- Distrowahl
- Linux Mint
- mikulas@Linux-Mint:~$ inxi -Fzxi
Kernel: 6.8.0-58-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop Mobo: ASUSTeK model: P8H61-M LE v: Rev x.0x
serial: <superuser required> BIOS: American Megatrends v: 0704
date: 07/18/2011
Info: quad core model: Intel Core i7-2600 bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
Speed (MHz): avg: 1692 high: 2151 min/max: 1600/3800 cores: 1: 1596
2: 1600 3: 1596 4: 1600 5: 1804 6: 2151 7: 1596 8: 1596 bogomips: 54259
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: NVIDIA GK208B [GeForce GT 730] vendor: ZOTAC driver: nvidia
v: 470.256.02 arch: Kepler bus-ID: 01:00.0
Device-2: Sunplus Innovation FHD Camera Microphone
driver: snd-usb-audio,uvcvideo type: USB bus-ID: 1-1.1:3
gpu: nvidia,nvidia-nvswitch resolution: 1680x1050~60Hz
API: EGL v: 1.5 drivers: kms_swrast,nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.256.02
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 730/PCIe/SSE2
Device-1: Intel 6 Series/C200 Series Family High Definition Audio
vendor: ASUSTeK 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GK208 HDMI/DP Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Device-3: Creative Labs EMU10k2/CA0100/CA0102/CA10200 [Sound Blaster
Audigy Series] driver: snd_emu10k1 v: kernel bus-ID: 07:00.0
Device-4: Sunplus Innovation FHD Camera Microphone
API: ALSA v: k6.8.0-58-generic status: kernel-api
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: d000 bus-ID: 04:00.0
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 700.14 GiB used: 286.91 GiB (41.0%)
ID-1: /dev/sda vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
ID-2: /dev/sdb vendor: Verbatim model: STORE N GO size: 117.19 GiB
type: USB
ID-3: /dev/sdc vendor: Verbatim model: STORE N GO size: 117.19 GiB
type: USB
ID-1: / size: 207.81 GiB used: 178.21 GiB (85.8%) fs: ext4 dev: /dev/sda1
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nvidia temp: 41 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 30%
Memory: total: 16 GiB available: 15.6 GiB used: 2.2 GiB (14.1%)
Processes: 287 Uptime: 9m Init: systemd target: graphical (5)
Packages: 4231 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Hallo zusammen,
nach dem Befehl im Terminal "sudo apt update" kam eine Meldung, dass einige Pakete aktuallisiert werden müssen und es notwendig ist den Befehl "apt list --upgradable" auszuführen. Da wurden dann fünf Programme gezeigt. Habe mehrfach versucht Programme mit "sudo apt upgrade (+ Programmname) up zu graden. Da kommt dann Meldung mit beschädigten Dateien:
Habe im Internet gesucht und verschiedene Hinweise ausprobiert. Nichts hat geholfen, das Problem besteht weiter hin. Deshalb wende ich mich hier an das Forum und bitte um Hilfe. ![]()
