --reinstall linux-generic linux-image-generic linux-headers-generic
  • Hier ist die Komplette Meldung vom Terminal.
    Edited once, last by DenalB: Zur besseren Lesbarkeit Codeblöcke eingefügt. (May 2, 2025 at 11:31 AM).
  • @zebolon ganz unten steht eine Meldung.
    Hier noch eine Meldung.
    W: Die Datei »http://artfiles.org/ubuntu.com/pool/main/l/linux/linux-headers-6.8.0-59_6.8.0-59.61_all.deb« konnte nicht heruntergeladen werden
     404  Not Found [IP: 2a00:1f78:af:c003::2 80]
  • Jetzt kriege ich diese Meldung.
    Edited once, last by DenalB: Zur besseren Lesbarkeit Codeblöcke eingefügt. (May 2, 2025 at 11:30 AM).
  • Das habe ich Beendet.
    Dann nochmal versuchen...
    Probier mal einen anderen Spiegelserver - in der Update-Verwaltung von LM einzustellen...
    Edited once, last by DenalB: Ein Beitrag von zebolon mit diesem Beitrag zusammengefügt. (May 2, 2025 at 10:21 AM).
  • Wenn ich im Terminal Update kommt schon wieder diese E Meldung.
    Und wenn ich das eingebe sudo apt --fix-broken install kommt diese Meldung.
    Edited once, last by DenalB: Zur besseren Lesbarkeit Codeblöcke eingefügt. (May 2, 2025 at 11:29 AM).
  • Jetzt kommt die Meldung. Passierte beim Server wechsel.
    Was soll ich mit den Defekten machen einfach löschen?
    Edited once, last by DenalB: Ein Beitrag von The Baron_Linux mit diesem Beitrag zusammengefügt. (May 2, 2025 at 10:21 AM).
  • Dann starte das System mal neu, öffne - nur - das Terminal und verarbeite die Befehle aus Post #3 nochmal...
    Da wird wohl nichts passiert wenn ich neu starte wegen dem fehler er konnte den neuen Kernel nicht Installieren. Was mache ich mit den Defekten #15
  • Da wird wohl nichts passiert wenn ich neu starte wegen dem fehler er konnte den neuen Kernel nicht Installieren. Was mache ich mit den Defekten #15
    Bislang konnten die Dateien nicht oder nur unvollständig von dem vorherigen Server runter geladen werden. Deshalb die ständigen Fehlermeldungen. Nach deiner Aussage wurde der Server erfolgreich gewechselt - deshlab mein Vorschlag, die Befehle aus Post #3 zu wiederholen. Es wäre hilfreich, wenn die Anweisungen befolgt würden...
  • Leider hat es nicht geklappt nach dem Neustart ich habe #3 noch mal gemacht.
    Das Ergebnis.
    Dann das hier.
    Probieren Sie »apt --fix-broken install«, um dies zu korrigieren.
    Die folgenden Pakete haben unerfüllte Abhängigkeiten:
    linux-headers-generic : Hängt ab von: linux-headers-6.8.0-59-generic soll aber nicht installiert werden
    linux-image-generic : Hängt ab von: linux-image-6.8.0-59-generic soll aber nicht installiert werden
                          Hängt ab von: linux-modules-extra-6.8.0-59-generic soll aber nicht installiert werden
    E: Unerfüllte Abhängigkeiten. Versuchen Sie »apt --fix-broken install« ohne Angabe eines Pakets (oder geben Sie eine Lösung an).
