Linux Mint: Fehler "Fehlerwert 4" beim Aktualisieren des Kernels
    Linux Mint
    Kernel: 6.8.0-38-generic arch: x86_64 bits: 64 compiler: gcc v: 13.2.0
    base: Ubuntu 24.04 noble
    Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 3805
    date: 05/16/2018
    Info: quad core model: Intel Core i7-6700K bits: 64 type: MT MCP
    arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
    Speed (MHz): avg: 800 min/max: 800/4500 cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 800 bogomips: 63999
    Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: ASUSTeK driver: nvidia
    v: 550.120 arch: Pascal bus-ID: 01:00.0
    gpu: nvidia,nvidia-nvswitch resolution: 1: 1920x1080~60Hz
    2: 1920x1080~60Hz
    API: EGL v: 1.5 drivers: nvidia,swrast platforms:
    active: gbm,x11,surfaceless,device inactive: wayland,device-1
    API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.120
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
    Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
    API: ALSA v: k6.8.0-38-generic status: kernel-api
    Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6
    IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
    Bluetooth:
    Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB
    bus-ID: 1-1:2
    lmp-v: 10
    Local Storage: total: 3.18 TiB used: 291.47 GiB (8.9%)
    ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
    size: 931.51 GiB temp: 33.9 C
    ID-2: /dev/sda vendor: Seagate model: ST1000DM003-1SB102 size: 931.51 GiB
    ID-3: /dev/sdb vendor: Samsung model: SSD 870 EVO 500GB size: 465.76 GiB
    ID-4: /dev/sdc vendor: Western Digital model: WD10EARS-00MVWB0
    ID-1: / size: 72.78 GiB used: 19.8 GiB (27.2%) fs: ext4 dev: /dev/sdb1
    ID-2: /boot/efi size: 96 MiB used: 33.2 MiB (34.6%) fs: vfat
    dev: /dev/nvme0n1p1
    ID-3: /home size: 369.03 GiB used: 81.4 GiB (22.1%) fs: ext4
    dev: /dev/sdb3
    ID-1: swap-1 type: partition size: 15.26 GiB used: 0 KiB (0.0%)
    dev: /dev/sdb2
    System Temperatures: cpu: 26.0 C mobo: N/A gpu: nvidia temp: 39 C
    Fan Speeds (rpm): N/A gpu: nvidia fan: 24%
    Memory: total: 16 GiB available: 15.56 GiB used: 2.76 GiB (17.7%)
    Processes: 313 Uptime: 23m Init: systemd target: graphical (5)
    Packages: 2519 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
    Moin, leider bekam ich bei der upgrade auf Version linux-headers-6.8.0-53 eine Fehlermeldung dann konnte ich den plötzlich Rechner nicht mehr starten.
    Aktuell läuft mein System auf dem 6.8.0-38-Kernel. Alle andere Kernels habe ich entfernt, hat aber nicht geholfen.
    Was ist der Fehlerwert 4 und warum ist /usr/bin/dpkg returned an error code (1) ??
    Kann jemand helfen ??
    Danke im vorraus
    Viele Grüße
    Der Fehler sitzt immer vor dem Monitor
  • radek March 4, 2025 at 11:05 PM
    Changed the title of the thread from “Upgrade” to “Upgrade fehlerwert 4 ??”.
  • exited with return code 4
    I.d.R. ist eine Fehlfunktion im Systembetrieb aufgetreten. Häufige Gründe sind falsche oder fehlgeschlagene Installation oder Deinstallation von Software, die ungültige Einträge in der Registrierung hinterlassen haben, unsachgemäßes Herunterfahren des Systems aufgrund eines Stromausfalls etc. Die unmittelbare Ursache des Fehlers “exited with return code 4” ist eine nicht ordnungsgemäße Ausführung durch das System oder eine seiner Anwendungskomponenten.
    Dürfte ein Resultat aus dem ersten Fehler sein.
    Als Erstes würde ich die Dpkg-Datenbank neu konfigurieren
    sudo dpkg --configure -a
    Als Zweites die kaputten Abhängigkeiten beheben (falls es welche gibt)
    sudo apt install -f
    Als Drittes nicht verwendete Pakete entfernen
    sudo apt autoremove
    sudo apt clean
    sudo apt update
    Danach noch mal testen, ob es funktioniert.
    Aber man muss auch nicht immer die neusten Kernel haben, damit der Rechner läuft. Kaufst dir ja auch nicht jedes halbes Jahr einen neuen Motor fürs Auto!:)
  • Hey Danke werde die Tipps gleich umsetzen .
    Richtig eingetlich ist mir der Kernel egal, aber ab und zu möchte ich es auf mein System aus einen Aktualeren stand bringen ;)
    Unsachgemäßes Herunterfahren des Systems! Ja habe ich des öffteren auch, über den Teminal mit shutdown -h now
    fährt mein Rechen aber auch hin und wieder nicht runter, oft ist er am nächsten Tag ist er immer noch an.
    Gib es da abhilfe??
  • DenalB March 5, 2025 at 2:14 PM
    Changed the title of the thread from “Upgrade fehlerwert 4 ??” to “Linux Mint: Fehler "Fehlerwert 4" beim Aktualisieren des Kernels”.
  • Beim Hochfahren die Umstalltaste oder esc-Taste oder F1 oder F2 drücken (ausprobieren).
    Dann mit dem älteren Kernel, der noch funktioniert hat, starten. Alle neueren Kernel deinstallieren. Der letzte neue Kernel wird wieder in der Aktuallisierungsverwaltung auftauchen. Mit Rechtsklieck die Install. sperren.
  • Er hatte doch geschrieben, das er die Kernel gelöscht hat!
    Ich habe nochmal hoch-und runtergescrollt. Ich habe nichts von einer Kernel-Deinstallation gefunden. Dies sollte nach der Deinstallation nochmal mit sudo apt autopurge nachbearbeitet werden, um auch restlos alles loszuwerden.
  • Jo...nun gut. :) Um auf Nummer sicher zu gehen, wäre es schön, wenn radek mal "sudo dpkg -l | grep linux-image" und danach "uname -r" im Terminal aufrufen würde und Screenshots davon postet. Nur zur Übersicht. Ein alter Kernel, der vorher funktioniert hat, funktioniert auch danach wieder...so jedenfalls meine Erfahrung bisher.
