Mindmap Freeplane und Java Runtime
    Linux Mint
    inxi -Fzxi
    Kernel: 6.8.0-55-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
    base: Ubuntu 24.04 noble
    Type: Laptop System: Micro-Star product: GX780/GT780/GT780DX/GT783 v: N/A
    serial: <superuser required>
    Mobo: Micro-Star model: MS-1761 serial: <superuser required>
    BIOS: American Megatrends v: E1761IMS V1.0H date: 11/18/2011
    Battery:
    ID-1: BAT1 charge: 43.7 Wh (100.0%) condition: 43.7/86.6 Wh (50.4%)
    volts: 12.5 min: 11.1 model: MS-1761 status: full
    Info: quad core model: Intel Core i7-2670QM bits: 64 type: MT MCP
    arch: Sandy Bridge rev: 7 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
    Speed (MHz): avg: 799 high: 800 min/max: 800/3100 cores: 1: 798 2: 800
    3: 798 4: 800 5: 800 6: 798 7: 800 8: 800 bogomips: 35120
    Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
    Device-1: NVIDIA GF114M [GeForce GTX 570M] vendor: Micro-Star MSI
    driver: nouveau v: kernel arch: Fermi bus-ID: 01:00.0 temp: 46.0 C
    loaded: modesetting unloaded: fbdev,vesa dri: nouveau gpu: nouveau
    resolution: 1920x1080~60Hz
    API: EGL v: 1.5 drivers: nouveau,swrast platforms:
    API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.8-1ubuntu1~24.04.1
    glx-v: 1.4 direct-render: yes renderer: NVCE
    Device-1: Intel 6 Series/C200 Series Family High Definition Audio
    vendor: Micro-Star MSI 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    Device-2: NVIDIA GF114 HDMI Audio vendor: Micro-Star MSI
    API: ALSA v: k6.8.0-55-generic status: kernel-api
    vendor: Micro-Star MSI RTL8111/8168/8411 driver: r8169 v: kernel port: d000
    bus-ID: 02:00.0
    IF: enp2s0 state: down mac: <filter>
    Device-2: Intel Centrino Wireless-N 130 driver: iwlwifi v: kernel
    bus-ID: 03:00.0
    Local Storage: total: 2.04 TiB used: 156.4 GiB (7.5%)
    ID-1: /dev/sda vendor: Samsung model: SSD 870 EVO 2TB size: 1.82 TiB
    ID-2: /dev/sdb vendor: Kingston model: SV300S37A240G size: 223.57 GiB
    ID-1: / size: 218.36 GiB used: 156.4 GiB (71.6%) fs: ext4 dev: /dev/sdb3
    ID-2: /boot/efi size: 570.8 MiB used: 6.1 MiB (1.1%) fs: vfat
    dev: /dev/sdb2
    System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 46.0 C
    Fan Speeds (rpm): N/A
    Memory: total: 8 GiB available: 7.73 GiB used: 1.91 GiB (24.7%)
    Processes: 302 Uptime: 4h 12m Init: systemd target: graphical (5)
    Packages: 2613 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Hallo zusammen,
    ich wollte gerne das Programm Freeplane installieren. Aber ich bekomme es nicht zum laufen. Was ich bisher recherchiert habe, ist, dass es evtl. an einer fehlerhaften Java Umgebung liegen könnte.
    Nachfolgend der Startverlauf im Terminal:
    Dabei fallen mir Fehlermeldungen auf, die ich als Nicht-Informatiker leider nicht verstehe - aber vielleicht kann einer von euch Pro's helfen??
    Ich habe die mal dick hervorgehoben, welche ich meine.
    Mit der Fehlersuche im Internet bin ich leider nicht weit(er) gekommen....
    Danke schön vorab!!
    Danach schweigt das Terminal und das Program.....
    Edited once, last by DenalB: Codeblock eingefügt (March 17, 2025 at 1:50 PM).
  • Naja, die Meldung ist wohl so zu interpretieren: du hast neuere Java-Klassen in deinem Package - neuer als die Java-Version auf deinem Rechner. Da hilft vermutlich eine JRE (Java Runtime Environment) mit neuerer Version.
    Was spucken denn folgende Befehle aus:
    which java
    java -version
    echo $JAVA_HOME
    echo $PATH
  • Hallo algl
    sorry für die späte Antwort...es war die letzten Tage etwas unübersichtlich...
    Hier die Ergebnisse aus den Abfragen:
    ***@MSI:~$ which java
    /usr/bin/java
    ***@MSI:~$ java -version
    openjdk version "21.0.6" 2025-01-21
    OpenJDK Runtime Environment (build 21.0.6+7-Ubuntu-124.04.1)
    OpenJDK 64-Bit Server VM (build 21.0.6+7-Ubuntu-124.04.1, mixed mode, sharing)
    ***@MSI:~$ echo $JAVA_HOME
    ***@MSI:~$ echo $PATH
    /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
    ***@MSI:~$
    Bei echo $java_home kam keine Rückmeldung.
    Danke dir für die Unterstützung :)
