- Distrowahl
- Linux Mint
- System:
Kernel: 6.8.0-54-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0
base: Ubuntu 24.04 noble
Type: Desktop System: LENOVO product: 4351D2G v: ThinkStation S30
serial: <superuser required>
Mobo: LENOVO model: LENOVO v: 0B98401 PRO serial: <superuser required>
UEFI: LENOVO v: A2KT45AUS date: 05/21/2014
Battery:
Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device
Mouse charge: 55% (should be ignored) status: discharging
Device-2: hidpp_battery_1 model: Logitech MX Keys Wireless Keyboard
charge: 100% (should be ignored) status: discharging
Info: 10-core model: Intel Xeon E5-2690 v2 bits: 64 type: MT MCP
arch: Ivy Bridge rev: 4 cache: L1: 640 KiB L2: 2.5 MiB L3: 25 MiB
Speed (MHz): avg: 1265 high: 2500 min/max: 1200/3600 cores: 1: 1200
2: 1200 3: 1200 4: 1200 5: 1200 6: 1200 7: 1200 8: 1200 9: 1200 10: 1200
11: 1200 12: 1200 13: 1200 14: 1200 15: 1200 16: 1200 17: 1200
18: 1200 19: 1200 20: 2500 bogomips: 120001
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: NVIDIA GP104GL [Quadro P4000] driver: nvidia v: 535.183.01
arch: Pascal bus-ID: 03:00.0
Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver:
X: loaded: nouveau unloaded: fbdev,modesetting,vesa failed: nvidia
gpu: nvidia,nvidia-nvswitch resolution: 6144x3456~60Hz
API: EGL v: 1.5 drivers: nvidia,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 535.183.01
glx-v: 1.4 direct-render: yes renderer: Quadro P4000/PCIe/SSE2
Device-1: Intel C600/X79 series High Definition Audio vendor: Lenovo
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1
API: ALSA v: k6.8.0-54-generic status: kernel-api
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e
v: kernel port: f040 bus-ID: 00:19.0
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: AzureWave driver: rtw89_8852be v: kernel port: c000
bus-ID: 06:00.0
IF: wlp6s0 state: up mac: <filter>
Bluetooth:
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
bus-ID: 1-1.1:3
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter>
bt-v: 5.3 lmp-v: 12
Local Storage: total: 4.09 TiB used: 2.06 TiB (50.3%)
ID-1: /dev/sda vendor: SanDisk model: SDSSDH3 500G size: 465.76 GiB
ID-2: /dev/sdb vendor: Seagate model: ST4000VN008-2DR166
ID-1: / size: 456.89 GiB used: 35.89 GiB (7.9%) fs: ext4 dev: /dev/sda2
dev: /dev/sda1
System Temperatures: cpu: 28.0 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 50%
Memory: total: 64 GiB available: 62.71 GiB used: 2.74 GiB (4.4%)
Processes: 407 Uptime: 13m Init: systemd target: graphical (5)
Packages: 2438 Compilers: gcc: 13.3.0 Shell: Bash v: 5.2.21
inxi: 3.3.34
Liebe Gemeinde,
Ich habe hier ein merkwürdiges Problem mit dem Nvidia Treiber 535.
Das Nividia Tool zeigt mir als Bildschirmauflösung 6144x3456 an.
Cool mein LG Monitor hat sich über Nacht zu einem 6K Monitor gemausert.....
Manuell kann ich zwar auf die korrekten 3840x2160 schalten, das aber nicht Speichern.
Die Cinnamon Bildschirmanpassung zeigt die korrekte Auflösung.
Nun Gut, die Treiberverwaltung empfihlt NVidia 550. Versucht umzuschalten, und die Treiberverwaltung melset fehlende Abhängigkeiten.
Was ist da zu tun?
Soll ich die fehlenden Pakete nachinstallieren?
Oder liegt da ein ganz anderes Problem vor?
Danke im Vorraus für die Hilfe.
