- Distrowahl
- Linux Mint
- freddy@C3PO:~$ inxi -Fzxi
Kernel: 6.8.0-58-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop System: MSI product: MS-7A12 v: 1.0
serial: <superuser required>
Mobo: MSI model: Z170A GAMING PRO CARBON (MS-7A12) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 1.30
date: 05/12/2016
Battery:
Device-1: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
M705 charge: 100% (should be ignored) status: discharging
Info: quad core model: Intel Core i7-6700K bits: 64 type: MT MCP
arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 800 min/max: 800/4400 cores: 1: 800 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 63999
Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 550.120
arch: Pascal bus-ID: 01:00.0
loaded: nouveau unloaded: fbdev,modesetting,vesa failed: nvidia
gpu: nvidia,nvidia-nvswitch resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1060
6GB/PCIe/SSE2
Device-1: Intel 100 Series/C230 Series Family HD Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-3: JMTek LLC. KLIM Impact driver: hid-generic,snd-usb-audio,usbhid
type: USB bus-ID: 1-7:4
API: ALSA v: k6.8.0-58-generic status: kernel-api
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel 82574L Gigabit Network driver: e1000e v: kernel port: d000
bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth:
Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB
bus-ID: 1-11:6
lmp-v: 10
Local Storage: total: 2.44 TiB used: 611.04 GiB (24.5%)
ID-1: /dev/sda vendor: Corsair model: Force GT size: 167.68 GiB
ID-2: /dev/sdb vendor: Western Digital model: WD15EADS-00S2B0
ID-3: /dev/sdc vendor: Western Digital model: WD10JMVW-11AJGS3
size: 931.48 GiB type: USB
ID-1: / size: 163.5 GiB used: 37.8 GiB (23.1%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 31.0 C pch: 38.5 C mobo: N/A gpu: nvidia
temp: 35 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 25%
Memory: total: 16 GiB available: 15.57 GiB used: 2.13 GiB (13.7%)
Processes: 313 Uptime: 9m Init: systemd target: graphical (5)
Packages: 2452 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
freddy@C3PO:~$
Hallo Zusammen,
ich bin neu bei Linux und habe direkt ein Problem. Mein Bluetooth Speaker der Marke Anker verbindet sich mit meinem System ( wird angezeigt ), bringt aber keinen Ton ! Tipps wo ich ansetzen kann? Danke!
Gruß Freddy
