Bluetooth verbindet sich nicht mit Mouse /kurze Verbindung dann wieder Abbruch
    Ubuntu
    Kernel: 6.12.10-76061203-generic x86_64 bits: 64 compiler: N/A
    Desktop: GNOME 42.9 Distro: Pop!_OS 22.04 LTS base: Ubuntu 22.04 LTS Jammy
    Mobo: ASUSTeK model: TUF GAMING B760-PLUS WIFI D4 v: Rev 1.xx
    serial: <superuser required> UEFI: American Megatrends v: 1805
    date: 10/30/2024
    Info: 12-core (8-mt/4-st) model: 12th Gen Intel Core i7-12700KF bits: 64
    type: MST AMCP arch: Alder Lake rev: 2 cache: L1: 1024 KiB L2: 12 MiB
    L3: 25 MiB
    Speed (MHz): avg: 796 high: 800 min/max: 800/4900:5000:3800 cores: 1: 800
    2: 800 3: 800 4: 772 5: 782 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800
    12: 800 13: 786 14: 800 15: 796 16: 800 17: 800 18: 800 19: 800 20: 800
    bogomips: 144383
    Device-1: NVIDIA vendor: ASUSTeK driver: nvidia v: 565.77 bus-ID: 01:00.0
    Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nouveau
    unloaded: fbdev,modesetting,vesa failed: nvidia gpu: nvidia resolution:
    1: 3440x1440 2: 1440x2560~60Hz
    OpenGL: renderer: NVIDIA GeForce RTX 4070 Ti SUPER/PCIe/SSE2
    v: 4.6.0 NVIDIA 565.77 direct render: Yes
    Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 00:1f.3
    Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 01:00.1
    Device-3: Focusrite-Novation Scarlett Solo (3rd Gen.) type: USB
    driver: snd-usb-audio bus-ID: 1-9.4.4.1:9
    Sound Server-1: ALSA v: k6.12.10-76061203-generic running: yes
    Sound Server-2: PulseAudio v: 15.99.1 running: no
    Sound Server-3: PipeWire v: 1.0.3 running: yes
    Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
    IF: wlp0s20f3 state: down mac: <filter>
    Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    port: 3000 bus-ID: 06:00.0
    IF: enp6s0 state: up speed: 100 Mbps duplex: full mac: <filter>
    Bluetooth:
    Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-14:4
    address: <filter>
    RAID:
    Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 bus-ID: 00:0e.0
    Local Storage: total: 5.46 TiB used: 1.33 TiB (24.4%)
    ID-1: /dev/nvme0n1 vendor: Kingston model: SNV2S1000G size: 931.51 GiB
    temp: 25.9 C
    ID-2: /dev/nvme1n1 vendor: Kingston model: SNV3S1000G size: 931.51 GiB
    temp: 32.9 C
    ID-3: /dev/nvme2n1 vendor: Kingston model: SNV3S1000G size: 931.51 GiB
    temp: 31.9 C
    ID-4: /dev/sda type: USB vendor: Western Digital model: WD Elements 25A1
    ID-1: / size: 912.93 GiB used: 815.34 GiB (89.3%) fs: ext4
    dev: /dev/nvme0n1p1
    ID-2: /boot/efi size: 2.92 GiB used: 195.3 MiB (6.5%) fs: vfat
    dev: /dev/nvme0n1p2
    ID-1: swap-1 type: zram size: 16 GiB used: 0 KiB (0.0%) dev: /dev/zram0
    System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 37 C
    Fan Speeds (RPM): N/A gpu: nvidia fan: 0%
    Processes: 499 Uptime: 29m Memory: 31.13 GiB used: 7.15 GiB (23.0%)
    Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2405 Shell: Bash
    v: 5.1.16 inxi: 3.3.13
    OS: POP_OS!
    Hi zusammen,
    ich habe das Problem, dass ich weder meine Logitech LIFT noch meine Razer Basilisc verbunden bekomme. Anscheinend hat der Bluetooth Treiber einen weg.
    Habe durch verschiedene Foren schon nach der Lösung gesucht aber nicht gefunden.
    Habe BT via Terminal mal aus und angemacht aber alles bringt nix. Die Basilisk will sich gar nicht verbinden und di4e LIFT connected kurz und dann ist sie aber nicht funktionsfähig.
    Ich wollte deswegen nicht gleich POP_OS! neu installieren. :(
    Vielleicht habt ihr ja Ideen?
    Beim Installieren von Inxi-Fzxi kommt auch folgende Meldung:
    "Fehler traten auf beim Bearbeiten von:
    btusb-lp1542743-dkms
    E: Sub-process /usr/bin/dpkg returned an error code (1)"
  • Hallo beschorner86
    scheint evtl. eine fehlerhafte Installation von btusb-lp1542743-dkms zu sein...
    Versuch mal folgende zwei Befehle im Terminal:
    sudo dpkg --configure -a
    und dann:
    sudo apt install -f
    Dann System neu starten und erneut versuchen...
  • Leider kann ich dir im Moment auch keine Lösung anbieten.
    Aber das hier wird dir auch der Lösung nicht näher bringen.
    Was meinst du damit?
    Inxi dürfte bei dir doch schon installiert sein, denn sonst hättest du die Ausgabe ja nicht posten können.
    Außerdem hast du einen Syntax-Fehler:
    richtig ist inxi (leerzeichen) -Fzxi
    Hier dürfte es sich um eine Installation des Treibers handeln.
    Kannst du uns bitte näher erläutern wie du installieren willst (Befehl)?
    Für Logitech Hardware gibt es unter Linux die Software "Solaar" und wenn die Maus unter Bluetooth nicht will, nimm doch den Logitech Dongle.
    und dann:
    sudo apt install -f
    Das ging leider nicht. Nachdem Neustart konnte ich die Mouse sehen (siehe Screenshot) aber nachdem ich auf "nicht eingerichtet" klickte, stand wieder nicht eingerichtet.
    Ja das denke ich auch.
    Solaar installiert nicht (siehe Screenshot) Er öffnet es zwar, zeigt aber nichts an. Ist Solaar nur für den USB Doongle oder auch für BT?
    Ich möchte einfach nur, dass BT läuft. Also als ich POP_OS vor einem halben Jahr installierte ging das alles problemlos.
    Der Text der angezeigt wird ist dieser: "Error while installing package: »installiertes btusb-lp1542743-dkms-Skript des Paketes post-installation«-Unterprozess gab den Fehlerwert 10 zurück"
  • Du versuchst immer noch den entsprechenden Bluetooth-Treiber zu installieren, obwohl eine Fehlermeldung kommt.
    Darum kannst du auch dein Solaar nicht installieren.
    Kann ich den denn deinstallieren und neu installieren oder so?
  • Das ging leider nicht. Nachdem Neustart konnte ich die Mouse sehen (siehe Screenshot) aber nachdem ich auf "nicht eingerichtet" klickte, stand wieder nicht eingerichtet.
    Diese Befehle haben rein gar nichts mit dem Treiber der Maus zu tun. Die sollen einfach nur dien abgebrochene Installation wieder reparieren.
    Damit du einmal richtig arbeiten kannst, stecke den USB Dongle der Maus ein und schaue einmal das dein System wieder rund läuft.
    Wenn das der Fall ist lass im Terminal einfach mal:
    sudo apt update durchlaufen und schau ob es anstandslos funktioniert.
    Wenn Bluetooth schon einmal funktioniert hat, müsste der Treiber eigentlich passen.
    Gib einfach danach hier Bescheid ob das System , mit angeschlossenem Dongle, wieder normal funktioniert und dann sehen wir weiter.
  • Du könntest noch prüfen, ob evtl. Bluetooth nicht versehentlich blockiert ist...
    Dazu ist ein installiertes rfkill hilfreich:
    sudo apt install rfkill
    Mit folgenden Befehl lässt sich nun eine evtl. Blockade auslesen:
    sudo rfkill list
    Ein funktionierendes Bluetooth sollte in etwa so aussehen:
    user@debian:~$ sudo rfkill list
    [sudo] Passwort für user:
    0: hci0: Bluetooth
    	Soft blocked: no
    	Hard blocked: no
    user@debian:~$
    Eine weitere Möglichkeit wäre, veraltete Firmware-Dateien zu löschen und neu zu installieren:
    sudo rm -r /lib/firmware/ath10k/QCA6174
    sudo apt-get install --reinstall linux-firmware
    PC neu starten - Bluetooth-Dienst neu starten mit:
    sudo systemctl restart bluetooth
  • Diese Befehle haben rein gar nichts mit dem Treiber der Maus zu tun. Die sollen einfach nur dien abgebrochene Installation wieder reparieren.
    Mit dem USB Dongle läuft es. Also die Razer läuft jetzt mit USB Dongle. Die LIFT da habe ich den USB Dongle gerade nicht hier.
    Habe auch den Befehl eingegeben und dann wurde ausgegeben bzw. angezeigt: Alle Pakete sind aktuell.
    Sorry für dei Fragerei aber ich bin bei Linux noch nicht olange dabei.
    Habe das mal probiert und da kam folgendes raus:
    Edited once, last by DenalB: Ein Beitrag von beschorner86 mit diesem Beitrag zusammengefügt. (April 26, 2025 at 11:41 PM).
  • Mit dem USB Dongle läuft es. Also die Razer läuft jetzt mit USB Dongle. Die LIFT da habe ich den USB Dongle gerade nicht hier.
    Super - du brauchst dich nicht zu entschuldigen.
    Es gibt keine dummen Fragen - nur dumme Antworten.
  • Super - du brauchst dich nicht zu entschuldigen.
    Hi,
    alles klar. Danke dir. Wie dem auch so. Ich verstehe immer noch nicht so richtig, wieso es Probleme gibt. Aber dafür läuft es insgesamt mit POP_OS! gut. Ich habe zwar noch Windows 11 drauf aber nutze inzwischen fast nur noch Linux. :)
