KDE Neon: Aktualisierungsproblem, wie weiter?
    Sonstiges
    holger@neon:~$ inxi -Fzxi
    Kernel: 6.11.0-21-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    Desktop: KDE Plasma v: 6.3.3 Distro: KDE neon 24.04 6.3
    base: Ubuntu 24.04 LTS Noble
    Type: Desktop Mobo: ASRock model: B550M Pro4 serial: <superuser required>
    UEFI: American Megatrends LLC. v: P3.40 date: 01/18/2024
    Info: 6-core model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3 rev: 0 cache: L1: 384 KiB L2: 3 MiB L3: 16 MiB
    Speed (MHz): avg: 1048 high: 2994 min/max: 400/4464 boost: enabled cores:
    1: 2992 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 2993
    11: 2994 12: 400 bogomips: 93423
    Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 bus-ID: 06:00.0 temp: 28.0 C
    Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.6
    unloaded: fbdev,modesetting,vesa dri: radeonsi gpu: amdgpu
    resolution: 1920x1080
    v: 24.2.8-1ubuntu1~24.04.1 glx-v: 1.4 direct-render: yes renderer: AMD
    Radeon Graphics (radeonsi renoir LLVM 19.1.1 DRM 3.59 6.11.0-21-generic)
    API: Vulkan v: 1.3.275 drivers: N/A surfaces: xcb,xlib,wayland devices: 2
    Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel bus-ID: 06:00.1
    Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel bus-ID: 06:00.6
    Device-3: Generic USB Audio driver: hid-generic,snd-usb-audio,usbhid
    type: USB bus-ID: 3-2.2.1.3:9
    API: ALSA v: k6.11.0-21-generic status: kernel-api
    Server-1: PipeWire v: 1.2.6 status: active
    Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel bus-ID: 03:00.0
    vendor: ASRock driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
    Bluetooth:
    Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB
    bus-ID: 1-7.3:6
    lmp-v: 12
    Local Storage: total: 2.43 TiB used: 15.28 GiB (0.6%)
    ID-1: /dev/nvme0n1 vendor: Intenso model: SSD size: 465.76 GiB
    temp: 30.9 C
    ID-2: /dev/sda vendor: Intenso model: SSD Sata III size: 119.24 GiB
    ID-3: /dev/sdb vendor: Intenso model: SSD Sata III size: 1.86 TiB
    ID-1: / size: 41.61 GiB used: 15.26 GiB (36.7%) fs: ext4 dev: /dev/sda4
    ID-2: /boot/efi size: 299.4 MiB used: 13.6 MiB (4.5%) fs: vfat
    dev: /dev/sda1
    System Temperatures: cpu: 32.1 C mobo: N/A gpu: amdgpu temp: 27.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 32 GiB note: est. available: 30.72 GiB used: 8.31 GiB (27.0%)
    Processes: 328 Uptime: 2h 29m Init: systemd target: graphical (5)
    Packages: 2088 Compilers: N/A Shell: Bash v: 5.2.21 inxi: 3.3.34
    holger@neon:~$
    Moin Leutz,
    habe mir Linux Neon mit KDE Plasma installiert und bin echt begeistert, nachdem ich wochenlang verschiedene Distrubitionen probiert habe.
    Die erste Distru mit der ich von Beginn an gut klarkomme, obwohl ich kein Spezi (ü 70) bin.
    Zum Problem:
    Bei der Aktualisierung über den "Discover" kommt folgende Fehlermeldung immer wieder.
    E: Das Depot »https://ppa.launchpadcontent.net/trebelnik-stef…stomizer/ubuntu noble Release« enthält keine Release-Datei.
    W: Eine Aktualisierung von solch einem Depot kann nicht auf eine sichere Art durchgeführt werden, daher ist es standardmäßig deaktiviert.
    W: Weitere Details zur Erzeugung von Paketdepots sowie zu deren Benutzerkonfiguration finden Sie in der Handbuchseite apt-secure(8).
  • OK - so viel ich heraus gefunden habe, handelt es sich hier um den Grub-Costumizer.
    Den zu verwenden rate ich ab. Da haben schon sehr viele ihr System zerschossen.
    Du müsstest aber auch über Software und Updates diese Quelle deaktivieren können.
    Alternativ auch über das Terminal:
    sudo add-apt-repository --remove ppa:name
    sudo apt update
    Bei "ppa:name" musst du das betreffende Repository eintragen.
  • DenalB March 30, 2025 at 1:43 PM
    Changed the title of the thread from “Aktualisierungsproblem, wie weite?” to “KDE Neon: Aktualisierungsproblem, wie weiter?”.
  • Das mit dem Grub Costumziser kann ich von vorigen Distrus bestätigen, da half auch kein Grub reparieren Stick mehr. Dort kam mal Grub dann wieder Grub2 ?
    Werde es versuchen.
    Die Repository-Verknüpfung „ppa.launchpadcontent.net/trebellnik-stefina/grub-customizer/ubuntu noble Release“ kann nicht verarbeitet werden.
    Hat anscheinend nicht gefunzt?
    Wurde das Passwort abgefragt und wenn ja, hast du es eingegeben?
    Sorry, kann ich nicht mehr sagen. ;(
    Edited once, last by DenalB: 2 Beiträge von Holger56 mit diesem Beitrag zusammengefügt. (March 30, 2025 at 6:05 PM).
  • Code
    olger@neon:~$ sudo apt-get remove grub customizer
    [sudo] Passwort für holger:
    Paket »grub« ist nicht installiert, wird also auch nicht entfernt.
    E: Paket customizer kann nicht gefunden werden.
    holger@neon:~$
    Grub Costomizer ist nach wie vor als Eintrag vorhanden incl. Fehlermeldung. Kann aber nicht mehr gestartet werden.
  • sudo apt-get remove grub customizer
    Äh, mit diesem Befehl würdest du die beiden Pakete grub und customizer entfernen wollen.
    Versuche doch mal sudo apt-get remove grub-customizer.
  • Äh, mit diesem Befehl würdest du die beiden Pakete grub und customizer entfernen wollen.
    Hat leider nicht geklappt, die Fehlermeldung erscheint auch nach einem Neustart.
  • Na ja, der Befehl entfernt ja auch nur das Paket grub-costomizer. Ein entsprechendes Repository wird damit nicht mit entfernt. Das Repository müsste dann auch noch entfernt werden.
    Hattest du das, was @josefine schrieb, schon probiert?
    Ich kenne mich leider mit PPAs nicht aus. :/
    Ja, der Tipp von Josefine hat leider auch nicht gefunzt.
  • Die müssten alle hier drinnen stehen:
    /etc/apt/sources.list.d/
    mit
    sudo nano /etc/apt/sources.list.d/
    müsstest du sie auch bearbeiten, deaktivieren, löschen können.
    Hab schon lange kein Debian basiertes System mehr benutzt, aber wenn mich mine Erinnerungen nicht täuschen müsste das so gehen.
    Man möge mich berichtigen, wenn ich falsch liege.
  • Hi,
    in der Datei "sourcec.list" sind diese Einträge:
    deb http://archive.ubuntu.com/ubuntu/ noble main restricted universe multiverse
    deb http://security.ubuntu.com/ubuntu/ noble-security main restricted universe multiverse
    deb http://archive.ubuntu.com/ubuntu/ noble-updates main restricted universe multiverse
    Frage:
    mittels der "Installation" ist die Fehlerbehebung nicht möglich?
    Gewisse Dateien/Einstellungen entfernen und dann neu istallieren.?
    Edited 2 times, last by DenalB: Ein Beitrag von Holger56 mit diesem Beitrag zusammengefügt. (March 31, 2025 at 9:25 PM).
  • Holger56
    Ehrlich gesagt würde ich hier über eine Neuinstallation nachdenken...
    Vielleicht ist auch KDE Neon nicht die geeignete Wahl...
  • Hi,
    Hier drin stehen die !!!!
    Leute lest doch wenigstens mal richtig!
  • Habe weiter gesucht.
    in der versteckten Datei: apt.conf, öffnete sich nach dem anklicken die bekannte Fehlermeldung.
    Daraufhin den Inhalt dieser apt.conf angesehen:
    Debug::pkgProblemResolver "true";
    Acquire::Languages "none";
    Diese beiden/oder einer der Einträge, scheint mir, sorgen für die Fehlermeldung.
