Dateisymbol / Icon systemweit ändern
    Linux Mint
    Kernel: 5.15.0-138-generic x86_64 bits: 64 compiler: gcc v: 11.4.0
    Desktop: MATE 1.26.0 Distro: Linux Mint 21.3 Virginia
    base: Ubuntu 22.04 jammy
    Type: Desktop System: ASUS product: All Series v: N/A
    serial: <superuser required>
    Mobo: ASUSTeK model: B85M-G v: Rev X.0x serial: <superuser required>
    BIOS: American Megatrends v: 2108 date: 08/11/2014
    Info: quad core model: Intel Core i7-4790 bits: 64 type: MT MCP
    arch: Haswell rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 3109 high: 3592 min/max: 800/4000 cores: 1: 3592
    2: 3592 3: 3592 4: 3592 5: 3592 6: 3592 7: 1329 8: 1994 bogomips: 57466
    Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    Device-1: NVIDIA GM107 [GeForce GTX 750 Ti] vendor: ASUSTeK driver: nvidia
    v: 550.120 bus-ID: 01:00.0
    Device-2: Guillemot Dualpix HD type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 3-10:5
    unloaded: fbdev,modesetting,nouveau,vesa gpu: nvidia
    resolution: 1920x1080~60Hz
    OpenGL: renderer: NVIDIA GeForce GTX 750 Ti/PCIe/SSE2
    v: 4.6.0 NVIDIA 550.120 direct render: Yes
    Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
    vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 01:00.1
    Device-3: Guillemot Dualpix HD type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 3-10:5
    Device-4: C-Media CM106 Like Sound Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-1.1:3
    Sound Server-1: ALSA v: k5.15.0-138-generic running: yes
    vendor: ASUSTeK H81M-C driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
    Local Storage: total: 2.51 TiB used: 1.31 TiB (52.1%)
    ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
    ID-2: /dev/sdb vendor: Seagate model: ST2000DM001-1ER164 size: 1.82 TiB
    ID-3: /dev/sdc vendor: Intenso model: SSD SATAIII size: 238.47 GiB
    ID-1: / size: 232.69 GiB used: 40.07 GiB (17.2%) fs: ext4 dev: /dev/sdc5
    ID-2: /boot/efi size: 512 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/sdc2
    System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 35 C
    Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
    Processes: 260 Uptime: 22m Memory: 31.28 GiB used: 1.73 GiB (5.5%)
    Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2129 Shell: Bash
    v: 5.1.16 inxi: 3.3.13
    Hallo in die Runde,
    vor ein paar Tagen habe ich LM 21 Mate installiert und soweit ist auch alles in Ordnung.
    Nur das Dateisymbol / Icon für PDF-Dateien ist besch...eiden: da wird nämlich quasi der PDF-Dokumneteninhalt als Miniatur (statt eines Icons) angezeigt.
    In der schreibgeschützten usr/share/mime/application/pdf.xml
    <mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="application/pdf">
    <!--Created automatically by update-mime-database. DO NOT EDIT!-->
    <comment>PDF document</comment>
    <acronym>PDF</acronym>
    <expanded-acronym>Portable Document Format</expanded-acronym>
    <generic-icon name="x-office-document"/>
    <glob pattern="*.pdf"/>
    <alias type="application/x-pdf"/>
    <alias type="image/pdf"/>
    <alias type="application/acrobat"/>
    <alias type="application/nappdf"/>
    und der dortige Eintrag <generic-icon name="x-office-document"/> ist wohl der Auslöser für diese "Miniaturen" ...
    Auch die Installation verschiedener PDF-Reader hat nichts geändert :(:(;(
    Wie und wo kann man kann man systemweit ein vernünftiges Icon hinterlegen (z.B. application-pdf.png dass ich in usr/share/icons/mate/48x48/mimetypes entdeckt habe ?
    Danke im voraus und
    Gruss
    Glolin
  • Im Dateimanager kann man das Ausschalten, das der Inhalt angezeigt wird. Das hat nichts mit den Icons selbst zu tun.
    Kannst Du mir das bitte näher erklären ? (Dass es auch ein Neuling versteht)8)
  • Kannst Du mir das bitte näher erklären ? (Dass es auch ein Neuling versteht)8)
    Im Dateimanager, bei MINT Cinnamon ist es NEMO, auf Bearbeiten, Einstellungen, Vorschau. Dort Vorschaubilder anzeigen, und einstellen was du willst.
